[postgis-devel] Re: GEOS-3?
Paul Ramsey pramsey at refractions.net
Thu May 25 06:52:10 PDT 2006
Yes, I was going to move them both... though leaving PostGIS where it
is, is also an option...
P
On 25-May-06, at 2:01 AM, Mark Cave-Ayland wrote:
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>> Sent: 25 May 2006 05:57
>> To: strk
>> Cc: GEOS Development List; PostGIS Development Discussion
>> Subject: [postgis-devel] Re: GEOS-3?
>> We can do the switch any time, I just need to know everyone has
>> committed their changes at a certain time so I can shut down the CVS.
> Hi Paul,
> Is the reason for the CC to the postgis-devel list because the
> PostGIS CVS
> repository is also being upgraded to SVN? :)
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended
> recipient
> and may also be privileged. If you are not the intended recipient
> please
> delete it from your system and notify the sender. You should not
> copy it or
> use it for any purpose nor disclose or distribute its contents to
> any other
> person.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
