[postgis-devel] Re: [postgis-users] PostGIS 1.3.0 Released
Obe, Regina robe.dnd at cityofboston.gov
Mon Aug 13 06:00:12 PDT 2007
I see a slight typo  in A.1.1.3.
geometery  should be geometry
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Monday, August 13, 2007 3:24 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Re: [postgis-users] PostGIS 1.3.0 Released
On Sun, 2007-08-12 at 20:45 +0100, Mark Cave-Ayland wrote:
> Also, one other thing I noticed: there are no release notes for the
1.3.0 release in
> the documentation here:
http://postgis.refractions.net/docs/apa.html#id2834647.
Now that I've fixed the XML error in postgis.xml, the release notes
appear on my local copy here so I guess that the website wasn't updating
because the documentation build was failing :(  Hopefully the website
should pick up the fixed version over the next day or so.
I've also committed a small fix for an unused variable warning which was
leftover from the PostgreSQL 8.3 patch.
So, if you re-tag the 1.3.0 release from trunk then these fixes will
automagically be included in the next 1.3.0 tarball.
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
