[postgis-devel] run_test syntax error on Solaris
strk at refractions.net strk at refractions.net
Sat Jan 21 00:41:10 PST 2006
Committed both patches, thanks  --strk;
On Fri, Jan 20, 2006 at 08:27:53PM -0700, Michael Fuhr wrote:
> Regression tests are failing on Solaris 9:
> ./run_test: PGOPTIONS= -c lc_messages=C: is not an identifier
> gmake[1]: *** [test] Error 1
> The error is a result of the following line in run_test:
> export PGOPTIONS="${PGOPTIONS} -c lc_messages=C"
> The traditional Bourne Shell on Solaris doesn't understand the
> "export variable=value" syntax; the assignment and the export must
> be done separately:
> export PGOPTIONS
> I see a similar line that needs to be changed in test_index_concurrency,
> although that isn't part of the regular regression tests.
> Michael Fuhr
