[postgis-devel] PostGIS 1.1.0 Win32 Distrib available forFrenchUsers
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Sun Jan 1 13:16:32 PST 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of strk at refractions.net
> Sent: 01 January 2006 21:01
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] PostGIS 1.1.0 Win32 Distrib available
> forFrenchUsers
(cut)
> Thanks, but I think we should find a POSIX shell way for doing this.
> --strk;
Hi strk,
Sure, I agree that it's definitely a MingW bug, and that we should continue
to use the POSIX shell. The main point is that until the bug is fixed, there
is a documented work-around in the archives for those people that need to
produce PostGIS 1.1.0 Win32 builds with MingW.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
