[postgis-devel] Packaging PostGIS for Windows - which to choose?
Paul Ramsey pramsey at refractions.net
Fri Aug 10 12:21:53 PDT 2007
Go with (ii).  We've just tried some serious work on (iii) and run
into some un-debuggable problems (if the problem happens to be in
libgcj, you're SOL), so unfortunately it looks like we're going to be
stuck with GEOS for a while longer.
There should be more maintainer effort around GEOS again over the
next few months, but I can't promise anything in the shortshort term.
P
On 10-Aug-07, at 11:17 AM, Mark Cave-Ayland wrote:
> Hi folks,
> I'm hoping to have some time to look at packaging the Win32 builds of
> PostGIS this weekend, but I am currently unsure as to which route to
> take with respect to GEOS/JTS.
> My options are as follows:
> i) GEOS v2
> Quite long in the tooth now, but it works. However quite a few people
> have reported back that GEOS v3 gives them better results.
> ii) GEOS v3
> A lot of people find that GEOS v3 gives better results with
> the spatial predicates, however there hasn't been a new RC for over 6
> months now and there doesn't seem to be much in the way of handling
> bug
> reports or fixes, so the project currently appears stagnant :(
> iii) JTS
> There does appear to be several recent commits to the JTS connector in
> the PostGIS source tree, however I've never attempted to
> build JTS for Win32 before and so relative performance to GEOS v3 is
> unknown. However, a lot of new features/optimisations tend to make it
> to JTS first.
> I'm leaning towards option ii) or iii), since with a major version
> change it would be a good time to change the underlying libraries as
> people will generally expect and check for changes in behaviour. Does
> anyone else have any thoughts on what would be the best way forward?
> Many thanks,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
