[postgis-devel] AsGML output not valid?
Christopher Schmidt crschmidt at metacarta.com
Wed Aug 29 05:13:17 PDT 2007
On Wed, Aug 29, 2007 at 08:57:09AM +0100, Mark Cave-Ayland wrote:
> Hi Christopher,
> We currently have a GML patch posted for review - I personally haven't
> had time to look at it in greater detail yet, plus it is likely to
> require a few more eyes since I don't tend to use GML everyday.
The actual GML2 output would correct the current problems. For the
record, you can paste GML into
http://dev.openlayers.org/sandbox/tschaub/xml/examples/vector-formats.html
to see it on a map, if it's in geographic coordinates.
I don't know enough about GML3 to say whether the GML3 output is
correct.
> http://postgis.refractions.net/pipermail/postgis-devel/2007-July/002690.html
> http://postgis.refractions.net/pipermail/postgis-devel/2007-July/002715.html
> http://postgis.refractions.net/pipermail/postgis-devel/2007-August/002744.html
> Would this solve the problems you are experiencing?
Yep.
> I'm intending to
> look at this when I get a free moment, and if you are able to test, it
> would be a great help.
I can't apply the patch at the moment: I'll see what I can do to get a
machine on which I can build postgis from source to play with.
Regards,
Christopher Schmidt
MetaCarta
