[postgis-devel] loader/dumper tests support
strk at refractions.net strk at refractions.net
Sat Jun 17 02:13:25 PDT 2006
On Fri, Jun 16, 2006 at 04:29:03PM +0100, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> > bounces at postgis.refractions.net] On Behalf Of strk
> > Sent: 16 June 2006 15:19
> > To: Michael Fuhr
> > Cc: postgis-devel at postgis.refractions.net
> > Subject: [postgis-devel] loader/dumper tests support
> > I've extended the regress/run_test script
> > to handle test for loader/dumper.
> > There's a README file under regress/loader that
> > explains how does the test work. Currently only
> > MULTILINE tests are provided for all dimensions.
> > Michael: could you give  the new code a try under Solaris ?
> > --strk;
> Hi strk,
> I've just compiled and run the regression tests from the latest
> postgis-cvs.tar.gz, and all of the tests pass under Win32. Do you think it
> is time for another release to resolve this and the nasty distance()
> function bug? Or should we wait for the SVN upgrade first? ;)
We can release after setting run_test in good shape and adding
shapefile tests for all geometry types.
--strk;
