[postgis-devel] Win32 crashes with PostGIS 1.1.4 / PostgreSQL 8.2 -- solved
Markus Schaber schabi at logix-tt.com
Wed Oct 11 03:50:58 PDT 2006
Hi, Strk,
>>> Ok with me, but let's also include the loader/dumper README
>>> issue and the documentation source for Java
>> The EJB3 documentation source is committed to trunk, it's an OpenOffice
>> .odt file. Not exactly what one would expect as "source" usually, but
>> clearly the "preferred form of modification" as stated by the GPL.
> Is it the same of the .pdf ?
I just re-exported the PDF from OOWriter, so now it's shure that they're
identical.
> Should we remove the .pdf from repository then ?
Is there any command line way of producing pdf or html from an .odt
file? I don't like to put the burden of installing OpenOffice.org just
to view the docs.
> Could you add a note in the README about the .odt file ?
Yes, I've done so.
> I've just committed a minor bugfix, but still untested.
Thanks.
Typical copy/paste typo. Shame on me. Code reuse is dangerous :-)
> Note that we have loader/dumper test units under regress dir,
> so maybe we should add an additional test for the -S flag.
> (will probably need additional .expected files)
I'll see whether the regression tests pass, and create new ones.
Can a regression test check for an expected failure? I'd want to make
shure that it properly rejects files that contain true Multi-Geometries.
Thanks,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
