[postgis-devel] KML from PostGIS patch
strk at refractions.net strk at refractions.net
Fri Dec 15 02:02:04 PST 2006
On Thu, Dec 14, 2006 at 11:57:07AM -0600, Eduin Carrillo wrote:
Applied both. Thanks. Some notes below..
> http://lists.refractions.net/pipermail/postgis-devel/attachments/20061207/fbb4cdc4/kml_from_postgis4.bin
1) I've fixed a dangerous use of pfree() where PFREE_IF_COPY() was needed.
2) A test case would help making sure it works now and it will keep working in the future.
3) Documentation only contains AsKML(geometry, [precision]), but I read in the sql file
   about a "version" parameter and an asUKML variant. What are them ?
--strk;
