[postgis-devel] FW: [Mingw-msys] RE: Bug with backticks behaviour in mSYS?
david techer davidtecher at yahoo.fr
Tue Jan 3 07:44:27 PST 2006
Hi Marc
Happy New Year too!
Lots of stuff to do this afternoon
I will try your solution this night at home! ;-) on windows xp
--david;
Jean David TECHER
e-mail: davidtecher(at)yahoo(dot)fr
site: http://techer.pascal.free.fr/postgis/
Mark Cave-Ayland a écrit :
>Hi strk/developers,
>Happy New Year! :) I've had a response from the MingW people about the
>quoting with backticks problem we are seeing which causes PostGIS 1.1.0
>builds to fail under Win32. From their point of view, the quoting we are
>using is wrong and from the mail below their suggestions would be equivalent
>to making the following changes in configure.in:
>Line 86/87 change to:
>PGFELIBS=-L`${PGCONFIG} --libdir`" -lpq"
>PGBELIBS=-L`${PGCONFIG} --libdir`" -lpostgres"
>Line 455 change to:
>PGFELIBS=`${PGCONFIG} --libdir`"/libpq.dll"
>These changes work for me after a quick ./autogen.sh, and allow the build to
>complete without error. Does anyone else have any comments/experience about
>quoting in this manner, and how it would work on various platforms?
>Kind regards,
>Mark.
>WebBased Ltd
>17 Research Way
>Plymouth
>PL6 8BT
>T: +44 (0)1752 797131
>F: +44 (0)1752 791023
>http://www.webbased.co.uk
>http://www.infomapper.com
>http://www.swtc.co.uk
>This email and any attachments are confidential to the intended recipient
>and may also be privileged. If you are not the intended recipient please
>delete it from your system and notify the sender. You should not copy it or
>use it for any purpose nor disclose or distribute its contents to any other
>person.
>>-----Original Message-----
>>From: mingw-msys-admin at lists.sourceforge.net [mailto:mingw-msys-
>>admin at lists.sourceforge.net] On Behalf Of Keith MARSHALL
>>Sent: 03 January 2006 12:15
>>To: mingw-msys at lists.sourceforge.net
>>Subject: RE: [Mingw-msys] RE: Bug with backticks behaviour in mSYS?
>>Mark Cave-Ayland wrote, quoting Luke Dunstan:
>>>>The "bash" command you are using is not part of MSYS, so it is
>>>>probably Cygwin bash or something.
>>>The machine I am using MingW/MSys with is 100% cygwin clean, so it
>>>must be something that comes with MingW/MSys/Msys-DTK... I also tried
>>>upgrading to the latest candidate of bash from the releases page to
>>>see what effect that would also have.
>>Mark,
>>We don't distribute bash with any standard MinGW/MSYS/msysDTK package;
>>(or rather we *do*, but we call it sh.exe, so it runs in its POSIX
>>compatibility mode).  You *must* have acquired your bash from some
>>other source, unless you are referring to the bash-2.05b-MSYS.tar.bz2
>>appearing in the MSYS snapshot section of the download page -- and
>>you should note that snapshots may not be stable.
>>IIRC, this snapshot was provided to kludge any environment variable
>>named `prefix' to represent a native Win32 path, even if specified
>>with MSYS semantics;  this was to co-operate more effectively with
>>autoconf, but it has since been established that there is a *much*
>>more effective method of achieving the desired goal.  In any case,
>>that snapshot of bash was intended to be installed as /bin/sh.exe
>>Using the standard MSYS sh.exe, from MSYS-1.0.10.exe, and also using
>>"correct" portable command quoting, I can't reproduce the failure
>>of your original simple test case:
>>  <file name="test.c">
>>  #include <stdio.h>
>>  main()
>>    printf("this is a test string\n");
>>  </file>
>>  <commands>
>>  gcc -o test test.c
>>  sh -c 'echo `./test`" -lpd" > x.x'
>>  od -cb x.x
>>  </commands>
>>  <output>
>>  0000000   t   h   i   s       i   s       a       t   e   s   t       s
>>          164 150 151 163 040 151 163 040 141 040 164 145 163 164 040 163
>>  0000020   t   r   i   n   g       -   l   p   q  \n
>>          164 162 151 156 147 040 055 154 160 161 012
>>  0000033
>>  </output>
>>(This output is reproduced identically, if I rename sh.exe as bash.exe,
>>and adjust the appropriate command accordingly, so even without the
>>POSIX compatibility mode turned on, I can't reproduce the failure).
>>You should avoid using backtick substitution within quoted command
>>arguments;  it isn't *generally* a problem with bash, but some shells
>>-- notably some of the BSD shells -- mishandle them.  And, in this case,
>>I *can* identically reproduce your failure when I use improper quoting,
>>regardless of whether the shell is called sh.exe or bash.exe, i.e. in:
>>  <commands>
>>  sh -c 'echo "`./test` -lpd" > x.x'
>>  od -cb x.x
>>  </commands>
>>the backticked command is improperly quoted, and fails *exactly* as you
>>have described:
>>  <output>
>>  0000020   t   r   i   n   g 001       -   l   p   q  \n
>>          164 162 151 156 147 001 040 055 154 160 161 012
>>  0000034
>>  </output>
>>Regards,
>>Keith.
>>This SF.net email is sponsored by: Splunk Inc. Do you grep through log
>>files
>>for problems?  Stop!  Download the new AJAX search engine that makes
>>searching your log files as easy as surfing the  web.  DOWNLOAD SPLUNK!
>>http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
>>_______________________________________________
>>Mingw-msys mailing list
>>Mingw-msys at lists.sourceforge.net
>>https://lists.sourceforge.net/lists/listinfo/mingw-msys
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
___________________________________________________________________________
Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
Téléchargez sur http://fr.messenger.yahoo.com
