On Thu, Jan 19, 2006 at 03:04:20AM +0100, TECHER David wrote: > Hi > > I would like to know it it could be possible in a next pgsql2shp's version > to use more than the limitation from 10 digits for each field? I think that's a DBF format limit, isn't it ? (I assume you're referring to field names) --strk;
