[postgis-devel] Re: PostGIS datastore creation
alex bodnaru alexbodn at 012.net.il
Wed Sep 20 15:06:27 PDT 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
i would also favourably comment, that using a template database might
*allow a non dba user to create databases*, provided this user has
createdb privileges, and access to the tables in the template database.
please see the template_gis related code under extras/.
alex
Chris Hodgson wrote:
> Markus Schaber wrote:
>> As long as the libraries (lwgeom, geos, proj) are installed in the
>> correct pathes on the server, it is completely possible to install
>> PostGIS from the client, having the postgis.sql file and the
>> spatial_refsys.sql on the client.
> I agree, but why would you have the correct version of the postgis.sql
> file (or even any postgis.sql file) on the client? That is what I mean
> by reliably. And surely you recognize that the definition of "correct
> paths" is rather subjective - it's perfectly functional to install the
> postgis (and other) libraries in any path at all (I might have to put it
> in my home directory if I'm doing a pure user-mode install) - all that
> would be reflected in the postgis.sql file... and as long as I had that
> specific postgis.sql file on the remote client, then yes, it would be
> possible. But I think it would be confusing and misleading to say that
> anything like a "remote postgis install" was possible, considering the
> very specific circumstances required.
> Actually, if you have the right postgis.sql, all you need is psql to
> install it. There is our installer! Just change postgis.sql to create
> and switch to "template_postgis", and perhaps rename it to
> "install_postgis_template.sql". Then we don't have to worry about
> platforms, etc., as we can safely assume that psql is already available
> to us.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Debian - http://enigmail.mozdev.org
iQCVAwUBRRG7Y9pwN1sq38njAQIoRAP/aHhgj4/AOBHAUo/cBy2FHEsk9S26Cbr8
l56aI5o0LrLC0V5Vh3xFipXpyQOmd+/rSxd6daI7rhZagpCkPNY8eZ+Uucf9YrYm
qdQ2ugWUONZaJ2lrHnS47cwYnMggKGKif98LAmhjkUao03hXZZsiLXM70dUY2fgz
mCqXfcbiWAo=
=5X/F
-----END PGP SIGNATURE-----
