[postgis-devel] Re: GEOS-3?
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri May 26 04:35:54 PDT 2006
> -----Original Message-----
> From: strk at refractions.net [mailto:strk at refractions.net]
> Sent: 25 May 2006 16:03
> To: Mark Cave-Ayland
> Cc: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] Re: GEOS-3?
(cut)
> What about a postgis-commits mailing list ?
> --strk;
It would help, but it doesn't have quite the same functionality - ViewVC is
effectively a web CVS/SVN client so you can browse the repository, generate
release tarballs on the fly, view coloured diffs between any two
versions....
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
