[postgis-devel] building from source on RHEL ES 3
Tony Grant tony at tgds.net
Wed Dec 20 04:47:09 PST 2006
On Wed, 2006-12-20 at 09:01 +0000, Mark Cave-Ayland wrote:
> I believe that this has already been fixed in the latest subversion
> repository - see
> http://postgis.refractions.net/pipermail/postgis-users/2006-November/013885.html for the actual patch, or check the changes against the latest lwgeom_gist.c at http://svn.refractions.net/postgis/trunk/lwgeom/lwgeom_gist.c (not sure if this will work directly with 1.1.6 but you can at least see the latest version).
Mark,
I first tried applying the patch but it didn't solve the problem. So I
downloaded the new version into the 1.1.6 tree and it compiled just
fine.
Thanks so much
Tony
