[postgis-devel] Possible server crash detected
strk at refractions.net strk at refractions.net
Tue Apr 18 09:58:25 PDT 2006
Fixed comment and yacc detection macro.
Please have a try. Thanks.
--strk;
On Tue, Apr 18, 2006 at 09:33:26AM -0600, Michael Fuhr wrote:
> On Tue, Apr 18, 2006 at 02:49:48PM +0200, strk at refractions.net wrote:
> > I've fixed the WKT parser to forbid EMPTY elements in multigeometries.
> > I think it makes sense. Also, if such objects are constructed with
> > any other mean I added some checks in the code to raise an error
> > rathern then crashing the backend. Crash tests welcome.
> On Solaris 9 yacc doesn't like the new code:
> /usr/ccs/bin/yacc -vd -p lwg_parse_yy wktparse.y
> "wktparse.y", line 216: fatal: illegal comment
> gmake[1]: *** [wktparse.tab.c] Error 1
> Changing the // comment to /* */ satisfies yacc but the build soon
> fails again:
> wktparse.lex: In function `lwg_parse_yylex':
> wktparse.lex:28: error: `lwg_parse_yylval' undeclared (first use in this function)
> wktparse.lex:28: error: (Each undeclared identifier is reported only once
> wktparse.lex:28: error: for each function it appears in.)
> wktparse.lex: At top level:
> lex.yy.c:3027: warning: 'yyunput' defined but not used
> gmake[1]: *** [lex.yy.o] Error 1
> I don't know if this is the proper solution, but if I edit configure.in
> and change
>   AC_SUBST(YACC)
>   AC_PATH_PROG([YACC], [yacc])
> to
>   AC_PROG_YACC
> and run autogen.sh and configure again, then the build succeeds
> (using bison -y instead of yacc) and all tests pass.
> On my FreeBSD 6.1-PRERELEASE box the code builds and passes all
> tests without any changes.
> Michael Fuhr
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
