[postgis-devel] estimated_extent & pg_statistic
strk at refractions.net strk at refractions.net
Wed Feb 22 06:24:27 PST 2006
estimated_extent *needs* to know about minimum and maximum salary :)
Does anybody know if it possilble to have functions run in 'setuid' mode
rather then with permissions derived by caller user ?
--strk;
On Mon, Feb 20, 2006 at 10:10:56AM -0000, Martin Schäfer wrote:
> Strk,
> The function estimated_extent seems to make use of the pg_statistic system table. But the PostgreSQL documentation says:
> pg_statistic should not be readable by the public, since even statistical information about a table's contents may be considered sensitive. (Example: minimum and maximum values of a salary column might be quite interesting.) pg_stats is a publicly readable view on pg_statistic that only exposes information about those tables that are readable by the current user.
> So in many installations the pg_statistic table will be unavailable, making estimated_extent unavailable as well. Is it possible to change estimated_extent to use the pg_stats view instead of the pg_statistic table?
> Martin Schaefer
> Cadcorp Ltd.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
      State-collected Geographic Data is public property
                 -*- sign the petition -*-
              http://petition.publicgeodata.org
