[postgis-devel] PostGIS-JDBC
Thomas Marti (HSR)
tmarti at hsr.ch
Thu Nov 30 14:15:43 PST 2006
As there seems to be no real interest by anyone else, we took the matter in our
own hands. We chose some names we thought were appropriate and deploied the JARs
to Refractions' Maven repo ourselves.
Versions 1.1.5 and 1.1.6 of the PostGIS-JDBC-Drivers are available at
http://lists.refractions.net/m2/org/postgis
Maven users now can add this to their pom.xml:
<repositories>
<repository>
<id>refractions</id>
<name>Refractions Research Maven 2 Repository</name>
<url>http://lists.refractions.net/m2</url>
</repository>
</repositories>
<dependencies>
<dependency>
<groupId>org.postgis</groupId>
<artifactId>postgis-jdbc</artifactId>
<version>1.1.6</version>
<scope>test</scope>
</dependency>
<dependency>
<artifactId>postgis-jdbc-jts</artifactId>
<scope>test</scope>
</dependency>
</dependencies>
Bye,
Thomas & Stefan
Thomas Marti (HSR) schrieb:
> Hello everyone
> 2) At the moment the only way to get the JDBC driver, is to either
> download the sources and build it yourself or to install PostGIS and
> then go dig for the JAR-file. In our opinion it would be much better to
> have a separate download for that, as for example the PostgreSQL project
> has (http://jdbc.postgresql.org/). Even better would be to put the JARs
> in a public Maven repository, so Java developers would only have to put
> the dependency in their POM files and the rest is then taken care of by
> Maven.
> We understand that this probably needs some time to be thought about,
> but it would be very convenient for us if we had a decision on a naming
> schema rather quickly. So that we won't have to change everything if you
> eventually do decide to publish to a Maven repository. What is needed
> for the names is a groupId (probably 'postgis' or 'org.postgis') and an
> artifactId for every JAR (e.g. 'postgis'/'postgis_jts',
> 'postgis-jdbc'/'postgis-jts-jdbc', 'postgis-driver'/'postgis-jts-driver'
> or the like...)
