[postgis-devel] error with GIST indexes with NULLs
strk at refractions.net
Wed Dec 20 04:07:17 PST 2006
On Fri, Dec 15, 2006 at 05:46:28PM +0000, Mark Cave-Ayland wrote:
> On Fri, 2006-12-15 at 17:00 +0100, strk at refractions.net wrote:
> Hi strk,
> > On Fri, Dec 15, 2006 at 07:36:09AM +0000, Mark Cave-Ayland wrote:
> > > Confirmed. I've had a quick look at this with a debugger, and it appears
> > > that the culprit is BOX2D_union calling PG_RETURN_NULL, which causes
> > > DirectFunctionCall2 to error out in fmgr.c.
> > BOX2D_union is likely *always* returning NULL. We're talking about 459
> > success and 1 failure ...
> AIUI the GiST penalty clause is called to determine into which subtree
> it is the least expensive to insert into - so my guess is that the
> insertion is falling over just after the first page split, but I don't
> have enough time to investigate at the moment :(
I don't have 8.2 around, anyway the attached patch avoids calling DirectFunctionCall2
if both inputs are NULL. Kevin, can you check if it fixes your issue ?
Also, could you add a testcase for this in the SVN repository ? We already have
a regress_lots_of_points.sql file, we should add a regress_lots_of_null.sql and
use it in a similar way from regress_index.sql.
--strk;
Index: lwgeom/lwgeom_gist.c
--- lwgeom/lwgeom_gist.c (revision 2557)
+++ lwgeom/lwgeom_gist.c (working copy)
@@ -959,14 +959,25 @@
#endif
- ud = DirectFunctionCall2(BOX2D_union, origentry->key, newentry->key);
- /*ud = BOX2D_union(origentry->key, newentry->key); */
- tmp1 = size_box2d_double(ud);
- if (DatumGetPointer(ud) != NULL)
- pfree(DatumGetPointer(ud));
+ if (DatumGetPointer(origentry->key) == NULL && DatumGetPointer(newentry->key) == NULL)
+#ifdef PGIS_DEBUG_GIST6
+ elog(NOTICE,"GIST: LWGEOM_gist_penalty called with both inputs NULL");
+#endif
+ *result = 0;
+ else
- *result = tmp1 - size_box2d_double(origentry->key);
+ ud = DirectFunctionCall2(BOX2D_union, origentry->key, newentry->key);
+ /*ud = BOX2D_union(origentry->key, newentry->key); */
+ tmp1 = size_box2d_double(ud);
+ if (DatumGetPointer(ud) != NULL)
+ pfree(DatumGetPointer(ud));
+ *result = tmp1 - size_box2d_double(origentry->key);
elog(NOTICE,"GIST: LWGEOM_gist_penalty called and returning %.15g", *result);
#endif
