[postgis-devel] loader/dumper tests support
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Mon Jun 19 03:05:53 PDT 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Michael Fuhr
> Sent: 19 June 2006 03:04
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] loader/dumper tests support
> On Sun, Jun 18, 2006 at 01:30:57PM +0200, strk at refractions.net wrote:
> > Committed, thanks. --strk;
> All tests now pass on my FreeBSD and Solaris boxes. Thanks.
> Michael Fuhr
Hi everyone,
Unfortunately these latest changes cause 3 regression failures on Win32:
loader/Polygon... failed (wkb insert: diff expected obtained:
/tmp/pgis_reg_3420/test_10_diff)
loader/PolygonM... failed (wkb insert: diff expected obtained:
/tmp/pgis_reg_3420/test_11_diff)
loader/PolygonZ... failed (wkb insert: diff expected obtained:
/tmp/pgis_reg_3420/test_12_diff)
Looking at the diffs, it appears to be caused by the signs of some of the
zero coordinates being reversed :( Anyone know what the best way is to
prevent this?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060619/93925124/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060619/93925124/attachment-0001.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060619/93925124/attachment-0002.obj>
