[postgis-devel] 1.1.3 release schedule
strk at refractions.net strk at refractions.net
Sun Jun 25 17:14:50 PDT 2006
I've shifted release date to take new Long Transaction support in.
It's committed now, so any test is appreciated (regress test run
by make check).
--strk;
On Sun, Jun 18, 2006 at 01:33:16PM +0200, strk at refractions.net wrote:
> I'd release 1.1.3 on Friday June 23.
> Changes since 1.1.2:
>         - Can run the regress tests with 'make check' now.
>         - New regress test support for loader/dumper.
>         - BUGFIX in pgsql2shp successful return code.
>         - BUGFIX in shp2pgsql handling of MultiLine WKT.
>         - BUGFIX in affine() failing to update bounding box
>         - WKT parser: forbidden construction of multigeometries with
>           EMPTY elements (still supported for GEOMETRYCOLLECTION).
>         - Added --with-proj-libdir and --with-geos-libdir configure
>           switches
>         - JDBC:
>             - Improved regression tests: MultiPoint and scientific ordinates
>             - Fixed some minor bugs in jdbc code
>             - Added proper accessor functions for all fields in preparation of
>               making those fields private later
>         - Support for build Tru64 build
>         - Use Jade for generating documentation
>         - NEW DumpRings() function
>         - BUGFIX in distance(poly,poly) giving wrong results
>         - NEW AsHEXEWKB(geom, XDR|NDR) function.
>         - Don't link pgsql2shp to more libs then required.
>         - Initial support for PostgreSQL 8.2
> Anyone with pending issues please report asap.
> Thanks.
