[postgis-devel] [Fwd: That jdbc bug on Rawhide]
Devrim GUNDUZ
devrim at CommandPrompt.com
Fri Jan 12 01:17:05 PST 2007
On Mon, 2007-01-08 at 10:55 +0100, Markus Schaber wrote:
> > > Attached is a diff between the 2 postgres drivers. If you look
> > > carefully, you can see that the debug and info method are removed
> on
> > > Driver are removed in 8.2
> > > The postgis guys should probably call Logger.debug.
> I just committed a fix for that problem - which also means that we
> won't compile and work on jdk 1.3 or earlier, and some free java
> implementations (debian oldstable etc.), any more.
Does not *seem* to work, unless I'm missing anything. See my previous
e-mail.
Regards,
The PostgreSQL Company - Command Prompt, Inc. 1.503.667.4564
PostgreSQL Replication, Consulting, Custom Development, 24x7 support
Managed Services, Shared and Dedicated Hosting
Co-Authors: plPHP, ODBCng - http://www.commandprompt.com/
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070112/14aa42f4/attachment.sig>
