[postgis-devel] PostGIS-1.1.3
strk at refractions.net strk at refractions.net
Fri Jun 30 15:01:46 PDT 2006
Tagged and ready to release.
PostGIS 1.1.3
2006/06/30
        - NEW Long Transactions support.
        - Can run the regress tests with 'make check' now.
        - New regress test support for loader/dumper.
        - BUGFIX in pgsql2shp successful return code.
        - BUGFIX in shp2pgsql handling of MultiLine WKT.
        - BUGFIX in affine() failing to update bounding box.
        - WKT parser: forbidden construction of multigeometries with
          EMPTY elements (still supported for GEOMETRYCOLLECTION).
        - Added --with-proj-libdir and --with-geos-libdir configure
          switches.
        - JDBC:
            - Improved regression tests: MultiPoint and scientific ordinates
            - Fixed some minor bugs in jdbc code
            - Added proper accessor functions for all fields in preparation of
              making those fields private later
        - Support for build Tru64 build.
        - Use Jade for generating documentation.
        - NEW DumpRings() function.
        - BUGFIX in distance(poly,poly) giving wrong results.
        - NEW AsHEXEWKB(geom, XDR|NDR) function.
        - Don't link pgsql2shp to more libs then required.
        - Initial support for PostgreSQL 8.2.
--strk;
