[postgis-devel] Re: PostGIS datastore creation
alex bodnaru alexbodn at 012.net.il
Wed Sep 20 10:48:20 PDT 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
hi all,
a couple years ago roberto boati and me have made a mechanism to create
and manipulate a postgis enabled postgresql template and you can find
this stuff in the extras subdirectory of the source postgis distribution.
please feel free to contact us for any question.
hope this might help,
alex
Chris Hodgson wrote:
> Greg and Mark, while I think your ideas certainly have merit, I don't
> think they address the main problem - the FDO client needs to be able to
> create a new database using ONLY the SQL connection to the server. The
> FDO client knows nothing of the Platform, OS, or even version of postgis
> that is installed on the server. We can't even use a standard postgis
> stored procedure on the postgres side because if we don't have a spatial
> database yet, none of the postgis stored procedures would be installed.
> However an alternative option to the template GIS database might be to
> create a "global" stored procedure to install postgis into the current
> database, and put that into the template1 or template0 DB... but I think
> I still like the template GIS database plan better.
> As far as actually "creating" the template GIS database, that can only
> sensibly be done as part of the actual postgis install process, as you
> need to know where the postgis.sql file is located, have read access to
> it, have admin access on the database, etc.
> One possible issue I see is that the template GIS database name must be
> unique AND standardized. While this doesn't seem like an unreasonable
> requirement, consider the possibility of multiple different versions of
> postgis installed on one postgresql server. AFAIK, this is currently
> possible using separate databases for each postgis version, and I think
> it isn't a completely unreasonable thing to do, especially during a
> Postgis upgrade/migration. However, I expect FDO won't have a mechanism
> for selecting which version of postgis you want to use for your new
> database, and the only reasonable thing to assume is to use the newest
> version... so perhaps we can safely ignore this situation by making the
> assumption that the newest version of postgis installed will have
> overwritten any previous template GIS database.
> I vote for "template_postgis" as the standardized name.
> Chris
> Mark Cave-Ayland wrote:
>> Maybe another option would be create a small C program called
>> "postgis_install" that could do the install for you. For example:
>>     postgis_install [-h host] [-p port] [-U user] -f lwpostgis.sql
>> The program could work something like this:
>>     - Check for the existence of the template_gis database. If it
>>     doesn't exist, connect to the template1/postgres database,
>>     issue CREATE DATABASE template_gis and disconnect.
>>     - Connect to the template_gis database and simply read in all
>>     commands from the file specified by -f (this would also work
>>     for loading spatial_ref_sys.sql into the template_gis database).
>> Since the program is written in C, it would work across all platforms
>> and would also have the advantage of being able to install on both
>> remote and local servers. It would also mean the installation
>> instructions would be consistent across all platforms, rather than
>> having different sets of instructions for Win32/Unix-based OS.
>> Kind regards,
>> Mark.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Debian - http://enigmail.mozdev.org
iQCVAwUBRRF+5NpwN1sq38njAQJ1YQQAhTKPNR0jHsOcgw3fiXpjnXeCzs1lTkbc
ZMEQWfxy4KHn6ywmEn820iq5YHnO5SLEiTRQwzmrFDhPmDDHBcgurTaOQRDCBkAH
bG6AMn7tH5GuNapnDv+YB4TOb3TyvkBt8wz3La4zKdFvh0EwoQDmgqe9mJF6mMnw
2oZwJo+5Kfo=
=Ms7g
-----END PGP SIGNATURE-----
