[postgis-devel] Patch for regression tests under Win32
strk at refractions.net strk at refractions.net
Tue Apr 18 02:11:59 PDT 2006
I've applied this patch. Thanks. --strk;
On Mon, Apr 10, 2006 at 08:26:43PM +0200, strk at refractions.net wrote:
> Sounds good to me.
> --strk;
> On Mon, Apr 10, 2006 at 11:46:40AM +0100, Mark Cave-Ayland wrote:
> > Hi everyone,
> > Please find enclosed a patch for review which allows the in-place regression
> > tests to run under MingW (Win32). The problem was that, by default, MingW's
> > pwd returns the current path in MSYS UNIX format (/home/mca.../) instead of
> > Windows format (C:\Documents And Settings\mca..\). By passing the -W
> > parameter to pwd when generating the regression library name, the correct
> > paths are generated in the lwpostgis.sql regression file and so the in-place
> > regression tests can find the DLL.
> > A minor side effect is that I've also had to change lwgeom/Makefile to use #
> > instead of : as the pattern separator, since obviously windows paths contain
> > a : to denote the drive letter :)
