[postgis-devel] estimated_extent & pg_statistic
Martin Schäfer Martin.Schaefer at cadcorp.com
Fri Mar 10 07:02:05 PST 2006
Any chance of getting a PostGIS installer containing the patch? The problem was originally reported by one of our users, and I don't think he will get into the business of compiling and installing from command line.
Martin
From: postgis-devel-bounces at postgis.refractions.net on behalf of Mark Cave-Ayland
Sent: Fri 10/03/2006 14:18
To: 'PostGIS Development Discussion'
Subject: RE: [postgis-devel] estimated_extent & pg_statistic
> I've no time to check the patch for this week. If people can test
> it with different pgsql versions (from 73 to 81) that'll help.
Yup, if Martin in particular could test it in his setup, that would be very
helpful.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060310/7c32b9af/attachment.bin>
