[postgis-devel] Packaging PostGIS for Windows - which to choose?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri Aug 10 12:28:10 PDT 2007
On Fri, 2007-08-10 at 12:21 -0700, Paul Ramsey wrote:
> Go with (ii).  We've just tried some serious work on (iii) and run
> into some un-debuggable problems (if the problem happens to be in
> libgcj, you're SOL), so unfortunately it looks like we're going to be
> stuck with GEOS for a while longer.
> There should be more maintainer effort around GEOS again over the
> next few months, but I can't promise anything in the shortshort term.
> P
Okay will do. Are there any plans to check & apply outstanding bug
reports and push out a RC5? For example, this
http://postgis.refractions.net/bugs/bug.php?op=show&bugid=158 looks
worth fixing...
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
