[postgis-devel] KML from PostGIS patch
Markus Schaber
schabi at logix-tt.com
Thu Dec 7 02:53:23 PST 2006
Hi, Eduin,
Eduin Carrillo wrote:
> Sounds good. There is another function using this kind of wrappers what I can
> follow to do it? Regress tests are on the road too.
I've just created an example 'on-the-fly', using the EWKT function:
CREATE FUNCTION TransformedEWKT(geometry, int4) RETURNS text
AS 'SELECT asEWKT(transform($1,$2))' STRICT IMMUTABLE LANGUAGE SQL;
So if you expose your function as Foo(), you can add a TransformedFoo()
(or expose your function as PlainFoo, and add Foo() as wrapper).
This way, those people who don't need to transform first (because they
keep the data in a compatible coordinate system) can skip the
transform() overhead.
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
