[postgis-devel] AsKML cleanups patch
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Sun Dec 2 12:47:50 PST 2007
On Sun, 2007-12-02 at 00:56 -0800, Eduin Carrillo wrote:
> Hi folks,
> I've made an update to KML routines mainly to get sync with latest AsGML changes. Additionally, some cleanups have been done:
> * Removed references to SRS handling (only EPSG:4326 here)
> * Removed getSRSbySRID()
> * Corrected Id and Log CVS tags
> Please let me know if tests are ok
> Thanks
Hi Eduin,
Thanks for the patch. I like the idea of bringing the KML routines in
sync with the GML routines, however a couple of things I have noticed in
the patch are:
- By adding a version number/precision parameter to AsKML(), you also
need to change lwpostgis.sql.in to reflect these changes.
- There are still references to GML rather than KML in your patch.
- SVN doesn't use CVS-style $Log/$Id tags, so you don't need to change
these at all.
- There is no documentation patch to reflect the new function
parameters.
Also, are we 100% sure we can drop all SRIDs except 4326 from the KML
output? What does the official KML documentation say about this?
HTH,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
