[postgis-devel] temporal indexing
Elena Camossi elena.camossi at gmail.com
Thu Aug 9 00:51:57 PDT 2007
Hi Paul,
does the cube constructor syntax allow to build a cube on geometric and
temporal columns?
I'm asking because all what I have found in the manual is the possibility to
construct cube on float values.
Best regards,
-Elena
On 8/8/07, Paul Ramsey <pramsey at refractions.net> wrote:
> I have had good success building a functional index on the cube
> constructors. That way you can have the cube index while not carrying
> the extra weight of a cube object in every tuple.
> Chris Hodgson wrote:
> > In order to build the cube index you will need to add an additional
> > column of type 'cube'
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>    Paul Ramsey
>    Refractions Research
>    http://www.refractions.net
>    Phone: 250-383-3022
>    Cell: 250-885-0632
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070809/46f7d47d/attachment.html>
