[postgis-devel] Win32 crashes with PostGIS 1.1.4 / PostgreSQL 8.2 -- solved
Markus Schaber schabi at logix-tt.com
Fri Oct 13 05:28:42 PDT 2006
Hi, Strk,
strk at refractions.net wrote:
>> What do you think about the attached formulation for HOWTO_RELEASE?
> No attachment... ?
Oh, sorry, I forgot it. :-(
It's attached now. (I hope. :-)
>> Btw, AFAICS the loader/dumper currently don't include that version info
>> altogether, they only contain the SVN version. Should we add a UTIL_* here?
> loader/dumper show RCSId when called w/out args, that'd help.
Yes, that's what I meant with "contain the SVN version".
But it won't change the uers confusion between PostGIS release numbers,
and SVN versions I mentioned below.
>> It might make sense to change Version.config to contain only the
>> REL_*_VERSION variables, and use them everywhere. There's a low risk
>> that we'll have users upgrade more parts then necessary, e. G. if the
>> loader and the jdbc don't change in a minor release. But as we won't
>> have independent releases of those subprojects, we confuse users even
>> more when we release a PostGIS 1.1.9 that contains a jdbc_1.1.8.jar and
>> a shp2gpsql version 4711.
> Yes, I've been thinknig about this too. Sounds much easier :)
So I'll create those changes soon after the next minor release.
> BTW, I see no critical fixes advertised in the CHANGES file, what did I miss ?
So, I'm afraid that Mark either forgot to mention the fixes in the
CHANGES file, or forgot to commit altogether. He announces the Win32
fixes in
http://postgis.refractions.net/pipermail/postgis-devel/2006-October/002284.html
which you kinda acknowledged in
http://postgis.refractions.net/pipermail/postgis-devel/2006-October/002285.html
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20061013/d0f05f6c/attachment.ksh>
