[postgis-devel] PostGIS 1.1.7
Kevin Neufeld kneufeld at refractions.net
Tue Dec 5 11:17:50 PST 2006
All,
Just an FYI, I've added a few dozen functions that follow ESRI's ArcSDE
(mostly correct) implementation of the SQL/MM specifications.
http://edndoc.esri.com/arcsde/9.1/sql_api/sqlapi3.htm
Most of these functions are wrappers, exposing exiting PostGIS functions
to an ArcSDE API. It should be noted that not all functions are ported
exactly following the SQL/MM specs. (i.e. our geometry constructors
default to an SRID of -1, while the SQL/MM specs actually specify a
default of 0).
MarkL is currently putting a little documentation together for these.
Cheers,
Kevin
strk at refractions.net wrote:
> On Tue, Dec 05, 2006 at 11:00:20AM +0100, Markus Schaber wrote:
>> Hi, Mark,
>> Mark Leslie wrote:
>>> Changes since 1.1.6
>>>   - Added curved geometry type support for serialization/deserialization.
>>>   - Added point-in-polygon shortcircuit to Contains and Within functions.
>>> Is there anything outstanding before 1.1.7 is released?
>> I don't see any ChangeLog entries for your changes :-(
> Yes, please remember to update the ChangeLog, it's done manually now.
> Also, for every new thing we should have proper documentation and
> unit testing.
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
