[postgis-devel] KML from PostGIS patch
Eduin Carrillo yecarrillo at yahoo.com
Fri Dec 8 09:26:25 PST 2006
Hi Paul. This is another patch. Transform function returns the geometry
untouched if requested srid is equal to input srid.
Eduin
--- Paul Ramsey <pramsey at refractions.net> escribió:
> Which points up something: it doesn't look like transform() has a short
> circuit right at the top to simply return the input geometry if the
> requested SRID is the same as the current geometry SRID.
> Markus Schaber wrote:
> > This way, those people who don't need to transform first (because they
> > keep the data in a compatible coordinate system) can skip the
> > transform() overhead.
> > HTH,
> > Markus
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
Type: application/octet-stream
Desc: 1244710316-transform_equal_srid.patch
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20061208/d2f6d073/attachment.obj>
