[postgis-devel] RE: Geotools, PostGis and Hibernate
VanIngen, Erik (ESTG) Erik.VanIngen at fao.org
Wed Aug 29 07:53:16 PDT 2007
Hi Karel,
Thank you for your quick reply.
We use Geoserver/Geotools together with our own application. Our own
application is heavily using Hibernate. For this reason we would like to use
the Hibernate DataStore to add to Geotools in order to serve Geoserver.
Why did you decide to abondon Hibernate DataStore? Was this because you do
not use Geotools anymore? Any information is welcome to us, we are in the
starting phase of the project.
Kind Regards,
Andrea & Erik
I'm working on something along those lines: Hibernate Spatial. It's
an extension on Hibernate so that it can work with JTS Geometry
classes (which is the geometry used in GeoTools feature model).
Here is the project page: http://www.cadrie.com/projects/majas-
hibernate/hibernate-spatial/introduction.html
NOTE: in the next couple of weeks the project will be moved to a new
home (http://www.hibernatespatial.org/)
Hibernate Spatial was developed in part during the MAJAS project.
There we worked for while on a Geotools datastore that used the
Hibernate Spatial as backend. This code can still be found on https://
www.cadrie.com/svn/majas/trunk/majas-hibernate-datastore/.  I do not
know how useful this code is at present. We abandoned development of
the Hibernate DataStore because working directly with Hibernate
Spatial was easier for us. If you're interested in this, I'll try to
revive development.
Regards,
Karel Maesen
>  -----Original Message-----
> From: 	VanIngen, Erik (ESTG)
> Sent:	28 August 2007 17:20
> To:	'postgis-devel at postgis.refractions.net'
> Subject:	Geotools, PostGis and Hibernate
> Hi all,
> We are working for Fao on a open source project called Fenix (just began).
> We need or need to develop a Geotools Datastore for Hibernate mapping to
> PostGis.
> Is this already done or are there any examples?
> Any suggestion or comments are very welcome and will be thanked with a
> pizza in Rome.
> Kind Regards,
> Andrea & Erik
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070829/267e92e0/attachment.html>
