[postgis-devel] PostGIS release
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Wed Jul 11 21:44:43 PDT 2007
On Wed, 2007-07-11 at 16:52 -0700, Mark Leslie wrote:
> I've churned out a tarball, basically a copy of the svn tarball as of
> two minutes ago, and stashed it at
> http://postgis.refractions.net/postgis-1.3.0RC1.tar.gz
> I don't yet have a link on the downloads page.
> Mark
Hi Mark,
Looks there are some regression failures in MingW for
sql-mm-multisurface which are present for both GEOS 2.2.3 and GEOS
3.0.0rc4. It appears to be some kind of precision issue - what is the
best way for this release to pass regression? Output included below.
ATB,
Mark.
make -C regress test
make[1]: Entering directory `/home/mca/postgis/pg82/postgis-svn/regress'
make -C ../lwgeom all-shared-lib
make[2]: Entering directory `/home/mca/postgis/pg82/postgis-svn/lwgeom'
make[2]: Nothing to be done for `all-shared-lib'.
make[2]: Leaving directory `/home/mca/postgis/pg82/postgis-svn/lwgeom'
cpp -P -traditional-cpp sql-mm-circularstring_expected.in | grep -v "^
cpp -P -traditional-cpp sql-mm-compoundcurve_expected.in | grep -v "^$"
cpp -P -traditional-cpp sql-mm-curvepoly_expected.in | grep -v "^$" >
cpp -P -traditional-cpp sql-mm-multicurve_expected.in | grep -v "^$" >
cpp -P -traditional-cpp sql-mm-multisurface_expected.in | grep -v "^$"
Creating spatial db postgis_reg
createlang: language "plpgsql" is already installed in database
"postgis_reg"
TMPDIR is /tmp/pgis_reg_428
 PostgreSQL 8.2.0 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
3.4.2 (mingw-special)
 Postgis 1.2.2SVN
 - 2007-07-12 03:03:11
   GEOS: 2.2.3-CAPI-1.1.1
   JTS:
   PROJ: Rel. 4.5.0, 22 Oct 2006
Running tests
 loader/Point.............. ok
 loader/PointM.............. ok
 loader/PointZ.............. ok
 loader/MultiPoint.............. ok
 loader/MultiPointM.............. ok
 loader/MultiPointZ.............. ok
 loader/Arc.............. ok
 loader/ArcM.............. ok
 loader/ArcZ.......... ok
 loader/Polygon.............. ok
 loader/PolygonM.............. ok
 loader/PolygonZ.............. ok
 regress. ok
 regress_index. ok
 regress_index_nulls. ok
 lwgeom_regress. ok
 regress_lrs. ok
removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-serialize. ok
 sql-mm-circularstring. ok
 sql-mm-compoundcurve. ok
 sql-mm-curvepoly. ok
 sql-mm-general. ok
 sql-mm-multicurve. ok
 sql-mm-multisurface. failed (diff expected obtained:
/tmp/pgis_reg_428/test_33_diff)
 regress_ogc. ok
 regress_bdpoly. ok
 regress_proj. ok
 kml. ok
Run tests: 37
Failed: 1
"postgis_reg"
TMPDIR is /tmp/pgis_reg_564
 Postgis 1.2.2SVN
 - 2007-07-12 03:23:02
   GEOS: 3.0.0rc4-CAPI-1.3.3
   JTS:
Running tests
 regress. ok
 regress_index. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-general. ok
/tmp/pgis_reg_564/test_33_diff)
 regress_ogc. ok
 regress_bdpoly. ok
 regress_proj. ok
 kml. ok
Run tests: 37
Failed: 1
ILande - Open Source Consultancy
http://www.ilande.co.uk
45,52c45,52
< ST_CurveToLine-401|MULTIPOLYGON(((-2 0,-1.92387953251129 -0.38268343236509,-1.70710678118655 -0.707106781186548,-1.38268343236509 -0.923879532511287,-1 -1,-0.61731656763491 -0.923879532511287,-0.292893218813452 -0.707106781186547,-0.0761204674887132 -0.38268343236509,0 0,0.0761204674887133 -0.38268343236509,0.292893218813453 -0.707106781186548,0.61731656763491 -0.923879532511287,1 -1,1.38268343236509 -0.923879532511287,1.70710678118655 -0.707106781186547,1.92387953251129 -0.38268343236509,2 0,1.84775906502257 0.76536686473018,1.4142135623731 1.41421356237309,0.76536686473018 1.84775906502257,1.22460635382238e-16 2,-0.765366864730179 1.84775906502257,-1.41421356237309 1.4142135623731,-1.84775906502257 0.76536686473018,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
< ST_CurveToLine-402|MULTIPOLYGONM(((-2 0 0,-1.92387953251129 -0.38268343236509 0.5,-1.70710678118655 -0.707106781186548 1,-1.38268343236509 -0.923879532511287 1.5,-1 -1 2,-0.61731656763491 -0.923879532511287 2.5,-0.292893218813452 -0.707106781186547 3,-0.0761204674887132 -0.38268343236509 3.5,0 0 4,0.0761204674887133 -0.38268343236509 4.5,0.292893218813453 -0.707106781186548 5,0.61731656763491 -0.923879532511287 5.5,1 -1 6,1.38268343236509 -0.923879532511287 6.5,1.70710678118655 -0.707106781186547 7,1.92387953251129 -0.38268343236509 7.5,2 0 8,1.84775906502257 0.76536686473018 7,1.4142135623731 1.41421356237309 6,0.76536686473018 1.84775906502257 5,1.22460635382238e-16 2 4,-0.765366864730179 1.84775906502257 3,-1.41421356237309 1.4142135623731 2,-1.84775906502257 0.76536686473018 1,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
< ST_CurveToLine-403|MULTIPOLYGON(((-2 0 0,-1.92387953251129 -0.38268343236509 0.25,-1.70710678118655 -0.707106781186548 0.5,-1.38268343236509 -0.923879532511287 0.75,-1 -1 1,-0.61731656763491 -0.923879532511287 1.25,-0.292893218813452 -0.707106781186547 1.5,-0.0761204674887132 -0.38268343236509 1.75,0 0 2,0.0761204674887133 -0.38268343236509 2.25,0.292893218813453 -0.707106781186548 2.5,0.61731656763491 -0.923879532511287 2.75,1 -1 3,1.38268343236509 -0.923879532511287 3.25,1.70710678118655 -0.707106781186547 3.5,1.92387953251129 -0.38268343236509 3.75,2 0 4,1.84775906502257 0.76536686473018 3.5,1.4142135623731 1.41421356237309 3,0.76536686473018 1.84775906502257 2.5,1.22460635382238e-16 2 2,-0.765366864730179 1.84775906502257 1.5,-1.41421356237309 1.4142135623731 1,-1.84775906502257 0.76536686473018 0.5,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
< ST_CurveToLine-404|MULTIPOLYGON(((-2 0 0 0,-1.92387953251129 -0.38268343236509 0.25 0.5,-1.70710678118655 -0.707106781186548 0.5 1,-1.38268343236509 -0.923879532511287 0.75 1.5,-1 -1 1 2,-0.61731656763491 -0.923879532511287 1.25 2.5,-0.292893218813452 -0.707106781186547 1.5 3,-0.0761204674887132 -0.38268343236509 1.75 3.5,0 0 2 4,0.0761204674887133 -0.38268343236509 2.25 4.5,0.292893218813453 -0.707106781186548 2.5 5,0.61731656763491 -0.923879532511287 2.75 5.5,1 -1 3 6,1.38268343236509 -0.923879532511287 3.25 6.5,1.70710678118655 -0.707106781186547 3.5 7,1.92387953251129 -0.38268343236509 3.75 7.5,2 0 4 8,1.84775906502257 0.76536686473018 3.5 7,1.4142135623731 1.41421356237309 3 6,0.76536686473018 1.84775906502257 2.5 5,1.22460635382238e-16 2 2 4,-0.765366864730179 1.84775906502257 1.5 3,-1.41421356237309 1.4142135623731 1 2,-1.84775906502257 0.76536686473018 0.5 1,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
< ST_CurveToLine01|MULTIPOLYGON(((-2 0,-1.99879545620517 -0.049067674327418,-1.9951847266722 -0.0980171403295604,-1.98917650996478 -0.146730474455361,-1.98078528040323 -0.195090322016128,-1.97003125319454 -0.242980179903263,-1.95694033573221 -0.290284677254461,-1.94154406518302 -0.336889853392219,-1.92387953251129 -0.382683432365089,-1.90398929312344 -0.427555093430281,-1.88192126434836 -0.471396736825996,-1.85772861000027 -0.51410274419322,-1.83146961230255 -0.555570233019601,-1.80320753148065 -0.595699304492432,-1.77301045336274 -0.634393284163644,-1.74095112535496 -0.671558954847017,-1.70710678118655 -0.707106781186546,-1.67155895484702 -0.740951125354957,-1.63439328416365 -0.773010453362735,-1.59569930449244 -0.803207531480643,-1.5555702330196 -0.831469612302543,-1.51410274419322 -0.85772861000027,-1.471396736826 -0.881921264348353,-1.42755509343029 -0.903989293123442,-1.38268343236509 -0.923879532511285,-1.33688985339222 -0.94154406518302,-1.29028467725447 -0.956940335732208,-1.24298017990327 -0.970031253194543,-1.19509032201613 -0.98078528040323,-1.14673047445537 -0.98917650996478,-1.09801714032956 -0.995184726672197,-1.04906767432742 -0.998795456205172,-1 -1,-0.950932325672585 -0.998795456205173,-0.901982859670443 -0.995184726672197,-0.853269525544641 -0.989176509964781,-0.804909677983875 -0.980785280403231,-0.757019820096739 -0.970031253194545,-0.709715322745541 -0.95694033573221,-0.663110146607783 -0.941544065183022,-0.617316567634913 -0.923879532511288,-0.57244490656972 -0.903989293123445,-0.528603263174005 -0.881921264348356,-0.485897255806781 -0.857728610000273,-0.4444297669804 -0.831469612302547,-0.404300695507569 -0.803207531480646,-0.365606715836356 -0.773010453362739,-0.328441045152983 -0.740951125354961,-0.292893218813454 -0.707106781186549,-0.259048874645043 -0.67155895484702,-0.226989546637265 -0.634393284163647,-0.196792468519356 -0.595699304492435,-0.168530387697456 -0.555570233019604,-0.142271389999729 -0.514102744193224,-0.118078735651646 -0.471396736826,-0.0960107068765576 -0.427555093430284,-0.0761204674887141 -0.382683432365092,-0.0584559348169799 -0.336889853392222,-0.0430596642677918 -0.290284677254464,-0.0299687468054565 -0.242980179903266,-0.01921471959677 -0.19509032201613,-0.0108234900352193 -0.146730474455364,-0.00481527332780333 -0.0980171403295628,-0.00120454379482771 -0.0490676743274202,0 0,0.0012045437948276 -0.049067674327418,0.00481527332780309 -0.0980171403295604,0.010823490035219 -0.146730474455361,0.0192147195967694 -0.195090322016128,0.0299687468054558 -0.242980179903263,0.0430596642677909 -0.290284677254461,0.0584559348169789 -0.336889853392219,0.0761204674887128 -0.382683432365089,0.0960107068765561 -0.427555093430281,0.118078735651644 -0.471396736825996,0.142271389999727 -0.51410274419322,0.168530387697454 -0.555570233019601,0.196792468519354 -0.595699304492432,0.226989546637262 -0.634393284163644,0.259048874645039 -0.671558954847017,0.292893218813451 -0.707106781186546,0.32844104515298 -0.740951125354957,0.365606715836352 -0.773010453362735,0.404300695507564 -0.803207531480643,0.444429766980395 -0.831469612302543,0.485897255806775 -0.85772861000027,0.528603263173999 -0.881921264348353,0.572444906569714 -0.903989293123442,0.617316567634907 -0.923879532511285,0.663110146607777 -0.94154406518302,0.709715322745534 -0.956940335732208,0.757019820096733 -0.970031253194543,0.804909677983868 -0.98078528040323,0.853269525544635 -0.98917650996478,0.901982859670436 -0.995184726672197,0.950932325672579 -0.998795456205172,0.999999999999997 -1,1.04906767432741 -0.998795456205173,1.09801714032956 -0.995184726672197,1.14673047445536 -0.989176509964781,1.19509032201613 -0.980785280403231,1.24298017990326 -0.970031253194545,1.29028467725446 -0.95694033573221,1.33688985339222 -0.941544065183022,1.38268343236509 -0.923879532511288,1.42755509343028 -0.903989293123445,1.471396736826 -0.881921264348356,1.51410274419322 -0.857728610000273,1.5555702330196 -0.831469612302547,1.59569930449243 -0.803207531480646,1.63439328416364 -0.773010453362739,1.67155895484702 -0.740951125354961,1.70710678118655 -0.707106781186549,1.74095112535496 -0.67155895484702,1.77301045336274 -0.634393284163647,1.80320753148064 -0.595699304492435,1.83146961230254 -0.555570233019604,1.85772861000027 -0.514102744193224,1.88192126434835 -0.471396736826,1.90398929312344 -0.427555093430284,1.92387953251129 -0.382683432365092,1.94154406518302 -0.336889853392222,1.95694033573221 -0.290284677254464,1.97003125319454 -0.242980179903266,1.98078528040323 -0.19509032201613,1.98917650996478 -0.146730474455364,1.9951847266722 -0.0980171403295628,1.99879545620517 -0.0490676743274202,2 0,1.99759091241034 0.098135348654836,1.99036945334439 0.196034280659121,1.97835301992956 0.293460948910723,1.96157056080646 0.390180644032256,1.94006250638909 0.485960359806528,1.91388067146442 0.580569354508925,1.88308813036604 0.67377970678444,1.84775906502257 0.76536686473018,1.80797858624689 0.855110186860564,1.76384252869671 0.942793473651995,1.71545722000054 1.02820548838644,1.66293922460509 1.1111404660392,1.60641506296129 1.19139860898487,1.54602090672547 1.26878656832729,1.48190225070992 1.34311790969404,1.41421356237309 1.4142135623731,1.34311790969404 1.48190225070992,1.26878656832729 1.54602090672547,1.19139860898487 1.60641506296129,1.1111404660392 1.66293922460509,1.02820548838644 1.71545722000054,0.942793473651994 1.76384252869671,0.855110186860563 1.80797858624689,0.765366864730178 1.84775906502257,0.673779706784439 1.88308813036604,0.580569354508923 1.91388067146442,0.485960359806526 1.94006250638909,0.390180644032255 1.96157056080646,0.293460948910722 1.97835301992956,0.196034280659119 1.99036945334439,0.098135348654834 1.99759091241034,-2.09798541386808e-15 2,-0.0981353486548382 1.99759091241034,-0.196034280659124 1.99036945334439,-0.293460948910726 1.97835301992956,-0.390180644032259 1.96157056080646,-0.48596035980653 1.94006250638909,-0.580569354508927 1.91388067146442,-0.673779706784443 1.88308813036604,-0.765366864730182 1.84775906502257,-0.855110186860567 1.80797858624689,-0.942793473651998 1.76384252869671,-1.02820548838645 1.71545722000054,-1.11114046603921 1.66293922460509,-1.19139860898487 1.60641506296129,-1.26878656832729 1.54602090672547,-1.34311790969404 1.48190225070992,-1.4142135623731 1.41421356237309,-1.48190225070992 1.34311790969404,-1.54602090672547 1.26878656832729,-1.60641506296129 1.19139860898487,-1.66293922460509 1.11114046603921,-1.71545722000054 1.02820548838644,-1.76384252869671 0.942793473651997,-1.80797858624689 0.855110186860566,-1.84775906502257 0.765366864730181,-1.88308813036604 0.673779706784442,-1.91388067146442 0.580569354508927,-1.94006250638909 0.485960359806531,-1.96157056080646 0.39018064403226,-1.97835301992956 0.293460948910727,-1.99036945334439 0.196034280659125,-1.99759091241034 0.0981353486548404,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
< ST_CurveToLine02|MULTIPOLYGONM(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.125,-1.98917650996478 -0.146730474455361 0.187499999999999,-1.98078528040323 -0.195090322016128 0.249999999999999,-1.97003125319454 -0.242980179903263 0.312499999999999,-1.95694033573221 -0.290284677254461 0.374999999999999,-1.94154406518302 -0.336889853392219 0.437499999999999,-1.92387953251129 -0.382683432365089 0.499999999999998,-1.90398929312344 -0.427555093430281 0.562499999999998,-1.88192126434836 -0.471396736825996 0.624999999999998,-1.85772861000027 -0.51410274419322 0.687499999999998,-1.83146961230255 -0.555570233019601 0.749999999999997,-1.80320753148065 -0.595699304492432 0.812499999999997,-1.77301045336274 -0.634393284163644 0.874999999999997,-1.74095112535496 -0.671558954847017 0.937499999999997,-1.70710678118655 -0.707106781186546 0.999999999999997,-1.67155895484702 -0.740951125354957 1.0625,-1.63439328416365 -0.773010453362735 1.125,-1.59569930449244 -0.803207531480643 1.1875,-1.5555702330196 -0.831469612302543 1.25,-1.51410274419322 -0.85772861000027 1.3125,-1.471396736826 -0.881921264348353 1.375,-1.42755509343029 -0.903989293123442 1.4375,-1.38268343236509 -0.923879532511285 1.5,-1.33688985339222 -0.94154406518302 1.5625,-1.29028467725447 -0.956940335732208 1.625,-1.24298017990327 -0.970031253194543 1.6875,-1.19509032201613 -0.98078528040323 1.75,-1.14673047445537 -0.98917650996478 1.8125,-1.09801714032956 -0.995184726672197 1.875,-1.04906767432742 -0.998795456205172 1.9375,-1 -1 2,-0.950932325672585 -0.998795456205173 2.0625,-0.901982859670443 -0.995184726672197 2.125,-0.853269525544641 -0.989176509964781 2.1875,-0.804909677983875 -0.980785280403231 2.25,-0.757019820096739 -0.970031253194545 2.3125,-0.709715322745541 -0.95694033573221 2.375,-0.663110146607783 -0.941544065183022 2.4375,-0.617316567634913 -0.923879532511288 2.5,-0.57244490656972 -0.903989293123445 2.5625,-0.528603263174005 -0.881921264348356 2.625,-0.485897255806781 -0.857728610000273 2.6875,-0.4444297669804 -0.831469612302547 2.75,-0.404300695507569 -0.803207531480646 2.8125,-0.365606715836356 -0.773010453362739 2.875,-0.328441045152983 -0.740951125354961 2.9375,-0.292893218813454 -0.707106781186549 3,-0.259048874645043 -0.67155895484702 3.0625,-0.226989546637265 -0.634393284163647 3.125,-0.196792468519356 -0.595699304492435 3.1875,-0.168530387697456 -0.555570233019604 3.25,-0.142271389999729 -0.514102744193224 3.3125,-0.118078735651646 -0.471396736826 3.375,-0.0960107068765576 -0.427555093430284 3.4375,-0.0761204674887141 -0.382683432365092 3.5,-0.0584559348169799 -0.336889853392222 3.5625,-0.0430596642677918 -0.290284677254464 3.625,-0.0299687468054565 -0.242980179903266 3.6875,-0.01921471959677 -0.19509032201613 3.75,-0.0108234900352193 -0.146730474455364 3.8125,-0.00481527332780333 -0.0980171403295628 3.875,-0.00120454379482771 -0.0490676743274202 3.9375,0 0 4,0.0012045437948276 -0.049067674327418 4.0625,0.00481527332780309 -0.0980171403295604 4.125,0.010823490035219 -0.146730474455361 4.1875,0.0192147195967694 -0.195090322016128 4.25,0.0299687468054558 -0.242980179903263 4.3125,0.0430596642677909 -0.290284677254461 4.375,0.0584559348169789 -0.336889853392219 4.4375,0.0761204674887128 -0.382683432365089 4.5,0.0960107068765561 -0.427555093430281 4.5625,0.118078735651644 -0.471396736825996 4.625,0.142271389999727 -0.51410274419322 4.6875,0.168530387697454 -0.555570233019601 4.75,0.196792468519354 -0.595699304492432 4.8125,0.226989546637262 -0.634393284163644 4.875,0.259048874645039 -0.671558954847017 4.9375,0.292893218813451 -0.707106781186546 5,0.32844104515298 -0.740951125354957 5.0625,0.365606715836352 -0.773010453362735 5.125,0.404300695507564 -0.803207531480643 5.1875,0.444429766980395 -0.831469612302543 5.25,0.485897255806775 -0.85772861000027 5.3125,0.528603263173999 -0.881921264348353 5.375,0.572444906569714 -0.903989293123442 5.4375,0.617316567634907 -0.923879532511285 5.5,0.663110146607777 -0.94154406518302 5.5625,0.709715322745534 -0.956940335732208 5.625,0.757019820096733 -0.970031253194543 5.6875,0.804909677983868 -0.98078528040323 5.75,0.853269525544635 -0.98917650996478 5.8125,0.901982859670436 -0.995184726672197 5.875,0.950932325672579 -0.998795456205172 5.9375,0.999999999999997 -1 6,1.04906767432741 -0.998795456205173 6.0625,1.09801714032956 -0.995184726672197 6.125,1.14673047445536 -0.989176509964781 6.1875,1.19509032201613 -0.980785280403231 6.25,1.24298017990326 -0.970031253194545 6.3125,1.29028467725446 -0.95694033573221 6.375,1.33688985339222 -0.941544065183022 6.4375,1.38268343236509 -0.923879532511288 6.5,1.42755509343028 -0.903989293123445 6.5625,1.471396736826 -0.881921264348356 6.625,1.51410274419322 -0.857728610000273 6.6875,1.5555702330196 -0.831469612302547 6.75,1.59569930449243 -0.803207531480646 6.8125,1.63439328416364 -0.773010453362739 6.875,1.67155895484702 -0.740951125354961 6.9375,1.70710678118655 -0.707106781186549 7,1.74095112535496 -0.67155895484702 7.0625,1.77301045336274 -0.634393284163647 7.125,1.80320753148064 -0.595699304492435 7.1875,1.83146961230254 -0.555570233019604 7.25,1.85772861000027 -0.514102744193224 7.3125,1.88192126434835 -0.471396736826 7.375,1.90398929312344 -0.427555093430284 7.4375,1.92387953251129 -0.382683432365092 7.5,1.94154406518302 -0.336889853392222 7.5625,1.95694033573221 -0.290284677254464 7.625,1.97003125319454 -0.242980179903266 7.6875,1.98078528040323 -0.19509032201613 7.75,1.98917650996478 -0.146730474455364 7.8125,1.9951847266722 -0.0980171403295628 7.875,1.99879545620517 -0.0490676743274202 7.9375,2 0 8,1.99759091241034 0.098135348654836 7.875,1.99036945334439 0.196034280659121 7.75,1.97835301992956 0.293460948910723 7.625,1.96157056080646 0.390180644032256 7.5,1.94006250638909 0.485960359806528 7.375,1.91388067146442 0.580569354508925 7.25,1.88308813036604 0.67377970678444 7.125,1.84775906502257 0.76536686473018 7,1.80797858624689 0.855110186860564 6.875,1.76384252869671 0.942793473651995 6.75,1.71545722000054 1.02820548838644 6.625,1.66293922460509 1.1111404660392 6.5,1.60641506296129 1.19139860898487 6.375,1.54602090672547 1.26878656832729 6.25,1.48190225070992 1.34311790969404 6.125,1.41421356237309 1.4142135623731 6,1.34311790969404 1.48190225070992 5.875,1.26878656832729 1.54602090672547 5.75,1.19139860898487 1.60641506296129 5.625,1.1111404660392 1.66293922460509 5.5,1.02820548838644 1.71545722000054 5.375,0.942793473651994 1.76384252869671 5.25,0.855110186860563 1.80797858624689 5.125,0.765366864730178 1.84775906502257 5,0.673779706784439 1.88308813036604 4.875,0.580569354508923 1.91388067146442 4.75,0.485960359806526 1.94006250638909 4.625,0.390180644032255 1.96157056080646 4.5,0.293460948910722 1.97835301992956 4.375,0.196034280659119 1.99036945334439 4.25,0.098135348654834 1.99759091241034 4.125,-2.09798541386808e-15 2 4,-0.0981353486548382 1.99759091241034 3.875,-0.196034280659124 1.99036945334439 3.75,-0.293460948910726 1.97835301992956 3.625,-0.390180644032259 1.96157056080646 3.5,-0.48596035980653 1.94006250638909 3.375,-0.580569354508927 1.91388067146442 3.25,-0.673779706784443 1.88308813036604 3.125,-0.765366864730182 1.84775906502257 3,-0.855110186860567 1.80797858624689 2.875,-0.942793473651998 1.76384252869671 2.75,-1.02820548838645 1.71545722000054 2.625,-1.11114046603921 1.66293922460509 2.5,-1.19139860898487 1.60641506296129 2.375,-1.26878656832729 1.54602090672547 2.25,-1.34311790969404 1.48190225070992 2.125,-1.4142135623731 1.41421356237309 2,-1.48190225070992 1.34311790969404 1.875,-1.54602090672547 1.26878656832729 1.75,-1.60641506296129 1.19139860898487 1.625,-1.66293922460509 1.11114046603921 1.5,-1.71545722000054 1.02820548838644 1.375,-1.76384252869671 0.942793473651997 1.25,-1.80797858624689 0.855110186860566 1.125,-1.84775906502257 0.765366864730181 1,-1.88308813036604 0.673779706784442 0.875000000000003,-1.91388067146442 0.580569354508927 0.750000000000003,-1.94006250638909 0.485960359806531 0.625000000000004,-1.96157056080646 0.39018064403226 0.500000000000004,-1.97835301992956 0.293460948910727 0.375000000000004,-1.99036945334439 0.196034280659125 0.250000000000005,-1.99759091241034 0.0981353486548404 0.125000000000005,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
< ST_CurveToLine03|MULTIPOLYGON(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999,-1.9951847266722 -0.0980171403295604 0.0624999999999998,-1.98917650996478 -0.146730474455361 0.0937499999999997,-1.98078528040323 -0.195090322016128 0.125,-1.97003125319454 -0.242980179903263 0.156249999999999,-1.95694033573221 -0.290284677254461 0.187499999999999,-1.94154406518302 -0.336889853392219 0.218749999999999,-1.92387953251129 -0.382683432365089 0.249999999999999,-1.90398929312344 -0.427555093430281 0.281249999999999,-1.88192126434836 -0.471396736825996 0.312499999999999,-1.85772861000027 -0.51410274419322 0.343749999999999,-1.83146961230255 -0.555570233019601 0.374999999999999,-1.80320753148065 -0.595699304492432 0.406249999999999,-1.77301045336274 -0.634393284163644 0.437499999999999,-1.74095112535496 -0.671558954847017 0.468749999999998,-1.70710678118655 -0.707106781186546 0.499999999999998,-1.67155895484702 -0.740951125354957 0.531249999999998,-1.63439328416365 -0.773010453362735 0.562499999999998,-1.59569930449244 -0.803207531480643 0.593749999999998,-1.5555702330196 -0.831469612302543 0.624999999999998,-1.51410274419322 -0.85772861000027 0.656249999999998,-1.471396736826 -0.881921264348353 0.687499999999998,-1.42755509343029 -0.903989293123442 0.718749999999998,-1.38268343236509 -0.923879532511285 0.749999999999998,-1.33688985339222 -0.94154406518302 0.781249999999998,-1.29028467725447 -0.956940335732208 0.812499999999998,-1.24298017990327 -0.970031253194543 0.843749999999998,-1.19509032201613 -0.98078528040323 0.874999999999998,-1.14673047445537 -0.98917650996478 0.906249999999998,-1.09801714032956 -0.995184726672197 0.937499999999998,-1.04906767432742 -0.998795456205172 0.968749999999998,-1 -1 0.999999999999998,-0.950932325672585 -0.998795456205173 1.03125,-0.901982859670443 -0.995184726672197 1.0625,-0.853269525544641 -0.989176509964781 1.09375,-0.804909677983875 -0.980785280403231 1.125,-0.757019820096739 -0.970031253194545 1.15625,-0.709715322745541 -0.95694033573221 1.1875,-0.663110146607783 -0.941544065183022 1.21875,-0.617316567634913 -0.923879532511288 1.25,-0.57244490656972 -0.903989293123445 1.28125,-0.528603263174005 -0.881921264348356 1.3125,-0.485897255806781 -0.857728610000273 1.34375,-0.4444297669804 -0.831469612302547 1.375,-0.404300695507569 -0.803207531480646 1.40625,-0.365606715836356 -0.773010453362739 1.4375,-0.328441045152983 -0.740951125354961 1.46875,-0.292893218813454 -0.707106781186549 1.5,-0.259048874645043 -0.67155895484702 1.53125,-0.226989546637265 -0.634393284163647 1.5625,-0.196792468519356 -0.595699304492435 1.59375,-0.168530387697456 -0.555570233019604 1.625,-0.142271389999729 -0.514102744193224 1.65625,-0.118078735651646 -0.471396736826 1.6875,-0.0960107068765576 -0.427555093430284 1.71875,-0.0761204674887141 -0.382683432365092 1.75,-0.0584559348169799 -0.336889853392222 1.78125,-0.0430596642677918 -0.290284677254464 1.8125,-0.0299687468054565 -0.242980179903266 1.84375,-0.01921471959677 -0.19509032201613 1.875,-0.0108234900352193 -0.146730474455364 1.90625,-0.00481527332780333 -0.0980171403295628 1.9375,-0.00120454379482771 -0.0490676743274202 1.96875,0 0 2,0.0012045437948276 -0.049067674327418 2.03125,0.00481527332780309 -0.0980171403295604 2.0625,0.010823490035219 -0.146730474455361 2.09375,0.0192147195967694 -0.195090322016128 2.125,0.0299687468054558 -0.242980179903263 2.15625,0.0430596642677909 -0.290284677254461 2.1875,0.0584559348169789 -0.336889853392219 2.21875,0.0761204674887128 -0.382683432365089 2.25,0.0960107068765561 -0.427555093430281 2.28125,0.118078735651644 -0.471396736825996 2.3125,0.142271389999727 -0.51410274419322 2.34375,0.168530387697454 -0.555570233019601 2.375,0.196792468519354 -0.595699304492432 2.40625,0.226989546637262 -0.634393284163644 2.4375,0.259048874645039 -0.671558954847017 2.46875,0.292893218813451 -0.707106781186546 2.5,0.32844104515298 -0.740951125354957 2.53125,0.365606715836352 -0.773010453362735 2.5625,0.404300695507564 -0.803207531480643 2.59375,0.444429766980395 -0.831469612302543 2.625,0.485897255806775 -0.85772861000027 2.65625,0.528603263173999 -0.881921264348353 2.6875,0.572444906569714 -0.903989293123442 2.71875,0.617316567634907 -0.923879532511285 2.75,0.663110146607777 -0.94154406518302 2.78125,0.709715322745534 -0.956940335732208 2.8125,0.757019820096733 -0.970031253194543 2.84375,0.804909677983868 -0.98078528040323 2.875,0.853269525544635 -0.98917650996478 2.90625,0.901982859670436 -0.995184726672197 2.9375,0.950932325672579 -0.998795456205172 2.96875,0.999999999999997 -1 3,1.04906767432741 -0.998795456205173 3.03125,1.09801714032956 -0.995184726672197 3.0625,1.14673047445536 -0.989176509964781 3.09375,1.19509032201613 -0.980785280403231 3.125,1.24298017990326 -0.970031253194545 3.15625,1.29028467725446 -0.95694033573221 3.1875,1.33688985339222 -0.941544065183022 3.21875,1.38268343236509 -0.923879532511288 3.25,1.42755509343028 -0.903989293123445 3.28125,1.471396736826 -0.881921264348356 3.3125,1.51410274419322 -0.857728610000273 3.34375,1.5555702330196 -0.831469612302547 3.375,1.59569930449243 -0.803207531480646 3.40625,1.63439328416364 -0.773010453362739 3.4375,1.67155895484702 -0.740951125354961 3.46875,1.70710678118655 -0.707106781186549 3.5,1.74095112535496 -0.67155895484702 3.53125,1.77301045336274 -0.634393284163647 3.5625,1.80320753148064 -0.595699304492435 3.59375,1.83146961230254 -0.555570233019604 3.625,1.85772861000027 -0.514102744193224 3.65625,1.88192126434835 -0.471396736826 3.6875,1.90398929312344 -0.427555093430284 3.71875,1.92387953251129 -0.382683432365092 3.75,1.94154406518302 -0.336889853392222 3.78125,1.95694033573221 -0.290284677254464 3.8125,1.97003125319454 -0.242980179903266 3.84375,1.98078528040323 -0.19509032201613 3.875,1.98917650996478 -0.146730474455364 3.90625,1.9951847266722 -0.0980171403295628 3.9375,1.99879545620517 -0.0490676743274202 3.96875,2 0 4,1.99759091241034 0.098135348654836 3.9375,1.99036945334439 0.196034280659121 3.875,1.97835301992956 0.293460948910723 3.8125,1.96157056080646 0.390180644032256 3.75,1.94006250638909 0.485960359806528 3.6875,1.91388067146442 0.580569354508925 3.625,1.88308813036604 0.67377970678444 3.5625,1.84775906502257 0.76536686473018 3.5,1.80797858624689 0.855110186860564 3.4375,1.76384252869671 0.942793473651995 3.375,1.71545722000054 1.02820548838644 3.3125,1.66293922460509 1.1111404660392 3.25,1.60641506296129 1.19139860898487 3.1875,1.54602090672547 1.26878656832729 3.125,1.48190225070992 1.34311790969404 3.0625,1.41421356237309 1.4142135623731 3,1.34311790969404 1.48190225070992 2.9375,1.26878656832729 1.54602090672547 2.875,1.19139860898487 1.60641506296129 2.8125,1.1111404660392 1.66293922460509 2.75,1.02820548838644 1.71545722000054 2.6875,0.942793473651994 1.76384252869671 2.625,0.855110186860563 1.80797858624689 2.5625,0.765366864730178 1.84775906502257 2.5,0.673779706784439 1.88308813036604 2.4375,0.580569354508923 1.91388067146442 2.375,0.485960359806526 1.94006250638909 2.3125,0.390180644032255 1.96157056080646 2.25,0.293460948910722 1.97835301992956 2.1875,0.196034280659119 1.99036945334439 2.125,0.098135348654834 1.99759091241034 2.0625,-2.09798541386808e-15 2 2,-0.0981353486548382 1.99759091241034 1.9375,-0.196034280659124 1.99036945334439 1.875,-0.293460948910726 1.97835301992956 1.8125,-0.390180644032259 1.96157056080646 1.75,-0.48596035980653 1.94006250638909 1.6875,-0.580569354508927 1.91388067146442 1.625,-0.673779706784443 1.88308813036604 1.5625,-0.765366864730182 1.84775906502257 1.5,-0.855110186860567 1.80797858624689 1.4375,-0.942793473651998 1.76384252869671 1.375,-1.02820548838645 1.71545722000054 1.3125,-1.11114046603921 1.66293922460509 1.25,-1.19139860898487 1.60641506296129 1.1875,-1.26878656832729 1.54602090672547 1.125,-1.34311790969404 1.48190225070992 1.0625,-1.4142135623731 1.41421356237309 0.999999999999999,-1.48190225070992 1.34311790969404 0.9375,-1.54602090672547 1.26878656832729 0.875,-1.60641506296129 1.19139860898487 0.8125,-1.66293922460509 1.11114046603921 0.75,-1.71545722000054 1.02820548838644 0.6875,-1.76384252869671 0.942793473651997 0.625000000000001,-1.80797858624689 0.855110186860566 0.562500000000001,-1.84775906502257 0.765366864730181 0.500000000000001,-1.88308813036604 0.673779706784442 0.437500000000001,-1.91388067146442 0.580569354508927 0.375000000000002,-1.94006250638909 0.485960359806531 0.312500000000002,-1.96157056080646 0.39018064403226 0.250000000000002,-1.97835301992956 0.293460948910727 0.187500000000002,-1.99036945334439 0.196034280659125 0.125000000000002,-1.99759091241034 0.0981353486548404 0.0625000000000026,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
< ST_CurveToLine04|MULTIPOLYGON(((-2 0 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.0624999999999998 0.125,-1.98917650996478 -0.146730474455361 0.0937499999999997 0.187499999999999,-1.98078528040323 -0.195090322016128 0.125 0.249999999999999,-1.97003125319454 -0.242980179903263 0.156249999999999 0.312499999999999,-1.95694033573221 -0.290284677254461 0.187499999999999 0.374999999999999,-1.94154406518302 -0.336889853392219 0.218749999999999 0.437499999999999,-1.92387953251129 -0.382683432365089 0.249999999999999 0.499999999999998,-1.90398929312344 -0.427555093430281 0.281249999999999 0.562499999999998,-1.88192126434836 -0.471396736825996 0.312499999999999 0.624999999999998,-1.85772861000027 -0.51410274419322 0.343749999999999 0.687499999999998,-1.83146961230255 -0.555570233019601 0.374999999999999 0.749999999999997,-1.80320753148065 -0.595699304492432 0.406249999999999 0.812499999999997,-1.77301045336274 -0.634393284163644 0.437499999999999 0.874999999999997,-1.74095112535496 -0.671558954847017 0.468749999999998 0.937499999999997,-1.70710678118655 -0.707106781186546 0.499999999999998 0.999999999999997,-1.67155895484702 -0.740951125354957 0.531249999999998 1.0625,-1.63439328416365 -0.773010453362735 0.562499999999998 1.125,-1.59569930449244 -0.803207531480643 0.593749999999998 1.1875,-1.5555702330196 -0.831469612302543 0.624999999999998 1.25,-1.51410274419322 -0.85772861000027 0.656249999999998 1.3125,-1.471396736826 -0.881921264348353 0.687499999999998 1.375,-1.42755509343029 -0.903989293123442 0.718749999999998 1.4375,-1.38268343236509 -0.923879532511285 0.749999999999998 1.5,-1.33688985339222 -0.94154406518302 0.781249999999998 1.5625,-1.29028467725447 -0.956940335732208 0.812499999999998 1.625,-1.24298017990327 -0.970031253194543 0.843749999999998 1.6875,-1.19509032201613 -0.98078528040323 0.874999999999998 1.75,-1.14673047445537 -0.98917650996478 0.906249999999998 1.8125,-1.09801714032956 -0.995184726672197 0.937499999999998 1.875,-1.04906767432742 -0.998795456205172 0.968749999999998 1.9375,-1 -1 0.999999999999998 2,-0.950932325672585 -0.998795456205173 1.03125 2.0625,-0.901982859670443 -0.995184726672197 1.0625 2.125,-0.853269525544641 -0.989176509964781 1.09375 2.1875,-0.804909677983875 -0.980785280403231 1.125 2.25,-0.757019820096739 -0.970031253194545 1.15625 2.3125,-0.709715322745541 -0.95694033573221 1.1875 2.375,-0.663110146607783 -0.941544065183022 1.21875 2.4375,-0.617316567634913 -0.923879532511288 1.25 2.5,-0.57244490656972 -0.903989293123445 1.28125 2.5625,-0.528603263174005 -0.881921264348356 1.3125 2.625,-0.485897255806781 -0.857728610000273 1.34375 2.6875,-0.4444297669804 -0.831469612302547 1.375 2.75,-0.404300695507569 -0.803207531480646 1.40625 2.8125,-0.365606715836356 -0.773010453362739 1.4375 2.875,-0.328441045152983 -0.740951125354961 1.46875 2.9375,-0.292893218813454 -0.707106781186549 1.5 3,-0.259048874645043 -0.67155895484702 1.53125 3.0625,-0.226989546637265 -0.634393284163647 1.5625 3.125,-0.196792468519356 -0.595699304492435 1.59375 3.1875,-0.168530387697456 -0.555570233019604 1.625 3.25,-0.142271389999729 -0.514102744193224 1.65625 3.3125,-0.118078735651646 -0.471396736826 1.6875 3.375,-0.0960107068765576 -0.427555093430284 1.71875 3.4375,-0.0761204674887141 -0.382683432365092 1.75 3.5,-0.0584559348169799 -0.336889853392222 1.78125 3.5625,-0.0430596642677918 -0.290284677254464 1.8125 3.625,-0.0299687468054565 -0.242980179903266 1.84375 3.6875,-0.01921471959677 -0.19509032201613 1.875 3.75,-0.0108234900352193 -0.146730474455364 1.90625 3.8125,-0.00481527332780333 -0.0980171403295628 1.9375 3.875,-0.00120454379482771 -0.0490676743274202 1.96875 3.9375,0 0 2 4,0.0012045437948276 -0.049067674327418 2.03125 4.0625,0.00481527332780309 -0.0980171403295604 2.0625 4.125,0.010823490035219 -0.146730474455361 2.09375 4.1875,0.0192147195967694 -0.195090322016128 2.125 4.25,0.0299687468054558 -0.242980179903263 2.15625 4.3125,0.0430596642677909 -0.290284677254461 2.1875 4.375,0.0584559348169789 -0.336889853392219 2.21875 4.4375,0.0761204674887128 -0.382683432365089 2.25 4.5,0.0960107068765561 -0.427555093430281 2.28125 4.5625,0.118078735651644 -0.471396736825996 2.3125 4.625,0.142271389999727 -0.51410274419322 2.34375 4.6875,0.168530387697454 -0.555570233019601 2.375 4.75,0.196792468519354 -0.595699304492432 2.40625 4.8125,0.226989546637262 -0.634393284163644 2.4375 4.875,0.259048874645039 -0.671558954847017 2.46875 4.9375,0.292893218813451 -0.707106781186546 2.5 5,0.32844104515298 -0.740951125354957 2.53125 5.0625,0.365606715836352 -0.773010453362735 2.5625 5.125,0.404300695507564 -0.803207531480643 2.59375 5.1875,0.444429766980395 -0.831469612302543 2.625 5.25,0.485897255806775 -0.85772861000027 2.65625 5.3125,0.528603263173999 -0.881921264348353 2.6875 5.375,0.572444906569714 -0.903989293123442 2.71875 5.4375,0.617316567634907 -0.923879532511285 2.75 5.5,0.663110146607777 -0.94154406518302 2.78125 5.5625,0.709715322745534 -0.956940335732208 2.8125 5.625,0.757019820096733 -0.970031253194543 2.84375 5.6875,0.804909677983868 -0.98078528040323 2.875 5.75,0.853269525544635 -0.98917650996478 2.90625 5.8125,0.901982859670436 -0.995184726672197 2.9375 5.875,0.950932325672579 -0.998795456205172 2.96875 5.9375,0.999999999999997 -1 3 6,1.04906767432741 -0.998795456205173 3.03125 6.0625,1.09801714032956 -0.995184726672197 3.0625 6.125,1.14673047445536 -0.989176509964781 3.09375 6.1875,1.19509032201613 -0.980785280403231 3.125 6.25,1.24298017990326 -0.970031253194545 3.15625 6.3125,1.29028467725446 -0.95694033573221 3.1875 6.375,1.33688985339222 -0.941544065183022 3.21875 6.4375,1.38268343236509 -0.923879532511288 3.25 6.5,1.42755509343028 -0.903989293123445 3.28125 6.5625,1.471396736826 -0.881921264348356 3.3125 6.625,1.51410274419322 -0.857728610000273 3.34375 6.6875,1.5555702330196 -0.831469612302547 3.375 6.75,1.59569930449243 -0.803207531480646 3.40625 6.8125,1.63439328416364 -0.773010453362739 3.4375 6.875,1.67155895484702 -0.740951125354961 3.46875 6.9375,1.70710678118655 -0.707106781186549 3.5 7,1.74095112535496 -0.67155895484702 3.53125 7.0625,1.77301045336274 -0.634393284163647 3.5625 7.125,1.80320753148064 -0.595699304492435 3.59375 7.1875,1.83146961230254 -0.555570233019604 3.625 7.25,1.85772861000027 -0.514102744193224 3.65625 7.3125,1.88192126434835 -0.471396736826 3.6875 7.375,1.90398929312344 -0.427555093430284 3.71875 7.4375,1.92387953251129 -0.382683432365092 3.75 7.5,1.94154406518302 -0.336889853392222 3.78125 7.5625,1.95694033573221 -0.290284677254464 3.8125 7.625,1.97003125319454 -0.242980179903266 3.84375 7.6875,1.98078528040323 -0.19509032201613 3.875 7.75,1.98917650996478 -0.146730474455364 3.90625 7.8125,1.9951847266722 -0.0980171403295628 3.9375 7.875,1.99879545620517 -0.0490676743274202 3.96875 7.9375,2 0 4 8,1.99759091241034 0.098135348654836 3.9375 7.875,1.99036945334439 0.196034280659121 3.875 7.75,1.97835301992956 0.293460948910723 3.8125 7.625,1.96157056080646 0.390180644032256 3.75 7.5,1.94006250638909 0.485960359806528 3.6875 7.375,1.91388067146442 0.580569354508925 3.625 7.25,1.88308813036604 0.67377970678444 3.5625 7.125,1.84775906502257 0.76536686473018 3.5 7,1.80797858624689 0.855110186860564 3.4375 6.875,1.76384252869671 0.942793473651995 3.375 6.75,1.71545722000054 1.02820548838644 3.3125 6.625,1.66293922460509 1.1111404660392 3.25 6.5,1.60641506296129 1.19139860898487 3.1875 6.375,1.54602090672547 1.26878656832729 3.125 6.25,1.48190225070992 1.34311790969404 3.0625 6.125,1.41421356237309 1.4142135623731 3 6,1.34311790969404 1.48190225070992 2.9375 5.875,1.26878656832729 1.54602090672547 2.875 5.75,1.19139860898487 1.60641506296129 2.8125 5.625,1.1111404660392 1.66293922460509 2.75 5.5,1.02820548838644 1.71545722000054 2.6875 5.375,0.942793473651994 1.76384252869671 2.625 5.25,0.855110186860563 1.80797858624689 2.5625 5.125,0.765366864730178 1.84775906502257 2.5 5,0.673779706784439 1.88308813036604 2.4375 4.875,0.580569354508923 1.91388067146442 2.375 4.75,0.485960359806526 1.94006250638909 2.3125 4.625,0.390180644032255 1.96157056080646 2.25 4.5,0.293460948910722 1.97835301992956 2.1875 4.375,0.196034280659119 1.99036945334439 2.125 4.25,0.098135348654834 1.99759091241034 2.0625 4.125,-2.09798541386808e-15 2 2 4,-0.0981353486548382 1.99759091241034 1.9375 3.875,-0.196034280659124 1.99036945334439 1.875 3.75,-0.293460948910726 1.97835301992956 1.8125 3.625,-0.390180644032259 1.96157056080646 1.75 3.5,-0.48596035980653 1.94006250638909 1.6875 3.375,-0.580569354508927 1.91388067146442 1.625 3.25,-0.673779706784443 1.88308813036604 1.5625 3.125,-0.765366864730182 1.84775906502257 1.5 3,-0.855110186860567 1.80797858624689 1.4375 2.875,-0.942793473651998 1.76384252869671 1.375 2.75,-1.02820548838645 1.71545722000054 1.3125 2.625,-1.11114046603921 1.66293922460509 1.25 2.5,-1.19139860898487 1.60641506296129 1.1875 2.375,-1.26878656832729 1.54602090672547 1.125 2.25,-1.34311790969404 1.48190225070992 1.0625 2.125,-1.4142135623731 1.41421356237309 0.999999999999999 2,-1.48190225070992 1.34311790969404 0.9375 1.875,-1.54602090672547 1.26878656832729 0.875 1.75,-1.60641506296129 1.19139860898487 0.8125 1.625,-1.66293922460509 1.11114046603921 0.75 1.5,-1.71545722000054 1.02820548838644 0.6875 1.375,-1.76384252869671 0.942793473651997 0.625000000000001 1.25,-1.80797858624689 0.855110186860566 0.562500000000001 1.125,-1.84775906502257 0.765366864730181 0.500000000000001 1,-1.88308813036604 0.673779706784442 0.437500000000001 0.875000000000003,-1.91388067146442 0.580569354508927 0.375000000000002 0.750000000000003,-1.94006250638909 0.485960359806531 0.312500000000002 0.625000000000004,-1.96157056080646 0.39018064403226 0.250000000000002 0.500000000000004,-1.97835301992956 0.293460948910727 0.187500000000002 0.375000000000004,-1.99036945334439 0.196034280659125 0.125000000000002 0.250000000000005,-1.99759091241034 0.0981353486548404 0.0625000000000026 0.125000000000005,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
> ST_CurveToLine-401|MULTIPOLYGON(((-2 0,-1.92387953251129 -0.38268343236509,-1.70710678118655 -0.707106781186548,-1.38268343236509 -0.923879532511287,-1 -1,-0.61731656763491 -0.923879532511287,-0.292893218813452 -0.707106781186547,-0.0761204674887133 -0.38268343236509,0 0,0.0761204674887133 -0.38268343236509,0.292893218813453 -0.707106781186548,0.61731656763491 -0.923879532511287,1 -1,1.38268343236509 -0.923879532511287,1.70710678118655 -0.707106781186547,1.92387953251129 -0.38268343236509,2 0,1.84775906502257 0.76536686473018,1.4142135623731 1.41421356237309,0.76536686473018 1.84775906502257,1.22460635382238e-16 2,-0.765366864730179 1.84775906502257,-1.41421356237309 1.4142135623731,-1.84775906502257 0.76536686473018,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
> ST_CurveToLine-402|MULTIPOLYGONM(((-2 0 0,-1.92387953251129 -0.38268343236509 0.5,-1.70710678118655 -0.707106781186548 1,-1.38268343236509 -0.923879532511287 1.5,-1 -1 2,-0.61731656763491 -0.923879532511287 2.5,-0.292893218813452 -0.707106781186547 3,-0.0761204674887133 -0.38268343236509 3.5,0 0 4,0.0761204674887133 -0.38268343236509 4.5,0.292893218813453 -0.707106781186548 5,0.61731656763491 -0.923879532511287 5.5,1 -1 6,1.38268343236509 -0.923879532511287 6.5,1.70710678118655 -0.707106781186547 7,1.92387953251129 -0.38268343236509 7.5,2 0 8,1.84775906502257 0.76536686473018 7,1.4142135623731 1.41421356237309 6,0.76536686473018 1.84775906502257 5,1.22460635382238e-16 2 4,-0.765366864730179 1.84775906502257 3,-1.41421356237309 1.4142135623731 2,-1.84775906502257 0.76536686473018 1,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
> ST_CurveToLine-403|MULTIPOLYGON(((-2 0 0,-1.92387953251129 -0.38268343236509 0.25,-1.70710678118655 -0.707106781186548 0.5,-1.38268343236509 -0.923879532511287 0.75,-1 -1 1,-0.61731656763491 -0.923879532511287 1.25,-0.292893218813452 -0.707106781186547 1.5,-0.0761204674887133 -0.38268343236509 1.75,0 0 2,0.0761204674887133 -0.38268343236509 2.25,0.292893218813453 -0.707106781186548 2.5,0.61731656763491 -0.923879532511287 2.75,1 -1 3,1.38268343236509 -0.923879532511287 3.25,1.70710678118655 -0.707106781186547 3.5,1.92387953251129 -0.38268343236509 3.75,2 0 4,1.84775906502257 0.76536686473018 3.5,1.4142135623731 1.41421356237309 3,0.76536686473018 1.84775906502257 2.5,1.22460635382238e-16 2 2,-0.765366864730179 1.84775906502257 1.5,-1.41421356237309 1.4142135623731 1,-1.84775906502257 0.76536686473018 0.5,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
> ST_CurveToLine-404|MULTIPOLYGON(((-2 0 0 0,-1.92387953251129 -0.38268343236509 0.25 0.5,-1.70710678118655 -0.707106781186548 0.5 1,-1.38268343236509 -0.923879532511287 0.75 1.5,-1 -1 1 2,-0.61731656763491 -0.923879532511287 1.25 2.5,-0.292893218813452 -0.707106781186547 1.5 3,-0.0761204674887133 -0.38268343236509 1.75 3.5,0 0 2 4,0.0761204674887133 -0.38268343236509 2.25 4.5,0.292893218813453 -0.707106781186548 2.5 5,0.61731656763491 -0.923879532511287 2.75 5.5,1 -1 3 6,1.38268343236509 -0.923879532511287 3.25 6.5,1.70710678118655 -0.707106781186547 3.5 7,1.92387953251129 -0.38268343236509 3.75 7.5,2 0 4 8,1.84775906502257 0.76536686473018 3.5 7,1.4142135623731 1.41421356237309 3 6,0.76536686473018 1.84775906502257 2.5 5,1.22460635382238e-16 2 2 4,-0.765366864730179 1.84775906502257 1.5 3,-1.41421356237309 1.4142135623731 1 2,-1.84775906502257 0.76536686473018 0.5 1,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
> ST_CurveToLine01|MULTIPOLYGON(((-2 0,-1.99879545620517 -0.049067674327418,-1.9951847266722 -0.0980171403295604,-1.98917650996478 -0.146730474455361,-1.98078528040323 -0.195090322016128,-1.97003125319454 -0.242980179903263,-1.95694033573221 -0.290284677254462,-1.94154406518302 -0.336889853392219,-1.92387953251129 -0.382683432365089,-1.90398929312344 -0.427555093430281,-1.88192126434836 -0.471396736825996,-1.85772861000027 -0.51410274419322,-1.83146961230255 -0.555570233019601,-1.80320753148065 -0.595699304492432,-1.77301045336274 -0.634393284163644,-1.74095112535496 -0.671558954847017,-1.70710678118655 -0.707106781186546,-1.67155895484702 -0.740951125354957,-1.63439328416365 -0.773010453362735,-1.59569930449244 -0.803207531480643,-1.5555702330196 -0.831469612302543,-1.51410274419322 -0.85772861000027,-1.471396736826 -0.881921264348353,-1.42755509343029 -0.903989293123442,-1.38268343236509 -0.923879532511285,-1.33688985339222 -0.94154406518302,-1.29028467725447 -0.956940335732208,-1.24298017990327 -0.970031253194543,-1.19509032201613 -0.98078528040323,-1.14673047445537 -0.98917650996478,-1.09801714032956 -0.995184726672197,-1.04906767432742 -0.998795456205172,-1 -1,-0.950932325672585 -0.998795456205173,-0.901982859670443 -0.995184726672197,-0.853269525544641 -0.989176509964781,-0.804909677983875 -0.980785280403231,-0.757019820096739 -0.970031253194545,-0.70971532274554 -0.95694033573221,-0.663110146607783 -0.941544065183022,-0.617316567634913 -0.923879532511288,-0.57244490656972 -0.903989293123445,-0.528603263174005 -0.881921264348356,-0.485897255806781 -0.857728610000273,-0.4444297669804 -0.831469612302547,-0.404300695507569 -0.803207531480647,-0.365606715836356 -0.773010453362739,-0.328441045152983 -0.740951125354961,-0.292893218813454 -0.707106781186549,-0.259048874645042 -0.67155895484702,-0.226989546637264 -0.634393284163647,-0.196792468519356 -0.595699304492435,-0.168530387697456 -0.555570233019604,-0.142271389999729 -0.514102744193224,-0.118078735651646 -0.471396736826,-0.0960107068765576 -0.427555093430284,-0.076120467488714 -0.382683432365092,-0.05845593481698 -0.336889853392222,-0.0430596642677917 -0.290284677254464,-0.0299687468054566 -0.242980179903266,-0.01921471959677 -0.19509032201613,-0.0108234900352193 -0.146730474455364,-0.00481527332780329 -0.0980171403295628,-0.00120454379482771 -0.0490676743274202,0 0,0.0012045437948276 -0.049067674327418,0.00481527332780307 -0.0980171403295604,0.010823490035219 -0.146730474455361,0.0192147195967695 -0.195090322016128,0.0299687468054558 -0.242980179903263,0.0430596642677908 -0.290284677254462,0.0584559348169789 -0.336889853392219,0.0761204674887128 -0.382683432365089,0.0960107068765561 -0.427555093430281,0.118078735651644 -0.471396736825996,0.142271389999727 -0.51410274419322,0.168530387697454 -0.555570233019601,0.196792468519354 -0.595699304492432,0.226989546637262 -0.634393284163644,0.259048874645039 -0.671558954847017,0.292893218813451 -0.707106781186546,0.32844104515298 -0.740951125354957,0.365606715836352 -0.773010453362735,0.404300695507564 -0.803207531480643,0.444429766980395 -0.831469612302543,0.485897255806775 -0.85772861000027,0.528603263173999 -0.881921264348353,0.572444906569715 -0.903989293123442,0.617316567634907 -0.923879532511285,0.663110146607776 -0.94154406518302,0.709715322745534 -0.956940335732208,0.757019820096733 -0.970031253194543,0.804909677983868 -0.98078528040323,0.853269525544635 -0.98917650996478,0.901982859670436 -0.995184726672197,0.950932325672579 -0.998795456205172,0.999999999999997 -1,1.04906767432741 -0.998795456205173,1.09801714032956 -0.995184726672197,1.14673047445536 -0.989176509964781,1.19509032201613 -0.980785280403231,1.24298017990326 -0.970031253194545,1.29028467725446 -0.95694033573221,1.33688985339222 -0.941544065183022,1.38268343236509 -0.923879532511288,1.42755509343028 -0.903989293123445,1.471396736826 -0.881921264348356,1.51410274419322 -0.857728610000273,1.5555702330196 -0.831469612302547,1.59569930449243 -0.803207531480647,1.63439328416364 -0.773010453362739,1.67155895484702 -0.740951125354961,1.70710678118655 -0.707106781186549,1.74095112535496 -0.67155895484702,1.77301045336274 -0.634393284163647,1.80320753148064 -0.595699304492435,1.83146961230254 -0.555570233019604,1.85772861000027 -0.514102744193224,1.88192126434835 -0.471396736826,1.90398929312344 -0.427555093430284,1.92387953251129 -0.382683432365092,1.94154406518302 -0.336889853392222,1.95694033573221 -0.290284677254464,1.97003125319454 -0.242980179903266,1.98078528040323 -0.19509032201613,1.98917650996478 -0.146730474455364,1.9951847266722 -0.0980171403295628,1.99879545620517 -0.0490676743274202,2 0,1.99759091241034 0.098135348654836,1.99036945334439 0.196034280659121,1.97835301992956 0.293460948910724,1.96157056080646 0.390180644032257,1.94006250638909 0.485960359806528,1.91388067146442 0.580569354508925,1.88308813036604 0.67377970678444,1.84775906502257 0.76536686473018,1.80797858624689 0.855110186860564,1.76384252869671 0.942793473651995,1.71545722000054 1.02820548838644,1.66293922460509 1.1111404660392,1.60641506296129 1.19139860898487,1.54602090672547 1.26878656832729,1.48190225070992 1.34311790969404,1.41421356237309 1.4142135623731,1.34311790969404 1.48190225070992,1.26878656832729 1.54602090672547,1.19139860898487 1.60641506296129,1.1111404660392 1.66293922460509,1.02820548838644 1.71545722000054,0.942793473651994 1.76384252869671,0.855110186860563 1.80797858624689,0.765366864730178 1.84775906502257,0.673779706784439 1.88308813036604,0.580569354508923 1.91388067146442,0.485960359806526 1.94006250638909,0.390180644032255 1.96157056080646,0.293460948910722 1.97835301992956,0.196034280659119 1.99036945334439,0.098135348654834 1.99759091241034,-2.09798541386808e-15 2,-0.0981353486548382 1.99759091241034,-0.196034280659124 1.99036945334439,-0.293460948910726 1.97835301992956,-0.390180644032259 1.96157056080646,-0.48596035980653 1.94006250638909,-0.580569354508927 1.91388067146442,-0.673779706784443 1.88308813036604,-0.765366864730182 1.84775906502257,-0.855110186860567 1.80797858624689,-0.942793473651998 1.76384252869671,-1.02820548838645 1.71545722000054,-1.11114046603921 1.66293922460509,-1.19139860898487 1.60641506296129,-1.26878656832729 1.54602090672547,-1.34311790969404 1.48190225070992,-1.4142135623731 1.41421356237309,-1.48190225070992 1.34311790969404,-1.54602090672547 1.26878656832729,-1.60641506296129 1.19139860898487,-1.66293922460509 1.11114046603921,-1.71545722000054 1.02820548838644,-1.76384252869671 0.942793473651997,-1.80797858624689 0.855110186860566,-1.84775906502257 0.765366864730181,-1.88308813036604 0.673779706784442,-1.91388067146442 0.580569354508927,-1.94006250638909 0.485960359806531,-1.96157056080646 0.39018064403226,-1.97835301992956 0.293460948910727,-1.99036945334439 0.196034280659125,-1.99759091241034 0.0981353486548404,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
> ST_CurveToLine02|MULTIPOLYGONM(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.125,-1.98917650996478 -0.146730474455361 0.187499999999999,-1.98078528040323 -0.195090322016128 0.249999999999999,-1.97003125319454 -0.242980179903263 0.312499999999999,-1.95694033573221 -0.290284677254462 0.374999999999999,-1.94154406518302 -0.336889853392219 0.437499999999999,-1.92387953251129 -0.382683432365089 0.499999999999998,-1.90398929312344 -0.427555093430281 0.562499999999998,-1.88192126434836 -0.471396736825996 0.624999999999998,-1.85772861000027 -0.51410274419322 0.687499999999998,-1.83146961230255 -0.555570233019601 0.749999999999997,-1.80320753148065 -0.595699304492432 0.812499999999997,-1.77301045336274 -0.634393284163644 0.874999999999997,-1.74095112535496 -0.671558954847017 0.937499999999997,-1.70710678118655 -0.707106781186546 0.999999999999997,-1.67155895484702 -0.740951125354957 1.0625,-1.63439328416365 -0.773010453362735 1.125,-1.59569930449244 -0.803207531480643 1.1875,-1.5555702330196 -0.831469612302543 1.25,-1.51410274419322 -0.85772861000027 1.3125,-1.471396736826 -0.881921264348353 1.375,-1.42755509343029 -0.903989293123442 1.4375,-1.38268343236509 -0.923879532511285 1.5,-1.33688985339222 -0.94154406518302 1.5625,-1.29028467725447 -0.956940335732208 1.625,-1.24298017990327 -0.970031253194543 1.6875,-1.19509032201613 -0.98078528040323 1.75,-1.14673047445537 -0.98917650996478 1.8125,-1.09801714032956 -0.995184726672197 1.875,-1.04906767432742 -0.998795456205172 1.9375,-1 -1 2,-0.950932325672585 -0.998795456205173 2.0625,-0.901982859670443 -0.995184726672197 2.125,-0.853269525544641 -0.989176509964781 2.1875,-0.804909677983875 -0.980785280403231 2.25,-0.757019820096739 -0.970031253194545 2.3125,-0.70971532274554 -0.95694033573221 2.375,-0.663110146607783 -0.941544065183022 2.4375,-0.617316567634913 -0.923879532511288 2.5,-0.57244490656972 -0.903989293123445 2.5625,-0.528603263174005 -0.881921264348356 2.625,-0.485897255806781 -0.857728610000273 2.6875,-0.4444297669804 -0.831469612302547 2.75,-0.404300695507569 -0.803207531480647 2.8125,-0.365606715836356 -0.773010453362739 2.875,-0.328441045152983 -0.740951125354961 2.9375,-0.292893218813454 -0.707106781186549 3,-0.259048874645042 -0.67155895484702 3.0625,-0.226989546637264 -0.634393284163647 3.125,-0.196792468519356 -0.595699304492435 3.1875,-0.168530387697456 -0.555570233019604 3.25,-0.142271389999729 -0.514102744193224 3.3125,-0.118078735651646 -0.471396736826 3.375,-0.0960107068765576 -0.427555093430284 3.4375,-0.076120467488714 -0.382683432365092 3.5,-0.05845593481698 -0.336889853392222 3.5625,-0.0430596642677917 -0.290284677254464 3.625,-0.0299687468054566 -0.242980179903266 3.6875,-0.01921471959677 -0.19509032201613 3.75,-0.0108234900352193 -0.146730474455364 3.8125,-0.00481527332780329 -0.0980171403295628 3.875,-0.00120454379482771 -0.0490676743274202 3.9375,0 0 4,0.0012045437948276 -0.049067674327418 4.0625,0.00481527332780307 -0.0980171403295604 4.125,0.010823490035219 -0.146730474455361 4.1875,0.0192147195967695 -0.195090322016128 4.25,0.0299687468054558 -0.242980179903263 4.3125,0.0430596642677908 -0.290284677254462 4.375,0.0584559348169789 -0.336889853392219 4.4375,0.0761204674887128 -0.382683432365089 4.5,0.0960107068765561 -0.427555093430281 4.5625,0.118078735651644 -0.471396736825996 4.625,0.142271389999727 -0.51410274419322 4.6875,0.168530387697454 -0.555570233019601 4.75,0.196792468519354 -0.595699304492432 4.8125,0.226989546637262 -0.634393284163644 4.875,0.259048874645039 -0.671558954847017 4.9375,0.292893218813451 -0.707106781186546 5,0.32844104515298 -0.740951125354957 5.0625,0.365606715836352 -0.773010453362735 5.125,0.404300695507564 -0.803207531480643 5.1875,0.444429766980395 -0.831469612302543 5.25,0.485897255806775 -0.85772861000027 5.3125,0.528603263173999 -0.881921264348353 5.375,0.572444906569715 -0.903989293123442 5.4375,0.617316567634907 -0.923879532511285 5.5,0.663110146607776 -0.94154406518302 5.5625,0.709715322745534 -0.956940335732208 5.625,0.757019820096733 -0.970031253194543 5.6875,0.804909677983868 -0.98078528040323 5.75,0.853269525544635 -0.98917650996478 5.8125,0.901982859670436 -0.995184726672197 5.875,0.950932325672579 -0.998795456205172 5.9375,0.999999999999997 -1 6,1.04906767432741 -0.998795456205173 6.0625,1.09801714032956 -0.995184726672197 6.125,1.14673047445536 -0.989176509964781 6.1875,1.19509032201613 -0.980785280403231 6.25,1.24298017990326 -0.970031253194545 6.3125,1.29028467725446 -0.95694033573221 6.375,1.33688985339222 -0.941544065183022 6.4375,1.38268343236509 -0.923879532511288 6.5,1.42755509343028 -0.903989293123445 6.5625,1.471396736826 -0.881921264348356 6.625,1.51410274419322 -0.857728610000273 6.6875,1.5555702330196 -0.831469612302547 6.75,1.59569930449243 -0.803207531480647 6.8125,1.63439328416364 -0.773010453362739 6.875,1.67155895484702 -0.740951125354961 6.9375,1.70710678118655 -0.707106781186549 7,1.74095112535496 -0.67155895484702 7.0625,1.77301045336274 -0.634393284163647 7.125,1.80320753148064 -0.595699304492435 7.1875,1.83146961230254 -0.555570233019604 7.25,1.85772861000027 -0.514102744193224 7.3125,1.88192126434835 -0.471396736826 7.375,1.90398929312344 -0.427555093430284 7.4375,1.92387953251129 -0.382683432365092 7.5,1.94154406518302 -0.336889853392222 7.5625,1.95694033573221 -0.290284677254464 7.625,1.97003125319454 -0.242980179903266 7.6875,1.98078528040323 -0.19509032201613 7.75,1.98917650996478 -0.146730474455364 7.8125,1.9951847266722 -0.0980171403295628 7.875,1.99879545620517 -0.0490676743274202 7.9375,2 0 8,1.99759091241034 0.098135348654836 7.875,1.99036945334439 0.196034280659121 7.75,1.97835301992956 0.293460948910724 7.625,1.96157056080646 0.390180644032257 7.5,1.94006250638909 0.485960359806528 7.375,1.91388067146442 0.580569354508925 7.25,1.88308813036604 0.67377970678444 7.125,1.84775906502257 0.76536686473018 7,1.80797858624689 0.855110186860564 6.875,1.76384252869671 0.942793473651995 6.75,1.71545722000054 1.02820548838644 6.625,1.66293922460509 1.1111404660392 6.5,1.60641506296129 1.19139860898487 6.375,1.54602090672547 1.26878656832729 6.25,1.48190225070992 1.34311790969404 6.125,1.41421356237309 1.4142135623731 6,1.34311790969404 1.48190225070992 5.875,1.26878656832729 1.54602090672547 5.75,1.19139860898487 1.60641506296129 5.625,1.1111404660392 1.66293922460509 5.5,1.02820548838644 1.71545722000054 5.375,0.942793473651994 1.76384252869671 5.25,0.855110186860563 1.80797858624689 5.125,0.765366864730178 1.84775906502257 5,0.673779706784439 1.88308813036604 4.875,0.580569354508923 1.91388067146442 4.75,0.485960359806526 1.94006250638909 4.625,0.390180644032255 1.96157056080646 4.5,0.293460948910722 1.97835301992956 4.375,0.196034280659119 1.99036945334439 4.25,0.098135348654834 1.99759091241034 4.125,-2.09798541386808e-15 2 4,-0.0981353486548382 1.99759091241034 3.875,-0.196034280659124 1.99036945334439 3.75,-0.293460948910726 1.97835301992956 3.625,-0.390180644032259 1.96157056080646 3.5,-0.48596035980653 1.94006250638909 3.375,-0.580569354508927 1.91388067146442 3.25,-0.673779706784443 1.88308813036604 3.125,-0.765366864730182 1.84775906502257 3,-0.855110186860567 1.80797858624689 2.875,-0.942793473651998 1.76384252869671 2.75,-1.02820548838645 1.71545722000054 2.625,-1.11114046603921 1.66293922460509 2.5,-1.19139860898487 1.60641506296129 2.375,-1.26878656832729 1.54602090672547 2.25,-1.34311790969404 1.48190225070992 2.125,-1.4142135623731 1.41421356237309 2,-1.48190225070992 1.34311790969404 1.875,-1.54602090672547 1.26878656832729 1.75,-1.60641506296129 1.19139860898487 1.625,-1.66293922460509 1.11114046603921 1.5,-1.71545722000054 1.02820548838644 1.375,-1.76384252869671 0.942793473651997 1.25,-1.80797858624689 0.855110186860566 1.125,-1.84775906502257 0.765366864730181 1,-1.88308813036604 0.673779706784442 0.875000000000003,-1.91388067146442 0.580569354508927 0.750000000000003,-1.94006250638909 0.485960359806531 0.625000000000004,-1.96157056080646 0.39018064403226 0.500000000000004,-1.97835301992956 0.293460948910727 0.375000000000004,-1.99036945334439 0.196034280659125 0.250000000000005,-1.99759091241034 0.0981353486548404 0.125000000000005,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
> ST_CurveToLine03|MULTIPOLYGON(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999,-1.9951847266722 -0.0980171403295604 0.0624999999999998,-1.98917650996478 -0.146730474455361 0.0937499999999997,-1.98078528040323 -0.195090322016128 0.125,-1.97003125319454 -0.242980179903263 0.156249999999999,-1.95694033573221 -0.290284677254462 0.187499999999999,-1.94154406518302 -0.336889853392219 0.218749999999999,-1.92387953251129 -0.382683432365089 0.249999999999999,-1.90398929312344 -0.427555093430281 0.281249999999999,-1.88192126434836 -0.471396736825996 0.312499999999999,-1.85772861000027 -0.51410274419322 0.343749999999999,-1.83146961230255 -0.555570233019601 0.374999999999999,-1.80320753148065 -0.595699304492432 0.406249999999999,-1.77301045336274 -0.634393284163644 0.437499999999999,-1.74095112535496 -0.671558954847017 0.468749999999998,-1.70710678118655 -0.707106781186546 0.499999999999998,-1.67155895484702 -0.740951125354957 0.531249999999998,-1.63439328416365 -0.773010453362735 0.562499999999998,-1.59569930449244 -0.803207531480643 0.593749999999998,-1.5555702330196 -0.831469612302543 0.624999999999998,-1.51410274419322 -0.85772861000027 0.656249999999998,-1.471396736826 -0.881921264348353 0.687499999999998,-1.42755509343029 -0.903989293123442 0.718749999999998,-1.38268343236509 -0.923879532511285 0.749999999999998,-1.33688985339222 -0.94154406518302 0.781249999999998,-1.29028467725447 -0.956940335732208 0.812499999999998,-1.24298017990327 -0.970031253194543 0.843749999999998,-1.19509032201613 -0.98078528040323 0.874999999999998,-1.14673047445537 -0.98917650996478 0.906249999999998,-1.09801714032956 -0.995184726672197 0.937499999999998,-1.04906767432742 -0.998795456205172 0.968749999999998,-1 -1 0.999999999999998,-0.950932325672585 -0.998795456205173 1.03125,-0.901982859670443 -0.995184726672197 1.0625,-0.853269525544641 -0.989176509964781 1.09375,-0.804909677983875 -0.980785280403231 1.125,-0.757019820096739 -0.970031253194545 1.15625,-0.70971532274554 -0.95694033573221 1.1875,-0.663110146607783 -0.941544065183022 1.21875,-0.617316567634913 -0.923879532511288 1.25,-0.57244490656972 -0.903989293123445 1.28125,-0.528603263174005 -0.881921264348356 1.3125,-0.485897255806781 -0.857728610000273 1.34375,-0.4444297669804 -0.831469612302547 1.375,-0.404300695507569 -0.803207531480647 1.40625,-0.365606715836356 -0.773010453362739 1.4375,-0.328441045152983 -0.740951125354961 1.46875,-0.292893218813454 -0.707106781186549 1.5,-0.259048874645042 -0.67155895484702 1.53125,-0.226989546637264 -0.634393284163647 1.5625,-0.196792468519356 -0.595699304492435 1.59375,-0.168530387697456 -0.555570233019604 1.625,-0.142271389999729 -0.514102744193224 1.65625,-0.118078735651646 -0.471396736826 1.6875,-0.0960107068765576 -0.427555093430284 1.71875,-0.076120467488714 -0.382683432365092 1.75,-0.05845593481698 -0.336889853392222 1.78125,-0.0430596642677917 -0.290284677254464 1.8125,-0.0299687468054566 -0.242980179903266 1.84375,-0.01921471959677 -0.19509032201613 1.875,-0.0108234900352193 -0.146730474455364 1.90625,-0.00481527332780329 -0.0980171403295628 1.9375,-0.00120454379482771 -0.0490676743274202 1.96875,0 0 2,0.0012045437948276 -0.049067674327418 2.03125,0.00481527332780307 -0.0980171403295604 2.0625,0.010823490035219 -0.146730474455361 2.09375,0.0192147195967695 -0.195090322016128 2.125,0.0299687468054558 -0.242980179903263 2.15625,0.0430596642677908 -0.290284677254462 2.1875,0.0584559348169789 -0.336889853392219 2.21875,0.0761204674887128 -0.382683432365089 2.25,0.0960107068765561 -0.427555093430281 2.28125,0.118078735651644 -0.471396736825996 2.3125,0.142271389999727 -0.51410274419322 2.34375,0.168530387697454 -0.555570233019601 2.375,0.196792468519354 -0.595699304492432 2.40625,0.226989546637262 -0.634393284163644 2.4375,0.259048874645039 -0.671558954847017 2.46875,0.292893218813451 -0.707106781186546 2.5,0.32844104515298 -0.740951125354957 2.53125,0.365606715836352 -0.773010453362735 2.5625,0.404300695507564 -0.803207531480643 2.59375,0.444429766980395 -0.831469612302543 2.625,0.485897255806775 -0.85772861000027 2.65625,0.528603263173999 -0.881921264348353 2.6875,0.572444906569715 -0.903989293123442 2.71875,0.617316567634907 -0.923879532511285 2.75,0.663110146607776 -0.94154406518302 2.78125,0.709715322745534 -0.956940335732208 2.8125,0.757019820096733 -0.970031253194543 2.84375,0.804909677983868 -0.98078528040323 2.875,0.853269525544635 -0.98917650996478 2.90625,0.901982859670436 -0.995184726672197 2.9375,0.950932325672579 -0.998795456205172 2.96875,0.999999999999997 -1 3,1.04906767432741 -0.998795456205173 3.03125,1.09801714032956 -0.995184726672197 3.0625,1.14673047445536 -0.989176509964781 3.09375,1.19509032201613 -0.980785280403231 3.125,1.24298017990326 -0.970031253194545 3.15625,1.29028467725446 -0.95694033573221 3.1875,1.33688985339222 -0.941544065183022 3.21875,1.38268343236509 -0.923879532511288 3.25,1.42755509343028 -0.903989293123445 3.28125,1.471396736826 -0.881921264348356 3.3125,1.51410274419322 -0.857728610000273 3.34375,1.5555702330196 -0.831469612302547 3.375,1.59569930449243 -0.803207531480647 3.40625,1.63439328416364 -0.773010453362739 3.4375,1.67155895484702 -0.740951125354961 3.46875,1.70710678118655 -0.707106781186549 3.5,1.74095112535496 -0.67155895484702 3.53125,1.77301045336274 -0.634393284163647 3.5625,1.80320753148064 -0.595699304492435 3.59375,1.83146961230254 -0.555570233019604 3.625,1.85772861000027 -0.514102744193224 3.65625,1.88192126434835 -0.471396736826 3.6875,1.90398929312344 -0.427555093430284 3.71875,1.92387953251129 -0.382683432365092 3.75,1.94154406518302 -0.336889853392222 3.78125,1.95694033573221 -0.290284677254464 3.8125,1.97003125319454 -0.242980179903266 3.84375,1.98078528040323 -0.19509032201613 3.875,1.98917650996478 -0.146730474455364 3.90625,1.9951847266722 -0.0980171403295628 3.9375,1.99879545620517 -0.0490676743274202 3.96875,2 0 4,1.99759091241034 0.098135348654836 3.9375,1.99036945334439 0.196034280659121 3.875,1.97835301992956 0.293460948910724 3.8125,1.96157056080646 0.390180644032257 3.75,1.94006250638909 0.485960359806528 3.6875,1.91388067146442 0.580569354508925 3.625,1.88308813036604 0.67377970678444 3.5625,1.84775906502257 0.76536686473018 3.5,1.80797858624689 0.855110186860564 3.4375,1.76384252869671 0.942793473651995 3.375,1.71545722000054 1.02820548838644 3.3125,1.66293922460509 1.1111404660392 3.25,1.60641506296129 1.19139860898487 3.1875,1.54602090672547 1.26878656832729 3.125,1.48190225070992 1.34311790969404 3.0625,1.41421356237309 1.4142135623731 3,1.34311790969404 1.48190225070992 2.9375,1.26878656832729 1.54602090672547 2.875,1.19139860898487 1.60641506296129 2.8125,1.1111404660392 1.66293922460509 2.75,1.02820548838644 1.71545722000054 2.6875,0.942793473651994 1.76384252869671 2.625,0.855110186860563 1.80797858624689 2.5625,0.765366864730178 1.84775906502257 2.5,0.673779706784439 1.88308813036604 2.4375,0.580569354508923 1.91388067146442 2.375,0.485960359806526 1.94006250638909 2.3125,0.390180644032255 1.96157056080646 2.25,0.293460948910722 1.97835301992956 2.1875,0.196034280659119 1.99036945334439 2.125,0.098135348654834 1.99759091241034 2.0625,-2.09798541386808e-15 2 2,-0.0981353486548382 1.99759091241034 1.9375,-0.196034280659124 1.99036945334439 1.875,-0.293460948910726 1.97835301992956 1.8125,-0.390180644032259 1.96157056080646 1.75,-0.48596035980653 1.94006250638909 1.6875,-0.580569354508927 1.91388067146442 1.625,-0.673779706784443 1.88308813036604 1.5625,-0.765366864730182 1.84775906502257 1.5,-0.855110186860567 1.80797858624689 1.4375,-0.942793473651998 1.76384252869671 1.375,-1.02820548838645 1.71545722000054 1.3125,-1.11114046603921 1.66293922460509 1.25,-1.19139860898487 1.60641506296129 1.1875,-1.26878656832729 1.54602090672547 1.125,-1.34311790969404 1.48190225070992 1.0625,-1.4142135623731 1.41421356237309 0.999999999999999,-1.48190225070992 1.34311790969404 0.9375,-1.54602090672547 1.26878656832729 0.875,-1.60641506296129 1.19139860898487 0.8125,-1.66293922460509 1.11114046603921 0.75,-1.71545722000054 1.02820548838644 0.6875,-1.76384252869671 0.942793473651997 0.625000000000001,-1.80797858624689 0.855110186860566 0.562500000000001,-1.84775906502257 0.765366864730181 0.500000000000001,-1.88308813036604 0.673779706784442 0.437500000000001,-1.91388067146442 0.580569354508927 0.375000000000002,-1.94006250638909 0.485960359806531 0.312500000000002,-1.96157056080646 0.39018064403226 0.250000000000002,-1.97835301992956 0.293460948910727 0.187500000000002,-1.99036945334439 0.196034280659125 0.125000000000002,-1.99759091241034 0.0981353486548404 0.0625000000000026,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
> ST_CurveToLine04|MULTIPOLYGON(((-2 0 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.0624999999999998 0.125,-1.98917650996478 -0.146730474455361 0.0937499999999997 0.187499999999999,-1.98078528040323 -0.195090322016128 0.125 0.249999999999999,-1.97003125319454 -0.242980179903263 0.156249999999999 0.312499999999999,-1.95694033573221 -0.290284677254462 0.187499999999999 0.374999999999999,-1.94154406518302 -0.336889853392219 0.218749999999999 0.437499999999999,-1.92387953251129 -0.382683432365089 0.249999999999999 0.499999999999998,-1.90398929312344 -0.427555093430281 0.281249999999999 0.562499999999998,-1.88192126434836 -0.471396736825996 0.312499999999999 0.624999999999998,-1.85772861000027 -0.51410274419322 0.343749999999999 0.687499999999998,-1.83146961230255 -0.555570233019601 0.374999999999999 0.749999999999997,-1.80320753148065 -0.595699304492432 0.406249999999999 0.812499999999997,-1.77301045336274 -0.634393284163644 0.437499999999999 0.874999999999997,-1.74095112535496 -0.671558954847017 0.468749999999998 0.937499999999997,-1.70710678118655 -0.707106781186546 0.499999999999998 0.999999999999997,-1.67155895484702 -0.740951125354957 0.531249999999998 1.0625,-1.63439328416365 -0.773010453362735 0.562499999999998 1.125,-1.59569930449244 -0.803207531480643 0.593749999999998 1.1875,-1.5555702330196 -0.831469612302543 0.624999999999998 1.25,-1.51410274419322 -0.85772861000027 0.656249999999998 1.3125,-1.471396736826 -0.881921264348353 0.687499999999998 1.375,-1.42755509343029 -0.903989293123442 0.718749999999998 1.4375,-1.38268343236509 -0.923879532511285 0.749999999999998 1.5,-1.33688985339222 -0.94154406518302 0.781249999999998 1.5625,-1.29028467725447 -0.956940335732208 0.812499999999998 1.625,-1.24298017990327 -0.970031253194543 0.843749999999998 1.6875,-1.19509032201613 -0.98078528040323 0.874999999999998 1.75,-1.14673047445537 -0.98917650996478 0.906249999999998 1.8125,-1.09801714032956 -0.995184726672197 0.937499999999998 1.875,-1.04906767432742 -0.998795456205172 0.968749999999998 1.9375,-1 -1 0.999999999999998 2,-0.950932325672585 -0.998795456205173 1.03125 2.0625,-0.901982859670443 -0.995184726672197 1.0625 2.125,-0.853269525544641 -0.989176509964781 1.09375 2.1875,-0.804909677983875 -0.980785280403231 1.125 2.25,-0.757019820096739 -0.970031253194545 1.15625 2.3125,-0.70971532274554 -0.95694033573221 1.1875 2.375,-0.663110146607783 -0.941544065183022 1.21875 2.4375,-0.617316567634913 -0.923879532511288 1.25 2.5,-0.57244490656972 -0.903989293123445 1.28125 2.5625,-0.528603263174005 -0.881921264348356 1.3125 2.625,-0.485897255806781 -0.857728610000273 1.34375 2.6875,-0.4444297669804 -0.831469612302547 1.375 2.75,-0.404300695507569 -0.803207531480647 1.40625 2.8125,-0.365606715836356 -0.773010453362739 1.4375 2.875,-0.328441045152983 -0.740951125354961 1.46875 2.9375,-0.292893218813454 -0.707106781186549 1.5 3,-0.259048874645042 -0.67155895484702 1.53125 3.0625,-0.226989546637264 -0.634393284163647 1.5625 3.125,-0.196792468519356 -0.595699304492435 1.59375 3.1875,-0.168530387697456 -0.555570233019604 1.625 3.25,-0.142271389999729 -0.514102744193224 1.65625 3.3125,-0.118078735651646 -0.471396736826 1.6875 3.375,-0.0960107068765576 -0.427555093430284 1.71875 3.4375,-0.076120467488714 -0.382683432365092 1.75 3.5,-0.05845593481698 -0.336889853392222 1.78125 3.5625,-0.0430596642677917 -0.290284677254464 1.8125 3.625,-0.0299687468054566 -0.242980179903266 1.84375 3.6875,-0.01921471959677 -0.19509032201613 1.875 3.75,-0.0108234900352193 -0.146730474455364 1.90625 3.8125,-0.00481527332780329 -0.0980171403295628 1.9375 3.875,-0.00120454379482771 -0.0490676743274202 1.96875 3.9375,0 0 2 4,0.0012045437948276 -0.049067674327418 2.03125 4.0625,0.00481527332780307 -0.0980171403295604 2.0625 4.125,0.010823490035219 -0.146730474455361 2.09375 4.1875,0.0192147195967695 -0.195090322016128 2.125 4.25,0.0299687468054558 -0.242980179903263 2.15625 4.3125,0.0430596642677908 -0.290284677254462 2.1875 4.375,0.0584559348169789 -0.336889853392219 2.21875 4.4375,0.0761204674887128 -0.382683432365089 2.25 4.5,0.0960107068765561 -0.427555093430281 2.28125 4.5625,0.118078735651644 -0.471396736825996 2.3125 4.625,0.142271389999727 -0.51410274419322 2.34375 4.6875,0.168530387697454 -0.555570233019601 2.375 4.75,0.196792468519354 -0.595699304492432 2.40625 4.8125,0.226989546637262 -0.634393284163644 2.4375 4.875,0.259048874645039 -0.671558954847017 2.46875 4.9375,0.292893218813451 -0.707106781186546 2.5 5,0.32844104515298 -0.740951125354957 2.53125 5.0625,0.365606715836352 -0.773010453362735 2.5625 5.125,0.404300695507564 -0.803207531480643 2.59375 5.1875,0.444429766980395 -0.831469612302543 2.625 5.25,0.485897255806775 -0.85772861000027 2.65625 5.3125,0.528603263173999 -0.881921264348353 2.6875 5.375,0.572444906569715 -0.903989293123442 2.71875 5.4375,0.617316567634907 -0.923879532511285 2.75 5.5,0.663110146607776 -0.94154406518302 2.78125 5.5625,0.709715322745534 -0.956940335732208 2.8125 5.625,0.757019820096733 -0.970031253194543 2.84375 5.6875,0.804909677983868 -0.98078528040323 2.875 5.75,0.853269525544635 -0.98917650996478 2.90625 5.8125,0.901982859670436 -0.995184726672197 2.9375 5.875,0.950932325672579 -0.998795456205172 2.96875 5.9375,0.999999999999997 -1 3 6,1.04906767432741 -0.998795456205173 3.03125 6.0625,1.09801714032956 -0.995184726672197 3.0625 6.125,1.14673047445536 -0.989176509964781 3.09375 6.1875,1.19509032201613 -0.980785280403231 3.125 6.25,1.24298017990326 -0.970031253194545 3.15625 6.3125,1.29028467725446 -0.95694033573221 3.1875 6.375,1.33688985339222 -0.941544065183022 3.21875 6.4375,1.38268343236509 -0.923879532511288 3.25 6.5,1.42755509343028 -0.903989293123445 3.28125 6.5625,1.471396736826 -0.881921264348356 3.3125 6.625,1.51410274419322 -0.857728610000273 3.34375 6.6875,1.5555702330196 -0.831469612302547 3.375 6.75,1.59569930449243 -0.803207531480647 3.40625 6.8125,1.63439328416364 -0.773010453362739 3.4375 6.875,1.67155895484702 -0.740951125354961 3.46875 6.9375,1.70710678118655 -0.707106781186549 3.5 7,1.74095112535496 -0.67155895484702 3.53125 7.0625,1.77301045336274 -0.634393284163647 3.5625 7.125,1.80320753148064 -0.595699304492435 3.59375 7.1875,1.83146961230254 -0.555570233019604 3.625 7.25,1.85772861000027 -0.514102744193224 3.65625 7.3125,1.88192126434835 -0.471396736826 3.6875 7.375,1.90398929312344 -0.427555093430284 3.71875 7.4375,1.92387953251129 -0.382683432365092 3.75 7.5,1.94154406518302 -0.336889853392222 3.78125 7.5625,1.95694033573221 -0.290284677254464 3.8125 7.625,1.97003125319454 -0.242980179903266 3.84375 7.6875,1.98078528040323 -0.19509032201613 3.875 7.75,1.98917650996478 -0.146730474455364 3.90625 7.8125,1.9951847266722 -0.0980171403295628 3.9375 7.875,1.99879545620517 -0.0490676743274202 3.96875 7.9375,2 0 4 8,1.99759091241034 0.098135348654836 3.9375 7.875,1.99036945334439 0.196034280659121 3.875 7.75,1.97835301992956 0.293460948910724 3.8125 7.625,1.96157056080646 0.390180644032257 3.75 7.5,1.94006250638909 0.485960359806528 3.6875 7.375,1.91388067146442 0.580569354508925 3.625 7.25,1.88308813036604 0.67377970678444 3.5625 7.125,1.84775906502257 0.76536686473018 3.5 7,1.80797858624689 0.855110186860564 3.4375 6.875,1.76384252869671 0.942793473651995 3.375 6.75,1.71545722000054 1.02820548838644 3.3125 6.625,1.66293922460509 1.1111404660392 3.25 6.5,1.60641506296129 1.19139860898487 3.1875 6.375,1.54602090672547 1.26878656832729 3.125 6.25,1.48190225070992 1.34311790969404 3.0625 6.125,1.41421356237309 1.4142135623731 3 6,1.34311790969404 1.48190225070992 2.9375 5.875,1.26878656832729 1.54602090672547 2.875 5.75,1.19139860898487 1.60641506296129 2.8125 5.625,1.1111404660392 1.66293922460509 2.75 5.5,1.02820548838644 1.71545722000054 2.6875 5.375,0.942793473651994 1.76384252869671 2.625 5.25,0.855110186860563 1.80797858624689 2.5625 5.125,0.765366864730178 1.84775906502257 2.5 5,0.673779706784439 1.88308813036604 2.4375 4.875,0.580569354508923 1.91388067146442 2.375 4.75,0.485960359806526 1.94006250638909 2.3125 4.625,0.390180644032255 1.96157056080646 2.25 4.5,0.293460948910722 1.97835301992956 2.1875 4.375,0.196034280659119 1.99036945334439 2.125 4.25,0.098135348654834 1.99759091241034 2.0625 4.125,-2.09798541386808e-15 2 2 4,-0.0981353486548382 1.99759091241034 1.9375 3.875,-0.196034280659124 1.99036945334439 1.875 3.75,-0.293460948910726 1.97835301992956 1.8125 3.625,-0.390180644032259 1.96157056080646 1.75 3.5,-0.48596035980653 1.94006250638909 1.6875 3.375,-0.580569354508927 1.91388067146442 1.625 3.25,-0.673779706784443 1.88308813036604 1.5625 3.125,-0.765366864730182 1.84775906502257 1.5 3,-0.855110186860567 1.80797858624689 1.4375 2.875,-0.942793473651998 1.76384252869671 1.375 2.75,-1.02820548838645 1.71545722000054 1.3125 2.625,-1.11114046603921 1.66293922460509 1.25 2.5,-1.19139860898487 1.60641506296129 1.1875 2.375,-1.26878656832729 1.54602090672547 1.125 2.25,-1.34311790969404 1.48190225070992 1.0625 2.125,-1.4142135623731 1.41421356237309 0.999999999999999 2,-1.48190225070992 1.34311790969404 0.9375 1.875,-1.54602090672547 1.26878656832729 0.875 1.75,-1.60641506296129 1.19139860898487 0.8125 1.625,-1.66293922460509 1.11114046603921 0.75 1.5,-1.71545722000054 1.02820548838644 0.6875 1.375,-1.76384252869671 0.942793473651997 0.625000000000001 1.25,-1.80797858624689 0.855110186860566 0.562500000000001 1.125,-1.84775906502257 0.765366864730181 0.500000000000001 1,-1.88308813036604 0.673779706784442 0.437500000000001 0.875000000000003,-1.91388067146442 0.580569354508927 0.375000000000002 0.750000000000003,-1.94006250638909 0.485960359806531 0.312500000000002 0.625000000000004,-1.96157056080646 0.39018064403226 0.250000000000002 0.500000000000004,-1.97835301992956 0.293460948910727 0.187500000000002 0.375000000000004,-1.99036945334439 0.196034280659125 0.125000000000002 0.250000000000005,-1.99759091241034 0.0981353486548404 0.0625000000000026 0.125000000000005,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
45,52c45,52
< ST_CurveToLine-401|MULTIPOLYGON(((-2 0,-1.92387953251129 -0.38268343236509,-1.70710678118655 -0.707106781186548,-1.38268343236509 -0.923879532511287,-1 -1,-0.61731656763491 -0.923879532511287,-0.292893218813452 -0.707106781186547,-0.0761204674887132 -0.38268343236509,0 0,0.0761204674887133 -0.38268343236509,0.292893218813453 -0.707106781186548,0.61731656763491 -0.923879532511287,1 -1,1.38268343236509 -0.923879532511287,1.70710678118655 -0.707106781186547,1.92387953251129 -0.38268343236509,2 0,1.84775906502257 0.76536686473018,1.4142135623731 1.41421356237309,0.76536686473018 1.84775906502257,1.22460635382238e-16 2,-0.765366864730179 1.84775906502257,-1.41421356237309 1.4142135623731,-1.84775906502257 0.76536686473018,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
< ST_CurveToLine-402|MULTIPOLYGONM(((-2 0 0,-1.92387953251129 -0.38268343236509 0.5,-1.70710678118655 -0.707106781186548 1,-1.38268343236509 -0.923879532511287 1.5,-1 -1 2,-0.61731656763491 -0.923879532511287 2.5,-0.292893218813452 -0.707106781186547 3,-0.0761204674887132 -0.38268343236509 3.5,0 0 4,0.0761204674887133 -0.38268343236509 4.5,0.292893218813453 -0.707106781186548 5,0.61731656763491 -0.923879532511287 5.5,1 -1 6,1.38268343236509 -0.923879532511287 6.5,1.70710678118655 -0.707106781186547 7,1.92387953251129 -0.38268343236509 7.5,2 0 8,1.84775906502257 0.76536686473018 7,1.4142135623731 1.41421356237309 6,0.76536686473018 1.84775906502257 5,1.22460635382238e-16 2 4,-0.765366864730179 1.84775906502257 3,-1.41421356237309 1.4142135623731 2,-1.84775906502257 0.76536686473018 1,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
< ST_CurveToLine-403|MULTIPOLYGON(((-2 0 0,-1.92387953251129 -0.38268343236509 0.25,-1.70710678118655 -0.707106781186548 0.5,-1.38268343236509 -0.923879532511287 0.75,-1 -1 1,-0.61731656763491 -0.923879532511287 1.25,-0.292893218813452 -0.707106781186547 1.5,-0.0761204674887132 -0.38268343236509 1.75,0 0 2,0.0761204674887133 -0.38268343236509 2.25,0.292893218813453 -0.707106781186548 2.5,0.61731656763491 -0.923879532511287 2.75,1 -1 3,1.38268343236509 -0.923879532511287 3.25,1.70710678118655 -0.707106781186547 3.5,1.92387953251129 -0.38268343236509 3.75,2 0 4,1.84775906502257 0.76536686473018 3.5,1.4142135623731 1.41421356237309 3,0.76536686473018 1.84775906502257 2.5,1.22460635382238e-16 2 2,-0.765366864730179 1.84775906502257 1.5,-1.41421356237309 1.4142135623731 1,-1.84775906502257 0.76536686473018 0.5,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
< ST_CurveToLine-404|MULTIPOLYGON(((-2 0 0 0,-1.92387953251129 -0.38268343236509 0.25 0.5,-1.70710678118655 -0.707106781186548 0.5 1,-1.38268343236509 -0.923879532511287 0.75 1.5,-1 -1 1 2,-0.61731656763491 -0.923879532511287 1.25 2.5,-0.292893218813452 -0.707106781186547 1.5 3,-0.0761204674887132 -0.38268343236509 1.75 3.5,0 0 2 4,0.0761204674887133 -0.38268343236509 2.25 4.5,0.292893218813453 -0.707106781186548 2.5 5,0.61731656763491 -0.923879532511287 2.75 5.5,1 -1 3 6,1.38268343236509 -0.923879532511287 3.25 6.5,1.70710678118655 -0.707106781186547 3.5 7,1.92387953251129 -0.38268343236509 3.75 7.5,2 0 4 8,1.84775906502257 0.76536686473018 3.5 7,1.4142135623731 1.41421356237309 3 6,0.76536686473018 1.84775906502257 2.5 5,1.22460635382238e-16 2 2 4,-0.765366864730179 1.84775906502257 1.5 3,-1.41421356237309 1.4142135623731 1 2,-1.84775906502257 0.76536686473018 0.5 1,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
< ST_CurveToLine01|MULTIPOLYGON(((-2 0,-1.99879545620517 -0.049067674327418,-1.9951847266722 -0.0980171403295604,-1.98917650996478 -0.146730474455361,-1.98078528040323 -0.195090322016128,-1.97003125319454 -0.242980179903263,-1.95694033573221 -0.290284677254461,-1.94154406518302 -0.336889853392219,-1.92387953251129 -0.382683432365089,-1.90398929312344 -0.427555093430281,-1.88192126434836 -0.471396736825996,-1.85772861000027 -0.51410274419322,-1.83146961230255 -0.555570233019601,-1.80320753148065 -0.595699304492432,-1.77301045336274 -0.634393284163644,-1.74095112535496 -0.671558954847017,-1.70710678118655 -0.707106781186546,-1.67155895484702 -0.740951125354957,-1.63439328416365 -0.773010453362735,-1.59569930449244 -0.803207531480643,-1.5555702330196 -0.831469612302543,-1.51410274419322 -0.85772861000027,-1.471396736826 -0.881921264348353,-1.42755509343029 -0.903989293123442,-1.38268343236509 -0.923879532511285,-1.33688985339222 -0.94154406518302,-1.29028467725447 -0.956940335732208,-1.24298017990327 -0.970031253194543,-1.19509032201613 -0.98078528040323,-1.14673047445537 -0.98917650996478,-1.09801714032956 -0.995184726672197,-1.04906767432742 -0.998795456205172,-1 -1,-0.950932325672585 -0.998795456205173,-0.901982859670443 -0.995184726672197,-0.853269525544641 -0.989176509964781,-0.804909677983875 -0.980785280403231,-0.757019820096739 -0.970031253194545,-0.709715322745541 -0.95694033573221,-0.663110146607783 -0.941544065183022,-0.617316567634913 -0.923879532511288,-0.57244490656972 -0.903989293123445,-0.528603263174005 -0.881921264348356,-0.485897255806781 -0.857728610000273,-0.4444297669804 -0.831469612302547,-0.404300695507569 -0.803207531480646,-0.365606715836356 -0.773010453362739,-0.328441045152983 -0.740951125354961,-0.292893218813454 -0.707106781186549,-0.259048874645043 -0.67155895484702,-0.226989546637265 -0.634393284163647,-0.196792468519356 -0.595699304492435,-0.168530387697456 -0.555570233019604,-0.142271389999729 -0.514102744193224,-0.118078735651646 -0.471396736826,-0.0960107068765576 -0.427555093430284,-0.0761204674887141 -0.382683432365092,-0.0584559348169799 -0.336889853392222,-0.0430596642677918 -0.290284677254464,-0.0299687468054565 -0.242980179903266,-0.01921471959677 -0.19509032201613,-0.0108234900352193 -0.146730474455364,-0.00481527332780333 -0.0980171403295628,-0.00120454379482771 -0.0490676743274202,0 0,0.0012045437948276 -0.049067674327418,0.00481527332780309 -0.0980171403295604,0.010823490035219 -0.146730474455361,0.0192147195967694 -0.195090322016128,0.0299687468054558 -0.242980179903263,0.0430596642677909 -0.290284677254461,0.0584559348169789 -0.336889853392219,0.0761204674887128 -0.382683432365089,0.0960107068765561 -0.427555093430281,0.118078735651644 -0.471396736825996,0.142271389999727 -0.51410274419322,0.168530387697454 -0.555570233019601,0.196792468519354 -0.595699304492432,0.226989546637262 -0.634393284163644,0.259048874645039 -0.671558954847017,0.292893218813451 -0.707106781186546,0.32844104515298 -0.740951125354957,0.365606715836352 -0.773010453362735,0.404300695507564 -0.803207531480643,0.444429766980395 -0.831469612302543,0.485897255806775 -0.85772861000027,0.528603263173999 -0.881921264348353,0.572444906569714 -0.903989293123442,0.617316567634907 -0.923879532511285,0.663110146607777 -0.94154406518302,0.709715322745534 -0.956940335732208,0.757019820096733 -0.970031253194543,0.804909677983868 -0.98078528040323,0.853269525544635 -0.98917650996478,0.901982859670436 -0.995184726672197,0.950932325672579 -0.998795456205172,0.999999999999997 -1,1.04906767432741 -0.998795456205173,1.09801714032956 -0.995184726672197,1.14673047445536 -0.989176509964781,1.19509032201613 -0.980785280403231,1.24298017990326 -0.970031253194545,1.29028467725446 -0.95694033573221,1.33688985339222 -0.941544065183022,1.38268343236509 -0.923879532511288,1.42755509343028 -0.903989293123445,1.471396736826 -0.881921264348356,1.51410274419322 -0.857728610000273,1.5555702330196 -0.831469612302547,1.59569930449243 -0.803207531480646,1.63439328416364 -0.773010453362739,1.67155895484702 -0.740951125354961,1.70710678118655 -0.707106781186549,1.74095112535496 -0.67155895484702,1.77301045336274 -0.634393284163647,1.80320753148064 -0.595699304492435,1.83146961230254 -0.555570233019604,1.85772861000027 -0.514102744193224,1.88192126434835 -0.471396736826,1.90398929312344 -0.427555093430284,1.92387953251129 -0.382683432365092,1.94154406518302 -0.336889853392222,1.95694033573221 -0.290284677254464,1.97003125319454 -0.242980179903266,1.98078528040323 -0.19509032201613,1.98917650996478 -0.146730474455364,1.9951847266722 -0.0980171403295628,1.99879545620517 -0.0490676743274202,2 0,1.99759091241034 0.098135348654836,1.99036945334439 0.196034280659121,1.97835301992956 0.293460948910723,1.96157056080646 0.390180644032256,1.94006250638909 0.485960359806528,1.91388067146442 0.580569354508925,1.88308813036604 0.67377970678444,1.84775906502257 0.76536686473018,1.80797858624689 0.855110186860564,1.76384252869671 0.942793473651995,1.71545722000054 1.02820548838644,1.66293922460509 1.1111404660392,1.60641506296129 1.19139860898487,1.54602090672547 1.26878656832729,1.48190225070992 1.34311790969404,1.41421356237309 1.4142135623731,1.34311790969404 1.48190225070992,1.26878656832729 1.54602090672547,1.19139860898487 1.60641506296129,1.1111404660392 1.66293922460509,1.02820548838644 1.71545722000054,0.942793473651994 1.76384252869671,0.855110186860563 1.80797858624689,0.765366864730178 1.84775906502257,0.673779706784439 1.88308813036604,0.580569354508923 1.91388067146442,0.485960359806526 1.94006250638909,0.390180644032255 1.96157056080646,0.293460948910722 1.97835301992956,0.196034280659119 1.99036945334439,0.098135348654834 1.99759091241034,-2.09798541386808e-15 2,-0.0981353486548382 1.99759091241034,-0.196034280659124 1.99036945334439,-0.293460948910726 1.97835301992956,-0.390180644032259 1.96157056080646,-0.48596035980653 1.94006250638909,-0.580569354508927 1.91388067146442,-0.673779706784443 1.88308813036604,-0.765366864730182 1.84775906502257,-0.855110186860567 1.80797858624689,-0.942793473651998 1.76384252869671,-1.02820548838645 1.71545722000054,-1.11114046603921 1.66293922460509,-1.19139860898487 1.60641506296129,-1.26878656832729 1.54602090672547,-1.34311790969404 1.48190225070992,-1.4142135623731 1.41421356237309,-1.48190225070992 1.34311790969404,-1.54602090672547 1.26878656832729,-1.60641506296129 1.19139860898487,-1.66293922460509 1.11114046603921,-1.71545722000054 1.02820548838644,-1.76384252869671 0.942793473651997,-1.80797858624689 0.855110186860566,-1.84775906502257 0.765366864730181,-1.88308813036604 0.673779706784442,-1.91388067146442 0.580569354508927,-1.94006250638909 0.485960359806531,-1.96157056080646 0.39018064403226,-1.97835301992956 0.293460948910727,-1.99036945334439 0.196034280659125,-1.99759091241034 0.0981353486548404,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
< ST_CurveToLine02|MULTIPOLYGONM(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.125,-1.98917650996478 -0.146730474455361 0.187499999999999,-1.98078528040323 -0.195090322016128 0.249999999999999,-1.97003125319454 -0.242980179903263 0.312499999999999,-1.95694033573221 -0.290284677254461 0.374999999999999,-1.94154406518302 -0.336889853392219 0.437499999999999,-1.92387953251129 -0.382683432365089 0.499999999999998,-1.90398929312344 -0.427555093430281 0.562499999999998,-1.88192126434836 -0.471396736825996 0.624999999999998,-1.85772861000027 -0.51410274419322 0.687499999999998,-1.83146961230255 -0.555570233019601 0.749999999999997,-1.80320753148065 -0.595699304492432 0.812499999999997,-1.77301045336274 -0.634393284163644 0.874999999999997,-1.74095112535496 -0.671558954847017 0.937499999999997,-1.70710678118655 -0.707106781186546 0.999999999999997,-1.67155895484702 -0.740951125354957 1.0625,-1.63439328416365 -0.773010453362735 1.125,-1.59569930449244 -0.803207531480643 1.1875,-1.5555702330196 -0.831469612302543 1.25,-1.51410274419322 -0.85772861000027 1.3125,-1.471396736826 -0.881921264348353 1.375,-1.42755509343029 -0.903989293123442 1.4375,-1.38268343236509 -0.923879532511285 1.5,-1.33688985339222 -0.94154406518302 1.5625,-1.29028467725447 -0.956940335732208 1.625,-1.24298017990327 -0.970031253194543 1.6875,-1.19509032201613 -0.98078528040323 1.75,-1.14673047445537 -0.98917650996478 1.8125,-1.09801714032956 -0.995184726672197 1.875,-1.04906767432742 -0.998795456205172 1.9375,-1 -1 2,-0.950932325672585 -0.998795456205173 2.0625,-0.901982859670443 -0.995184726672197 2.125,-0.853269525544641 -0.989176509964781 2.1875,-0.804909677983875 -0.980785280403231 2.25,-0.757019820096739 -0.970031253194545 2.3125,-0.709715322745541 -0.95694033573221 2.375,-0.663110146607783 -0.941544065183022 2.4375,-0.617316567634913 -0.923879532511288 2.5,-0.57244490656972 -0.903989293123445 2.5625,-0.528603263174005 -0.881921264348356 2.625,-0.485897255806781 -0.857728610000273 2.6875,-0.4444297669804 -0.831469612302547 2.75,-0.404300695507569 -0.803207531480646 2.8125,-0.365606715836356 -0.773010453362739 2.875,-0.328441045152983 -0.740951125354961 2.9375,-0.292893218813454 -0.707106781186549 3,-0.259048874645043 -0.67155895484702 3.0625,-0.226989546637265 -0.634393284163647 3.125,-0.196792468519356 -0.595699304492435 3.1875,-0.168530387697456 -0.555570233019604 3.25,-0.142271389999729 -0.514102744193224 3.3125,-0.118078735651646 -0.471396736826 3.375,-0.0960107068765576 -0.427555093430284 3.4375,-0.0761204674887141 -0.382683432365092 3.5,-0.0584559348169799 -0.336889853392222 3.5625,-0.0430596642677918 -0.290284677254464 3.625,-0.0299687468054565 -0.242980179903266 3.6875,-0.01921471959677 -0.19509032201613 3.75,-0.0108234900352193 -0.146730474455364 3.8125,-0.00481527332780333 -0.0980171403295628 3.875,-0.00120454379482771 -0.0490676743274202 3.9375,0 0 4,0.0012045437948276 -0.049067674327418 4.0625,0.00481527332780309 -0.0980171403295604 4.125,0.010823490035219 -0.146730474455361 4.1875,0.0192147195967694 -0.195090322016128 4.25,0.0299687468054558 -0.242980179903263 4.3125,0.0430596642677909 -0.290284677254461 4.375,0.0584559348169789 -0.336889853392219 4.4375,0.0761204674887128 -0.382683432365089 4.5,0.0960107068765561 -0.427555093430281 4.5625,0.118078735651644 -0.471396736825996 4.625,0.142271389999727 -0.51410274419322 4.6875,0.168530387697454 -0.555570233019601 4.75,0.196792468519354 -0.595699304492432 4.8125,0.226989546637262 -0.634393284163644 4.875,0.259048874645039 -0.671558954847017 4.9375,0.292893218813451 -0.707106781186546 5,0.32844104515298 -0.740951125354957 5.0625,0.365606715836352 -0.773010453362735 5.125,0.404300695507564 -0.803207531480643 5.1875,0.444429766980395 -0.831469612302543 5.25,0.485897255806775 -0.85772861000027 5.3125,0.528603263173999 -0.881921264348353 5.375,0.572444906569714 -0.903989293123442 5.4375,0.617316567634907 -0.923879532511285 5.5,0.663110146607777 -0.94154406518302 5.5625,0.709715322745534 -0.956940335732208 5.625,0.757019820096733 -0.970031253194543 5.6875,0.804909677983868 -0.98078528040323 5.75,0.853269525544635 -0.98917650996478 5.8125,0.901982859670436 -0.995184726672197 5.875,0.950932325672579 -0.998795456205172 5.9375,0.999999999999997 -1 6,1.04906767432741 -0.998795456205173 6.0625,1.09801714032956 -0.995184726672197 6.125,1.14673047445536 -0.989176509964781 6.1875,1.19509032201613 -0.980785280403231 6.25,1.24298017990326 -0.970031253194545 6.3125,1.29028467725446 -0.95694033573221 6.375,1.33688985339222 -0.941544065183022 6.4375,1.38268343236509 -0.923879532511288 6.5,1.42755509343028 -0.903989293123445 6.5625,1.471396736826 -0.881921264348356 6.625,1.51410274419322 -0.857728610000273 6.6875,1.5555702330196 -0.831469612302547 6.75,1.59569930449243 -0.803207531480646 6.8125,1.63439328416364 -0.773010453362739 6.875,1.67155895484702 -0.740951125354961 6.9375,1.70710678118655 -0.707106781186549 7,1.74095112535496 -0.67155895484702 7.0625,1.77301045336274 -0.634393284163647 7.125,1.80320753148064 -0.595699304492435 7.1875,1.83146961230254 -0.555570233019604 7.25,1.85772861000027 -0.514102744193224 7.3125,1.88192126434835 -0.471396736826 7.375,1.90398929312344 -0.427555093430284 7.4375,1.92387953251129 -0.382683432365092 7.5,1.94154406518302 -0.336889853392222 7.5625,1.95694033573221 -0.290284677254464 7.625,1.97003125319454 -0.242980179903266 7.6875,1.98078528040323 -0.19509032201613 7.75,1.98917650996478 -0.146730474455364 7.8125,1.9951847266722 -0.0980171403295628 7.875,1.99879545620517 -0.0490676743274202 7.9375,2 0 8,1.99759091241034 0.098135348654836 7.875,1.99036945334439 0.196034280659121 7.75,1.97835301992956 0.293460948910723 7.625,1.96157056080646 0.390180644032256 7.5,1.94006250638909 0.485960359806528 7.375,1.91388067146442 0.580569354508925 7.25,1.88308813036604 0.67377970678444 7.125,1.84775906502257 0.76536686473018 7,1.80797858624689 0.855110186860564 6.875,1.76384252869671 0.942793473651995 6.75,1.71545722000054 1.02820548838644 6.625,1.66293922460509 1.1111404660392 6.5,1.60641506296129 1.19139860898487 6.375,1.54602090672547 1.26878656832729 6.25,1.48190225070992 1.34311790969404 6.125,1.41421356237309 1.4142135623731 6,1.34311790969404 1.48190225070992 5.875,1.26878656832729 1.54602090672547 5.75,1.19139860898487 1.60641506296129 5.625,1.1111404660392 1.66293922460509 5.5,1.02820548838644 1.71545722000054 5.375,0.942793473651994 1.76384252869671 5.25,0.855110186860563 1.80797858624689 5.125,0.765366864730178 1.84775906502257 5,0.673779706784439 1.88308813036604 4.875,0.580569354508923 1.91388067146442 4.75,0.485960359806526 1.94006250638909 4.625,0.390180644032255 1.96157056080646 4.5,0.293460948910722 1.97835301992956 4.375,0.196034280659119 1.99036945334439 4.25,0.098135348654834 1.99759091241034 4.125,-2.09798541386808e-15 2 4,-0.0981353486548382 1.99759091241034 3.875,-0.196034280659124 1.99036945334439 3.75,-0.293460948910726 1.97835301992956 3.625,-0.390180644032259 1.96157056080646 3.5,-0.48596035980653 1.94006250638909 3.375,-0.580569354508927 1.91388067146442 3.25,-0.673779706784443 1.88308813036604 3.125,-0.765366864730182 1.84775906502257 3,-0.855110186860567 1.80797858624689 2.875,-0.942793473651998 1.76384252869671 2.75,-1.02820548838645 1.71545722000054 2.625,-1.11114046603921 1.66293922460509 2.5,-1.19139860898487 1.60641506296129 2.375,-1.26878656832729 1.54602090672547 2.25,-1.34311790969404 1.48190225070992 2.125,-1.4142135623731 1.41421356237309 2,-1.48190225070992 1.34311790969404 1.875,-1.54602090672547 1.26878656832729 1.75,-1.60641506296129 1.19139860898487 1.625,-1.66293922460509 1.11114046603921 1.5,-1.71545722000054 1.02820548838644 1.375,-1.76384252869671 0.942793473651997 1.25,-1.80797858624689 0.855110186860566 1.125,-1.84775906502257 0.765366864730181 1,-1.88308813036604 0.673779706784442 0.875000000000003,-1.91388067146442 0.580569354508927 0.750000000000003,-1.94006250638909 0.485960359806531 0.625000000000004,-1.96157056080646 0.39018064403226 0.500000000000004,-1.97835301992956 0.293460948910727 0.375000000000004,-1.99036945334439 0.196034280659125 0.250000000000005,-1.99759091241034 0.0981353486548404 0.125000000000005,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
< ST_CurveToLine03|MULTIPOLYGON(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999,-1.9951847266722 -0.0980171403295604 0.0624999999999998,-1.98917650996478 -0.146730474455361 0.0937499999999997,-1.98078528040323 -0.195090322016128 0.125,-1.97003125319454 -0.242980179903263 0.156249999999999,-1.95694033573221 -0.290284677254461 0.187499999999999,-1.94154406518302 -0.336889853392219 0.218749999999999,-1.92387953251129 -0.382683432365089 0.249999999999999,-1.90398929312344 -0.427555093430281 0.281249999999999,-1.88192126434836 -0.471396736825996 0.312499999999999,-1.85772861000027 -0.51410274419322 0.343749999999999,-1.83146961230255 -0.555570233019601 0.374999999999999,-1.80320753148065 -0.595699304492432 0.406249999999999,-1.77301045336274 -0.634393284163644 0.437499999999999,-1.74095112535496 -0.671558954847017 0.468749999999998,-1.70710678118655 -0.707106781186546 0.499999999999998,-1.67155895484702 -0.740951125354957 0.531249999999998,-1.63439328416365 -0.773010453362735 0.562499999999998,-1.59569930449244 -0.803207531480643 0.593749999999998,-1.5555702330196 -0.831469612302543 0.624999999999998,-1.51410274419322 -0.85772861000027 0.656249999999998,-1.471396736826 -0.881921264348353 0.687499999999998,-1.42755509343029 -0.903989293123442 0.718749999999998,-1.38268343236509 -0.923879532511285 0.749999999999998,-1.33688985339222 -0.94154406518302 0.781249999999998,-1.29028467725447 -0.956940335732208 0.812499999999998,-1.24298017990327 -0.970031253194543 0.843749999999998,-1.19509032201613 -0.98078528040323 0.874999999999998,-1.14673047445537 -0.98917650996478 0.906249999999998,-1.09801714032956 -0.995184726672197 0.937499999999998,-1.04906767432742 -0.998795456205172 0.968749999999998,-1 -1 0.999999999999998,-0.950932325672585 -0.998795456205173 1.03125,-0.901982859670443 -0.995184726672197 1.0625,-0.853269525544641 -0.989176509964781 1.09375,-0.804909677983875 -0.980785280403231 1.125,-0.757019820096739 -0.970031253194545 1.15625,-0.709715322745541 -0.95694033573221 1.1875,-0.663110146607783 -0.941544065183022 1.21875,-0.617316567634913 -0.923879532511288 1.25,-0.57244490656972 -0.903989293123445 1.28125,-0.528603263174005 -0.881921264348356 1.3125,-0.485897255806781 -0.857728610000273 1.34375,-0.4444297669804 -0.831469612302547 1.375,-0.404300695507569 -0.803207531480646 1.40625,-0.365606715836356 -0.773010453362739 1.4375,-0.328441045152983 -0.740951125354961 1.46875,-0.292893218813454 -0.707106781186549 1.5,-0.259048874645043 -0.67155895484702 1.53125,-0.226989546637265 -0.634393284163647 1.5625,-0.196792468519356 -0.595699304492435 1.59375,-0.168530387697456 -0.555570233019604 1.625,-0.142271389999729 -0.514102744193224 1.65625,-0.118078735651646 -0.471396736826 1.6875,-0.0960107068765576 -0.427555093430284 1.71875,-0.0761204674887141 -0.382683432365092 1.75,-0.0584559348169799 -0.336889853392222 1.78125,-0.0430596642677918 -0.290284677254464 1.8125,-0.0299687468054565 -0.242980179903266 1.84375,-0.01921471959677 -0.19509032201613 1.875,-0.0108234900352193 -0.146730474455364 1.90625,-0.00481527332780333 -0.0980171403295628 1.9375,-0.00120454379482771 -0.0490676743274202 1.96875,0 0 2,0.0012045437948276 -0.049067674327418 2.03125,0.00481527332780309 -0.0980171403295604 2.0625,0.010823490035219 -0.146730474455361 2.09375,0.0192147195967694 -0.195090322016128 2.125,0.0299687468054558 -0.242980179903263 2.15625,0.0430596642677909 -0.290284677254461 2.1875,0.0584559348169789 -0.336889853392219 2.21875,0.0761204674887128 -0.382683432365089 2.25,0.0960107068765561 -0.427555093430281 2.28125,0.118078735651644 -0.471396736825996 2.3125,0.142271389999727 -0.51410274419322 2.34375,0.168530387697454 -0.555570233019601 2.375,0.196792468519354 -0.595699304492432 2.40625,0.226989546637262 -0.634393284163644 2.4375,0.259048874645039 -0.671558954847017 2.46875,0.292893218813451 -0.707106781186546 2.5,0.32844104515298 -0.740951125354957 2.53125,0.365606715836352 -0.773010453362735 2.5625,0.404300695507564 -0.803207531480643 2.59375,0.444429766980395 -0.831469612302543 2.625,0.485897255806775 -0.85772861000027 2.65625,0.528603263173999 -0.881921264348353 2.6875,0.572444906569714 -0.903989293123442 2.71875,0.617316567634907 -0.923879532511285 2.75,0.663110146607777 -0.94154406518302 2.78125,0.709715322745534 -0.956940335732208 2.8125,0.757019820096733 -0.970031253194543 2.84375,0.804909677983868 -0.98078528040323 2.875,0.853269525544635 -0.98917650996478 2.90625,0.901982859670436 -0.995184726672197 2.9375,0.950932325672579 -0.998795456205172 2.96875,0.999999999999997 -1 3,1.04906767432741 -0.998795456205173 3.03125,1.09801714032956 -0.995184726672197 3.0625,1.14673047445536 -0.989176509964781 3.09375,1.19509032201613 -0.980785280403231 3.125,1.24298017990326 -0.970031253194545 3.15625,1.29028467725446 -0.95694033573221 3.1875,1.33688985339222 -0.941544065183022 3.21875,1.38268343236509 -0.923879532511288 3.25,1.42755509343028 -0.903989293123445 3.28125,1.471396736826 -0.881921264348356 3.3125,1.51410274419322 -0.857728610000273 3.34375,1.5555702330196 -0.831469612302547 3.375,1.59569930449243 -0.803207531480646 3.40625,1.63439328416364 -0.773010453362739 3.4375,1.67155895484702 -0.740951125354961 3.46875,1.70710678118655 -0.707106781186549 3.5,1.74095112535496 -0.67155895484702 3.53125,1.77301045336274 -0.634393284163647 3.5625,1.80320753148064 -0.595699304492435 3.59375,1.83146961230254 -0.555570233019604 3.625,1.85772861000027 -0.514102744193224 3.65625,1.88192126434835 -0.471396736826 3.6875,1.90398929312344 -0.427555093430284 3.71875,1.92387953251129 -0.382683432365092 3.75,1.94154406518302 -0.336889853392222 3.78125,1.95694033573221 -0.290284677254464 3.8125,1.97003125319454 -0.242980179903266 3.84375,1.98078528040323 -0.19509032201613 3.875,1.98917650996478 -0.146730474455364 3.90625,1.9951847266722 -0.0980171403295628 3.9375,1.99879545620517 -0.0490676743274202 3.96875,2 0 4,1.99759091241034 0.098135348654836 3.9375,1.99036945334439 0.196034280659121 3.875,1.97835301992956 0.293460948910723 3.8125,1.96157056080646 0.390180644032256 3.75,1.94006250638909 0.485960359806528 3.6875,1.91388067146442 0.580569354508925 3.625,1.88308813036604 0.67377970678444 3.5625,1.84775906502257 0.76536686473018 3.5,1.80797858624689 0.855110186860564 3.4375,1.76384252869671 0.942793473651995 3.375,1.71545722000054 1.02820548838644 3.3125,1.66293922460509 1.1111404660392 3.25,1.60641506296129 1.19139860898487 3.1875,1.54602090672547 1.26878656832729 3.125,1.48190225070992 1.34311790969404 3.0625,1.41421356237309 1.4142135623731 3,1.34311790969404 1.48190225070992 2.9375,1.26878656832729 1.54602090672547 2.875,1.19139860898487 1.60641506296129 2.8125,1.1111404660392 1.66293922460509 2.75,1.02820548838644 1.71545722000054 2.6875,0.942793473651994 1.76384252869671 2.625,0.855110186860563 1.80797858624689 2.5625,0.765366864730178 1.84775906502257 2.5,0.673779706784439 1.88308813036604 2.4375,0.580569354508923 1.91388067146442 2.375,0.485960359806526 1.94006250638909 2.3125,0.390180644032255 1.96157056080646 2.25,0.293460948910722 1.97835301992956 2.1875,0.196034280659119 1.99036945334439 2.125,0.098135348654834 1.99759091241034 2.0625,-2.09798541386808e-15 2 2,-0.0981353486548382 1.99759091241034 1.9375,-0.196034280659124 1.99036945334439 1.875,-0.293460948910726 1.97835301992956 1.8125,-0.390180644032259 1.96157056080646 1.75,-0.48596035980653 1.94006250638909 1.6875,-0.580569354508927 1.91388067146442 1.625,-0.673779706784443 1.88308813036604 1.5625,-0.765366864730182 1.84775906502257 1.5,-0.855110186860567 1.80797858624689 1.4375,-0.942793473651998 1.76384252869671 1.375,-1.02820548838645 1.71545722000054 1.3125,-1.11114046603921 1.66293922460509 1.25,-1.19139860898487 1.60641506296129 1.1875,-1.26878656832729 1.54602090672547 1.125,-1.34311790969404 1.48190225070992 1.0625,-1.4142135623731 1.41421356237309 0.999999999999999,-1.48190225070992 1.34311790969404 0.9375,-1.54602090672547 1.26878656832729 0.875,-1.60641506296129 1.19139860898487 0.8125,-1.66293922460509 1.11114046603921 0.75,-1.71545722000054 1.02820548838644 0.6875,-1.76384252869671 0.942793473651997 0.625000000000001,-1.80797858624689 0.855110186860566 0.562500000000001,-1.84775906502257 0.765366864730181 0.500000000000001,-1.88308813036604 0.673779706784442 0.437500000000001,-1.91388067146442 0.580569354508927 0.375000000000002,-1.94006250638909 0.485960359806531 0.312500000000002,-1.96157056080646 0.39018064403226 0.250000000000002,-1.97835301992956 0.293460948910727 0.187500000000002,-1.99036945334439 0.196034280659125 0.125000000000002,-1.99759091241034 0.0981353486548404 0.0625000000000026,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
< ST_CurveToLine04|MULTIPOLYGON(((-2 0 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.0624999999999998 0.125,-1.98917650996478 -0.146730474455361 0.0937499999999997 0.187499999999999,-1.98078528040323 -0.195090322016128 0.125 0.249999999999999,-1.97003125319454 -0.242980179903263 0.156249999999999 0.312499999999999,-1.95694033573221 -0.290284677254461 0.187499999999999 0.374999999999999,-1.94154406518302 -0.336889853392219 0.218749999999999 0.437499999999999,-1.92387953251129 -0.382683432365089 0.249999999999999 0.499999999999998,-1.90398929312344 -0.427555093430281 0.281249999999999 0.562499999999998,-1.88192126434836 -0.471396736825996 0.312499999999999 0.624999999999998,-1.85772861000027 -0.51410274419322 0.343749999999999 0.687499999999998,-1.83146961230255 -0.555570233019601 0.374999999999999 0.749999999999997,-1.80320753148065 -0.595699304492432 0.406249999999999 0.812499999999997,-1.77301045336274 -0.634393284163644 0.437499999999999 0.874999999999997,-1.74095112535496 -0.671558954847017 0.468749999999998 0.937499999999997,-1.70710678118655 -0.707106781186546 0.499999999999998 0.999999999999997,-1.67155895484702 -0.740951125354957 0.531249999999998 1.0625,-1.63439328416365 -0.773010453362735 0.562499999999998 1.125,-1.59569930449244 -0.803207531480643 0.593749999999998 1.1875,-1.5555702330196 -0.831469612302543 0.624999999999998 1.25,-1.51410274419322 -0.85772861000027 0.656249999999998 1.3125,-1.471396736826 -0.881921264348353 0.687499999999998 1.375,-1.42755509343029 -0.903989293123442 0.718749999999998 1.4375,-1.38268343236509 -0.923879532511285 0.749999999999998 1.5,-1.33688985339222 -0.94154406518302 0.781249999999998 1.5625,-1.29028467725447 -0.956940335732208 0.812499999999998 1.625,-1.24298017990327 -0.970031253194543 0.843749999999998 1.6875,-1.19509032201613 -0.98078528040323 0.874999999999998 1.75,-1.14673047445537 -0.98917650996478 0.906249999999998 1.8125,-1.09801714032956 -0.995184726672197 0.937499999999998 1.875,-1.04906767432742 -0.998795456205172 0.968749999999998 1.9375,-1 -1 0.999999999999998 2,-0.950932325672585 -0.998795456205173 1.03125 2.0625,-0.901982859670443 -0.995184726672197 1.0625 2.125,-0.853269525544641 -0.989176509964781 1.09375 2.1875,-0.804909677983875 -0.980785280403231 1.125 2.25,-0.757019820096739 -0.970031253194545 1.15625 2.3125,-0.709715322745541 -0.95694033573221 1.1875 2.375,-0.663110146607783 -0.941544065183022 1.21875 2.4375,-0.617316567634913 -0.923879532511288 1.25 2.5,-0.57244490656972 -0.903989293123445 1.28125 2.5625,-0.528603263174005 -0.881921264348356 1.3125 2.625,-0.485897255806781 -0.857728610000273 1.34375 2.6875,-0.4444297669804 -0.831469612302547 1.375 2.75,-0.404300695507569 -0.803207531480646 1.40625 2.8125,-0.365606715836356 -0.773010453362739 1.4375 2.875,-0.328441045152983 -0.740951125354961 1.46875 2.9375,-0.292893218813454 -0.707106781186549 1.5 3,-0.259048874645043 -0.67155895484702 1.53125 3.0625,-0.226989546637265 -0.634393284163647 1.5625 3.125,-0.196792468519356 -0.595699304492435 1.59375 3.1875,-0.168530387697456 -0.555570233019604 1.625 3.25,-0.142271389999729 -0.514102744193224 1.65625 3.3125,-0.118078735651646 -0.471396736826 1.6875 3.375,-0.0960107068765576 -0.427555093430284 1.71875 3.4375,-0.0761204674887141 -0.382683432365092 1.75 3.5,-0.0584559348169799 -0.336889853392222 1.78125 3.5625,-0.0430596642677918 -0.290284677254464 1.8125 3.625,-0.0299687468054565 -0.242980179903266 1.84375 3.6875,-0.01921471959677 -0.19509032201613 1.875 3.75,-0.0108234900352193 -0.146730474455364 1.90625 3.8125,-0.00481527332780333 -0.0980171403295628 1.9375 3.875,-0.00120454379482771 -0.0490676743274202 1.96875 3.9375,0 0 2 4,0.0012045437948276 -0.049067674327418 2.03125 4.0625,0.00481527332780309 -0.0980171403295604 2.0625 4.125,0.010823490035219 -0.146730474455361 2.09375 4.1875,0.0192147195967694 -0.195090322016128 2.125 4.25,0.0299687468054558 -0.242980179903263 2.15625 4.3125,0.0430596642677909 -0.290284677254461 2.1875 4.375,0.0584559348169789 -0.336889853392219 2.21875 4.4375,0.0761204674887128 -0.382683432365089 2.25 4.5,0.0960107068765561 -0.427555093430281 2.28125 4.5625,0.118078735651644 -0.471396736825996 2.3125 4.625,0.142271389999727 -0.51410274419322 2.34375 4.6875,0.168530387697454 -0.555570233019601 2.375 4.75,0.196792468519354 -0.595699304492432 2.40625 4.8125,0.226989546637262 -0.634393284163644 2.4375 4.875,0.259048874645039 -0.671558954847017 2.46875 4.9375,0.292893218813451 -0.707106781186546 2.5 5,0.32844104515298 -0.740951125354957 2.53125 5.0625,0.365606715836352 -0.773010453362735 2.5625 5.125,0.404300695507564 -0.803207531480643 2.59375 5.1875,0.444429766980395 -0.831469612302543 2.625 5.25,0.485897255806775 -0.85772861000027 2.65625 5.3125,0.528603263173999 -0.881921264348353 2.6875 5.375,0.572444906569714 -0.903989293123442 2.71875 5.4375,0.617316567634907 -0.923879532511285 2.75 5.5,0.663110146607777 -0.94154406518302 2.78125 5.5625,0.709715322745534 -0.956940335732208 2.8125 5.625,0.757019820096733 -0.970031253194543 2.84375 5.6875,0.804909677983868 -0.98078528040323 2.875 5.75,0.853269525544635 -0.98917650996478 2.90625 5.8125,0.901982859670436 -0.995184726672197 2.9375 5.875,0.950932325672579 -0.998795456205172 2.96875 5.9375,0.999999999999997 -1 3 6,1.04906767432741 -0.998795456205173 3.03125 6.0625,1.09801714032956 -0.995184726672197 3.0625 6.125,1.14673047445536 -0.989176509964781 3.09375 6.1875,1.19509032201613 -0.980785280403231 3.125 6.25,1.24298017990326 -0.970031253194545 3.15625 6.3125,1.29028467725446 -0.95694033573221 3.1875 6.375,1.33688985339222 -0.941544065183022 3.21875 6.4375,1.38268343236509 -0.923879532511288 3.25 6.5,1.42755509343028 -0.903989293123445 3.28125 6.5625,1.471396736826 -0.881921264348356 3.3125 6.625,1.51410274419322 -0.857728610000273 3.34375 6.6875,1.5555702330196 -0.831469612302547 3.375 6.75,1.59569930449243 -0.803207531480646 3.40625 6.8125,1.63439328416364 -0.773010453362739 3.4375 6.875,1.67155895484702 -0.740951125354961 3.46875 6.9375,1.70710678118655 -0.707106781186549 3.5 7,1.74095112535496 -0.67155895484702 3.53125 7.0625,1.77301045336274 -0.634393284163647 3.5625 7.125,1.80320753148064 -0.595699304492435 3.59375 7.1875,1.83146961230254 -0.555570233019604 3.625 7.25,1.85772861000027 -0.514102744193224 3.65625 7.3125,1.88192126434835 -0.471396736826 3.6875 7.375,1.90398929312344 -0.427555093430284 3.71875 7.4375,1.92387953251129 -0.382683432365092 3.75 7.5,1.94154406518302 -0.336889853392222 3.78125 7.5625,1.95694033573221 -0.290284677254464 3.8125 7.625,1.97003125319454 -0.242980179903266 3.84375 7.6875,1.98078528040323 -0.19509032201613 3.875 7.75,1.98917650996478 -0.146730474455364 3.90625 7.8125,1.9951847266722 -0.0980171403295628 3.9375 7.875,1.99879545620517 -0.0490676743274202 3.96875 7.9375,2 0 4 8,1.99759091241034 0.098135348654836 3.9375 7.875,1.99036945334439 0.196034280659121 3.875 7.75,1.97835301992956 0.293460948910723 3.8125 7.625,1.96157056080646 0.390180644032256 3.75 7.5,1.94006250638909 0.485960359806528 3.6875 7.375,1.91388067146442 0.580569354508925 3.625 7.25,1.88308813036604 0.67377970678444 3.5625 7.125,1.84775906502257 0.76536686473018 3.5 7,1.80797858624689 0.855110186860564 3.4375 6.875,1.76384252869671 0.942793473651995 3.375 6.75,1.71545722000054 1.02820548838644 3.3125 6.625,1.66293922460509 1.1111404660392 3.25 6.5,1.60641506296129 1.19139860898487 3.1875 6.375,1.54602090672547 1.26878656832729 3.125 6.25,1.48190225070992 1.34311790969404 3.0625 6.125,1.41421356237309 1.4142135623731 3 6,1.34311790969404 1.48190225070992 2.9375 5.875,1.26878656832729 1.54602090672547 2.875 5.75,1.19139860898487 1.60641506296129 2.8125 5.625,1.1111404660392 1.66293922460509 2.75 5.5,1.02820548838644 1.71545722000054 2.6875 5.375,0.942793473651994 1.76384252869671 2.625 5.25,0.855110186860563 1.80797858624689 2.5625 5.125,0.765366864730178 1.84775906502257 2.5 5,0.673779706784439 1.88308813036604 2.4375 4.875,0.580569354508923 1.91388067146442 2.375 4.75,0.485960359806526 1.94006250638909 2.3125 4.625,0.390180644032255 1.96157056080646 2.25 4.5,0.293460948910722 1.97835301992956 2.1875 4.375,0.196034280659119 1.99036945334439 2.125 4.25,0.098135348654834 1.99759091241034 2.0625 4.125,-2.09798541386808e-15 2 2 4,-0.0981353486548382 1.99759091241034 1.9375 3.875,-0.196034280659124 1.99036945334439 1.875 3.75,-0.293460948910726 1.97835301992956 1.8125 3.625,-0.390180644032259 1.96157056080646 1.75 3.5,-0.48596035980653 1.94006250638909 1.6875 3.375,-0.580569354508927 1.91388067146442 1.625 3.25,-0.673779706784443 1.88308813036604 1.5625 3.125,-0.765366864730182 1.84775906502257 1.5 3,-0.855110186860567 1.80797858624689 1.4375 2.875,-0.942793473651998 1.76384252869671 1.375 2.75,-1.02820548838645 1.71545722000054 1.3125 2.625,-1.11114046603921 1.66293922460509 1.25 2.5,-1.19139860898487 1.60641506296129 1.1875 2.375,-1.26878656832729 1.54602090672547 1.125 2.25,-1.34311790969404 1.48190225070992 1.0625 2.125,-1.4142135623731 1.41421356237309 0.999999999999999 2,-1.48190225070992 1.34311790969404 0.9375 1.875,-1.54602090672547 1.26878656832729 0.875 1.75,-1.60641506296129 1.19139860898487 0.8125 1.625,-1.66293922460509 1.11114046603921 0.75 1.5,-1.71545722000054 1.02820548838644 0.6875 1.375,-1.76384252869671 0.942793473651997 0.625000000000001 1.25,-1.80797858624689 0.855110186860566 0.562500000000001 1.125,-1.84775906502257 0.765366864730181 0.500000000000001 1,-1.88308813036604 0.673779706784442 0.437500000000001 0.875000000000003,-1.91388067146442 0.580569354508927 0.375000000000002 0.750000000000003,-1.94006250638909 0.485960359806531 0.312500000000002 0.625000000000004,-1.96157056080646 0.39018064403226 0.250000000000002 0.500000000000004,-1.97835301992956 0.293460948910727 0.187500000000002 0.375000000000004,-1.99036945334439 0.196034280659125 0.125000000000002 0.250000000000005,-1.99759091241034 0.0981353486548404 0.0625000000000026 0.125000000000005,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
> ST_CurveToLine-401|MULTIPOLYGON(((-2 0,-1.92387953251129 -0.38268343236509,-1.70710678118655 -0.707106781186548,-1.38268343236509 -0.923879532511287,-1 -1,-0.61731656763491 -0.923879532511287,-0.292893218813452 -0.707106781186547,-0.0761204674887133 -0.38268343236509,0 0,0.0761204674887133 -0.38268343236509,0.292893218813453 -0.707106781186548,0.61731656763491 -0.923879532511287,1 -1,1.38268343236509 -0.923879532511287,1.70710678118655 -0.707106781186547,1.92387953251129 -0.38268343236509,2 0,1.84775906502257 0.76536686473018,1.4142135623731 1.41421356237309,0.76536686473018 1.84775906502257,1.22460635382238e-16 2,-0.765366864730179 1.84775906502257,-1.41421356237309 1.4142135623731,-1.84775906502257 0.76536686473018,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
> ST_CurveToLine-402|MULTIPOLYGONM(((-2 0 0,-1.92387953251129 -0.38268343236509 0.5,-1.70710678118655 -0.707106781186548 1,-1.38268343236509 -0.923879532511287 1.5,-1 -1 2,-0.61731656763491 -0.923879532511287 2.5,-0.292893218813452 -0.707106781186547 3,-0.0761204674887133 -0.38268343236509 3.5,0 0 4,0.0761204674887133 -0.38268343236509 4.5,0.292893218813453 -0.707106781186548 5,0.61731656763491 -0.923879532511287 5.5,1 -1 6,1.38268343236509 -0.923879532511287 6.5,1.70710678118655 -0.707106781186547 7,1.92387953251129 -0.38268343236509 7.5,2 0 8,1.84775906502257 0.76536686473018 7,1.4142135623731 1.41421356237309 6,0.76536686473018 1.84775906502257 5,1.22460635382238e-16 2 4,-0.765366864730179 1.84775906502257 3,-1.41421356237309 1.4142135623731 2,-1.84775906502257 0.76536686473018 1,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
> ST_CurveToLine-403|MULTIPOLYGON(((-2 0 0,-1.92387953251129 -0.38268343236509 0.25,-1.70710678118655 -0.707106781186548 0.5,-1.38268343236509 -0.923879532511287 0.75,-1 -1 1,-0.61731656763491 -0.923879532511287 1.25,-0.292893218813452 -0.707106781186547 1.5,-0.0761204674887133 -0.38268343236509 1.75,0 0 2,0.0761204674887133 -0.38268343236509 2.25,0.292893218813453 -0.707106781186548 2.5,0.61731656763491 -0.923879532511287 2.75,1 -1 3,1.38268343236509 -0.923879532511287 3.25,1.70710678118655 -0.707106781186547 3.5,1.92387953251129 -0.38268343236509 3.75,2 0 4,1.84775906502257 0.76536686473018 3.5,1.4142135623731 1.41421356237309 3,0.76536686473018 1.84775906502257 2.5,1.22460635382238e-16 2 2,-0.765366864730179 1.84775906502257 1.5,-1.41421356237309 1.4142135623731 1,-1.84775906502257 0.76536686473018 0.5,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
> ST_CurveToLine-404|MULTIPOLYGON(((-2 0 0 0,-1.92387953251129 -0.38268343236509 0.25 0.5,-1.70710678118655 -0.707106781186548 0.5 1,-1.38268343236509 -0.923879532511287 0.75 1.5,-1 -1 1 2,-0.61731656763491 -0.923879532511287 1.25 2.5,-0.292893218813452 -0.707106781186547 1.5 3,-0.0761204674887133 -0.38268343236509 1.75 3.5,0 0 2 4,0.0761204674887133 -0.38268343236509 2.25 4.5,0.292893218813453 -0.707106781186548 2.5 5,0.61731656763491 -0.923879532511287 2.75 5.5,1 -1 3 6,1.38268343236509 -0.923879532511287 3.25 6.5,1.70710678118655 -0.707106781186547 3.5 7,1.92387953251129 -0.38268343236509 3.75 7.5,2 0 4 8,1.84775906502257 0.76536686473018 3.5 7,1.4142135623731 1.41421356237309 3 6,0.76536686473018 1.84775906502257 2.5 5,1.22460635382238e-16 2 2 4,-0.765366864730179 1.84775906502257 1.5 3,-1.41421356237309 1.4142135623731 1 2,-1.84775906502257 0.76536686473018 0.5 1,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
> ST_CurveToLine01|MULTIPOLYGON(((-2 0,-1.99879545620517 -0.049067674327418,-1.9951847266722 -0.0980171403295604,-1.98917650996478 -0.146730474455361,-1.98078528040323 -0.195090322016128,-1.97003125319454 -0.242980179903263,-1.95694033573221 -0.290284677254462,-1.94154406518302 -0.336889853392219,-1.92387953251129 -0.382683432365089,-1.90398929312344 -0.427555093430281,-1.88192126434836 -0.471396736825996,-1.85772861000027 -0.51410274419322,-1.83146961230255 -0.555570233019601,-1.80320753148065 -0.595699304492432,-1.77301045336274 -0.634393284163644,-1.74095112535496 -0.671558954847017,-1.70710678118655 -0.707106781186546,-1.67155895484702 -0.740951125354957,-1.63439328416365 -0.773010453362735,-1.59569930449244 -0.803207531480643,-1.5555702330196 -0.831469612302543,-1.51410274419322 -0.85772861000027,-1.471396736826 -0.881921264348353,-1.42755509343029 -0.903989293123442,-1.38268343236509 -0.923879532511285,-1.33688985339222 -0.94154406518302,-1.29028467725447 -0.956940335732208,-1.24298017990327 -0.970031253194543,-1.19509032201613 -0.98078528040323,-1.14673047445537 -0.98917650996478,-1.09801714032956 -0.995184726672197,-1.04906767432742 -0.998795456205172,-1 -1,-0.950932325672585 -0.998795456205173,-0.901982859670443 -0.995184726672197,-0.853269525544641 -0.989176509964781,-0.804909677983875 -0.980785280403231,-0.757019820096739 -0.970031253194545,-0.70971532274554 -0.95694033573221,-0.663110146607783 -0.941544065183022,-0.617316567634913 -0.923879532511288,-0.57244490656972 -0.903989293123445,-0.528603263174005 -0.881921264348356,-0.485897255806781 -0.857728610000273,-0.4444297669804 -0.831469612302547,-0.404300695507569 -0.803207531480647,-0.365606715836356 -0.773010453362739,-0.328441045152983 -0.740951125354961,-0.292893218813454 -0.707106781186549,-0.259048874645042 -0.67155895484702,-0.226989546637264 -0.634393284163647,-0.196792468519356 -0.595699304492435,-0.168530387697456 -0.555570233019604,-0.142271389999729 -0.514102744193224,-0.118078735651646 -0.471396736826,-0.0960107068765576 -0.427555093430284,-0.076120467488714 -0.382683432365092,-0.05845593481698 -0.336889853392222,-0.0430596642677917 -0.290284677254464,-0.0299687468054566 -0.242980179903266,-0.01921471959677 -0.19509032201613,-0.0108234900352193 -0.146730474455364,-0.00481527332780329 -0.0980171403295628,-0.00120454379482771 -0.0490676743274202,0 0,0.0012045437948276 -0.049067674327418,0.00481527332780307 -0.0980171403295604,0.010823490035219 -0.146730474455361,0.0192147195967695 -0.195090322016128,0.0299687468054558 -0.242980179903263,0.0430596642677908 -0.290284677254462,0.0584559348169789 -0.336889853392219,0.0761204674887128 -0.382683432365089,0.0960107068765561 -0.427555093430281,0.118078735651644 -0.471396736825996,0.142271389999727 -0.51410274419322,0.168530387697454 -0.555570233019601,0.196792468519354 -0.595699304492432,0.226989546637262 -0.634393284163644,0.259048874645039 -0.671558954847017,0.292893218813451 -0.707106781186546,0.32844104515298 -0.740951125354957,0.365606715836352 -0.773010453362735,0.404300695507564 -0.803207531480643,0.444429766980395 -0.831469612302543,0.485897255806775 -0.85772861000027,0.528603263173999 -0.881921264348353,0.572444906569715 -0.903989293123442,0.617316567634907 -0.923879532511285,0.663110146607776 -0.94154406518302,0.709715322745534 -0.956940335732208,0.757019820096733 -0.970031253194543,0.804909677983868 -0.98078528040323,0.853269525544635 -0.98917650996478,0.901982859670436 -0.995184726672197,0.950932325672579 -0.998795456205172,0.999999999999997 -1,1.04906767432741 -0.998795456205173,1.09801714032956 -0.995184726672197,1.14673047445536 -0.989176509964781,1.19509032201613 -0.980785280403231,1.24298017990326 -0.970031253194545,1.29028467725446 -0.95694033573221,1.33688985339222 -0.941544065183022,1.38268343236509 -0.923879532511288,1.42755509343028 -0.903989293123445,1.471396736826 -0.881921264348356,1.51410274419322 -0.857728610000273,1.5555702330196 -0.831469612302547,1.59569930449243 -0.803207531480647,1.63439328416364 -0.773010453362739,1.67155895484702 -0.740951125354961,1.70710678118655 -0.707106781186549,1.74095112535496 -0.67155895484702,1.77301045336274 -0.634393284163647,1.80320753148064 -0.595699304492435,1.83146961230254 -0.555570233019604,1.85772861000027 -0.514102744193224,1.88192126434835 -0.471396736826,1.90398929312344 -0.427555093430284,1.92387953251129 -0.382683432365092,1.94154406518302 -0.336889853392222,1.95694033573221 -0.290284677254464,1.97003125319454 -0.242980179903266,1.98078528040323 -0.19509032201613,1.98917650996478 -0.146730474455364,1.9951847266722 -0.0980171403295628,1.99879545620517 -0.0490676743274202,2 0,1.99759091241034 0.098135348654836,1.99036945334439 0.196034280659121,1.97835301992956 0.293460948910724,1.96157056080646 0.390180644032257,1.94006250638909 0.485960359806528,1.91388067146442 0.580569354508925,1.88308813036604 0.67377970678444,1.84775906502257 0.76536686473018,1.80797858624689 0.855110186860564,1.76384252869671 0.942793473651995,1.71545722000054 1.02820548838644,1.66293922460509 1.1111404660392,1.60641506296129 1.19139860898487,1.54602090672547 1.26878656832729,1.48190225070992 1.34311790969404,1.41421356237309 1.4142135623731,1.34311790969404 1.48190225070992,1.26878656832729 1.54602090672547,1.19139860898487 1.60641506296129,1.1111404660392 1.66293922460509,1.02820548838644 1.71545722000054,0.942793473651994 1.76384252869671,0.855110186860563 1.80797858624689,0.765366864730178 1.84775906502257,0.673779706784439 1.88308813036604,0.580569354508923 1.91388067146442,0.485960359806526 1.94006250638909,0.390180644032255 1.96157056080646,0.293460948910722 1.97835301992956,0.196034280659119 1.99036945334439,0.098135348654834 1.99759091241034,-2.09798541386808e-15 2,-0.0981353486548382 1.99759091241034,-0.196034280659124 1.99036945334439,-0.293460948910726 1.97835301992956,-0.390180644032259 1.96157056080646,-0.48596035980653 1.94006250638909,-0.580569354508927 1.91388067146442,-0.673779706784443 1.88308813036604,-0.765366864730182 1.84775906502257,-0.855110186860567 1.80797858624689,-0.942793473651998 1.76384252869671,-1.02820548838645 1.71545722000054,-1.11114046603921 1.66293922460509,-1.19139860898487 1.60641506296129,-1.26878656832729 1.54602090672547,-1.34311790969404 1.48190225070992,-1.4142135623731 1.41421356237309,-1.48190225070992 1.34311790969404,-1.54602090672547 1.26878656832729,-1.60641506296129 1.19139860898487,-1.66293922460509 1.11114046603921,-1.71545722000054 1.02820548838644,-1.76384252869671 0.942793473651997,-1.80797858624689 0.855110186860566,-1.84775906502257 0.765366864730181,-1.88308813036604 0.673779706784442,-1.91388067146442 0.580569354508927,-1.94006250638909 0.485960359806531,-1.96157056080646 0.39018064403226,-1.97835301992956 0.293460948910727,-1.99036945334439 0.196034280659125,-1.99759091241034 0.0981353486548404,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))
> ST_CurveToLine02|MULTIPOLYGONM(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.125,-1.98917650996478 -0.146730474455361 0.187499999999999,-1.98078528040323 -0.195090322016128 0.249999999999999,-1.97003125319454 -0.242980179903263 0.312499999999999,-1.95694033573221 -0.290284677254462 0.374999999999999,-1.94154406518302 -0.336889853392219 0.437499999999999,-1.92387953251129 -0.382683432365089 0.499999999999998,-1.90398929312344 -0.427555093430281 0.562499999999998,-1.88192126434836 -0.471396736825996 0.624999999999998,-1.85772861000027 -0.51410274419322 0.687499999999998,-1.83146961230255 -0.555570233019601 0.749999999999997,-1.80320753148065 -0.595699304492432 0.812499999999997,-1.77301045336274 -0.634393284163644 0.874999999999997,-1.74095112535496 -0.671558954847017 0.937499999999997,-1.70710678118655 -0.707106781186546 0.999999999999997,-1.67155895484702 -0.740951125354957 1.0625,-1.63439328416365 -0.773010453362735 1.125,-1.59569930449244 -0.803207531480643 1.1875,-1.5555702330196 -0.831469612302543 1.25,-1.51410274419322 -0.85772861000027 1.3125,-1.471396736826 -0.881921264348353 1.375,-1.42755509343029 -0.903989293123442 1.4375,-1.38268343236509 -0.923879532511285 1.5,-1.33688985339222 -0.94154406518302 1.5625,-1.29028467725447 -0.956940335732208 1.625,-1.24298017990327 -0.970031253194543 1.6875,-1.19509032201613 -0.98078528040323 1.75,-1.14673047445537 -0.98917650996478 1.8125,-1.09801714032956 -0.995184726672197 1.875,-1.04906767432742 -0.998795456205172 1.9375,-1 -1 2,-0.950932325672585 -0.998795456205173 2.0625,-0.901982859670443 -0.995184726672197 2.125,-0.853269525544641 -0.989176509964781 2.1875,-0.804909677983875 -0.980785280403231 2.25,-0.757019820096739 -0.970031253194545 2.3125,-0.70971532274554 -0.95694033573221 2.375,-0.663110146607783 -0.941544065183022 2.4375,-0.617316567634913 -0.923879532511288 2.5,-0.57244490656972 -0.903989293123445 2.5625,-0.528603263174005 -0.881921264348356 2.625,-0.485897255806781 -0.857728610000273 2.6875,-0.4444297669804 -0.831469612302547 2.75,-0.404300695507569 -0.803207531480647 2.8125,-0.365606715836356 -0.773010453362739 2.875,-0.328441045152983 -0.740951125354961 2.9375,-0.292893218813454 -0.707106781186549 3,-0.259048874645042 -0.67155895484702 3.0625,-0.226989546637264 -0.634393284163647 3.125,-0.196792468519356 -0.595699304492435 3.1875,-0.168530387697456 -0.555570233019604 3.25,-0.142271389999729 -0.514102744193224 3.3125,-0.118078735651646 -0.471396736826 3.375,-0.0960107068765576 -0.427555093430284 3.4375,-0.076120467488714 -0.382683432365092 3.5,-0.05845593481698 -0.336889853392222 3.5625,-0.0430596642677917 -0.290284677254464 3.625,-0.0299687468054566 -0.242980179903266 3.6875,-0.01921471959677 -0.19509032201613 3.75,-0.0108234900352193 -0.146730474455364 3.8125,-0.00481527332780329 -0.0980171403295628 3.875,-0.00120454379482771 -0.0490676743274202 3.9375,0 0 4,0.0012045437948276 -0.049067674327418 4.0625,0.00481527332780307 -0.0980171403295604 4.125,0.010823490035219 -0.146730474455361 4.1875,0.0192147195967695 -0.195090322016128 4.25,0.0299687468054558 -0.242980179903263 4.3125,0.0430596642677908 -0.290284677254462 4.375,0.0584559348169789 -0.336889853392219 4.4375,0.0761204674887128 -0.382683432365089 4.5,0.0960107068765561 -0.427555093430281 4.5625,0.118078735651644 -0.471396736825996 4.625,0.142271389999727 -0.51410274419322 4.6875,0.168530387697454 -0.555570233019601 4.75,0.196792468519354 -0.595699304492432 4.8125,0.226989546637262 -0.634393284163644 4.875,0.259048874645039 -0.671558954847017 4.9375,0.292893218813451 -0.707106781186546 5,0.32844104515298 -0.740951125354957 5.0625,0.365606715836352 -0.773010453362735 5.125,0.404300695507564 -0.803207531480643 5.1875,0.444429766980395 -0.831469612302543 5.25,0.485897255806775 -0.85772861000027 5.3125,0.528603263173999 -0.881921264348353 5.375,0.572444906569715 -0.903989293123442 5.4375,0.617316567634907 -0.923879532511285 5.5,0.663110146607776 -0.94154406518302 5.5625,0.709715322745534 -0.956940335732208 5.625,0.757019820096733 -0.970031253194543 5.6875,0.804909677983868 -0.98078528040323 5.75,0.853269525544635 -0.98917650996478 5.8125,0.901982859670436 -0.995184726672197 5.875,0.950932325672579 -0.998795456205172 5.9375,0.999999999999997 -1 6,1.04906767432741 -0.998795456205173 6.0625,1.09801714032956 -0.995184726672197 6.125,1.14673047445536 -0.989176509964781 6.1875,1.19509032201613 -0.980785280403231 6.25,1.24298017990326 -0.970031253194545 6.3125,1.29028467725446 -0.95694033573221 6.375,1.33688985339222 -0.941544065183022 6.4375,1.38268343236509 -0.923879532511288 6.5,1.42755509343028 -0.903989293123445 6.5625,1.471396736826 -0.881921264348356 6.625,1.51410274419322 -0.857728610000273 6.6875,1.5555702330196 -0.831469612302547 6.75,1.59569930449243 -0.803207531480647 6.8125,1.63439328416364 -0.773010453362739 6.875,1.67155895484702 -0.740951125354961 6.9375,1.70710678118655 -0.707106781186549 7,1.74095112535496 -0.67155895484702 7.0625,1.77301045336274 -0.634393284163647 7.125,1.80320753148064 -0.595699304492435 7.1875,1.83146961230254 -0.555570233019604 7.25,1.85772861000027 -0.514102744193224 7.3125,1.88192126434835 -0.471396736826 7.375,1.90398929312344 -0.427555093430284 7.4375,1.92387953251129 -0.382683432365092 7.5,1.94154406518302 -0.336889853392222 7.5625,1.95694033573221 -0.290284677254464 7.625,1.97003125319454 -0.242980179903266 7.6875,1.98078528040323 -0.19509032201613 7.75,1.98917650996478 -0.146730474455364 7.8125,1.9951847266722 -0.0980171403295628 7.875,1.99879545620517 -0.0490676743274202 7.9375,2 0 8,1.99759091241034 0.098135348654836 7.875,1.99036945334439 0.196034280659121 7.75,1.97835301992956 0.293460948910724 7.625,1.96157056080646 0.390180644032257 7.5,1.94006250638909 0.485960359806528 7.375,1.91388067146442 0.580569354508925 7.25,1.88308813036604 0.67377970678444 7.125,1.84775906502257 0.76536686473018 7,1.80797858624689 0.855110186860564 6.875,1.76384252869671 0.942793473651995 6.75,1.71545722000054 1.02820548838644 6.625,1.66293922460509 1.1111404660392 6.5,1.60641506296129 1.19139860898487 6.375,1.54602090672547 1.26878656832729 6.25,1.48190225070992 1.34311790969404 6.125,1.41421356237309 1.4142135623731 6,1.34311790969404 1.48190225070992 5.875,1.26878656832729 1.54602090672547 5.75,1.19139860898487 1.60641506296129 5.625,1.1111404660392 1.66293922460509 5.5,1.02820548838644 1.71545722000054 5.375,0.942793473651994 1.76384252869671 5.25,0.855110186860563 1.80797858624689 5.125,0.765366864730178 1.84775906502257 5,0.673779706784439 1.88308813036604 4.875,0.580569354508923 1.91388067146442 4.75,0.485960359806526 1.94006250638909 4.625,0.390180644032255 1.96157056080646 4.5,0.293460948910722 1.97835301992956 4.375,0.196034280659119 1.99036945334439 4.25,0.098135348654834 1.99759091241034 4.125,-2.09798541386808e-15 2 4,-0.0981353486548382 1.99759091241034 3.875,-0.196034280659124 1.99036945334439 3.75,-0.293460948910726 1.97835301992956 3.625,-0.390180644032259 1.96157056080646 3.5,-0.48596035980653 1.94006250638909 3.375,-0.580569354508927 1.91388067146442 3.25,-0.673779706784443 1.88308813036604 3.125,-0.765366864730182 1.84775906502257 3,-0.855110186860567 1.80797858624689 2.875,-0.942793473651998 1.76384252869671 2.75,-1.02820548838645 1.71545722000054 2.625,-1.11114046603921 1.66293922460509 2.5,-1.19139860898487 1.60641506296129 2.375,-1.26878656832729 1.54602090672547 2.25,-1.34311790969404 1.48190225070992 2.125,-1.4142135623731 1.41421356237309 2,-1.48190225070992 1.34311790969404 1.875,-1.54602090672547 1.26878656832729 1.75,-1.60641506296129 1.19139860898487 1.625,-1.66293922460509 1.11114046603921 1.5,-1.71545722000054 1.02820548838644 1.375,-1.76384252869671 0.942793473651997 1.25,-1.80797858624689 0.855110186860566 1.125,-1.84775906502257 0.765366864730181 1,-1.88308813036604 0.673779706784442 0.875000000000003,-1.91388067146442 0.580569354508927 0.750000000000003,-1.94006250638909 0.485960359806531 0.625000000000004,-1.96157056080646 0.39018064403226 0.500000000000004,-1.97835301992956 0.293460948910727 0.375000000000004,-1.99036945334439 0.196034280659125 0.250000000000005,-1.99759091241034 0.0981353486548404 0.125000000000005,-2 0 0),(-1 0 2,0 0.5 4,1 0 6,0 1 4,-1 0 2)),((7 8 8,10 10 5,6 14 1,4 11 6,7 8 8)))
> ST_CurveToLine03|MULTIPOLYGON(((-2 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999,-1.9951847266722 -0.0980171403295604 0.0624999999999998,-1.98917650996478 -0.146730474455361 0.0937499999999997,-1.98078528040323 -0.195090322016128 0.125,-1.97003125319454 -0.242980179903263 0.156249999999999,-1.95694033573221 -0.290284677254462 0.187499999999999,-1.94154406518302 -0.336889853392219 0.218749999999999,-1.92387953251129 -0.382683432365089 0.249999999999999,-1.90398929312344 -0.427555093430281 0.281249999999999,-1.88192126434836 -0.471396736825996 0.312499999999999,-1.85772861000027 -0.51410274419322 0.343749999999999,-1.83146961230255 -0.555570233019601 0.374999999999999,-1.80320753148065 -0.595699304492432 0.406249999999999,-1.77301045336274 -0.634393284163644 0.437499999999999,-1.74095112535496 -0.671558954847017 0.468749999999998,-1.70710678118655 -0.707106781186546 0.499999999999998,-1.67155895484702 -0.740951125354957 0.531249999999998,-1.63439328416365 -0.773010453362735 0.562499999999998,-1.59569930449244 -0.803207531480643 0.593749999999998,-1.5555702330196 -0.831469612302543 0.624999999999998,-1.51410274419322 -0.85772861000027 0.656249999999998,-1.471396736826 -0.881921264348353 0.687499999999998,-1.42755509343029 -0.903989293123442 0.718749999999998,-1.38268343236509 -0.923879532511285 0.749999999999998,-1.33688985339222 -0.94154406518302 0.781249999999998,-1.29028467725447 -0.956940335732208 0.812499999999998,-1.24298017990327 -0.970031253194543 0.843749999999998,-1.19509032201613 -0.98078528040323 0.874999999999998,-1.14673047445537 -0.98917650996478 0.906249999999998,-1.09801714032956 -0.995184726672197 0.937499999999998,-1.04906767432742 -0.998795456205172 0.968749999999998,-1 -1 0.999999999999998,-0.950932325672585 -0.998795456205173 1.03125,-0.901982859670443 -0.995184726672197 1.0625,-0.853269525544641 -0.989176509964781 1.09375,-0.804909677983875 -0.980785280403231 1.125,-0.757019820096739 -0.970031253194545 1.15625,-0.70971532274554 -0.95694033573221 1.1875,-0.663110146607783 -0.941544065183022 1.21875,-0.617316567634913 -0.923879532511288 1.25,-0.57244490656972 -0.903989293123445 1.28125,-0.528603263174005 -0.881921264348356 1.3125,-0.485897255806781 -0.857728610000273 1.34375,-0.4444297669804 -0.831469612302547 1.375,-0.404300695507569 -0.803207531480647 1.40625,-0.365606715836356 -0.773010453362739 1.4375,-0.328441045152983 -0.740951125354961 1.46875,-0.292893218813454 -0.707106781186549 1.5,-0.259048874645042 -0.67155895484702 1.53125,-0.226989546637264 -0.634393284163647 1.5625,-0.196792468519356 -0.595699304492435 1.59375,-0.168530387697456 -0.555570233019604 1.625,-0.142271389999729 -0.514102744193224 1.65625,-0.118078735651646 -0.471396736826 1.6875,-0.0960107068765576 -0.427555093430284 1.71875,-0.076120467488714 -0.382683432365092 1.75,-0.05845593481698 -0.336889853392222 1.78125,-0.0430596642677917 -0.290284677254464 1.8125,-0.0299687468054566 -0.242980179903266 1.84375,-0.01921471959677 -0.19509032201613 1.875,-0.0108234900352193 -0.146730474455364 1.90625,-0.00481527332780329 -0.0980171403295628 1.9375,-0.00120454379482771 -0.0490676743274202 1.96875,0 0 2,0.0012045437948276 -0.049067674327418 2.03125,0.00481527332780307 -0.0980171403295604 2.0625,0.010823490035219 -0.146730474455361 2.09375,0.0192147195967695 -0.195090322016128 2.125,0.0299687468054558 -0.242980179903263 2.15625,0.0430596642677908 -0.290284677254462 2.1875,0.0584559348169789 -0.336889853392219 2.21875,0.0761204674887128 -0.382683432365089 2.25,0.0960107068765561 -0.427555093430281 2.28125,0.118078735651644 -0.471396736825996 2.3125,0.142271389999727 -0.51410274419322 2.34375,0.168530387697454 -0.555570233019601 2.375,0.196792468519354 -0.595699304492432 2.40625,0.226989546637262 -0.634393284163644 2.4375,0.259048874645039 -0.671558954847017 2.46875,0.292893218813451 -0.707106781186546 2.5,0.32844104515298 -0.740951125354957 2.53125,0.365606715836352 -0.773010453362735 2.5625,0.404300695507564 -0.803207531480643 2.59375,0.444429766980395 -0.831469612302543 2.625,0.485897255806775 -0.85772861000027 2.65625,0.528603263173999 -0.881921264348353 2.6875,0.572444906569715 -0.903989293123442 2.71875,0.617316567634907 -0.923879532511285 2.75,0.663110146607776 -0.94154406518302 2.78125,0.709715322745534 -0.956940335732208 2.8125,0.757019820096733 -0.970031253194543 2.84375,0.804909677983868 -0.98078528040323 2.875,0.853269525544635 -0.98917650996478 2.90625,0.901982859670436 -0.995184726672197 2.9375,0.950932325672579 -0.998795456205172 2.96875,0.999999999999997 -1 3,1.04906767432741 -0.998795456205173 3.03125,1.09801714032956 -0.995184726672197 3.0625,1.14673047445536 -0.989176509964781 3.09375,1.19509032201613 -0.980785280403231 3.125,1.24298017990326 -0.970031253194545 3.15625,1.29028467725446 -0.95694033573221 3.1875,1.33688985339222 -0.941544065183022 3.21875,1.38268343236509 -0.923879532511288 3.25,1.42755509343028 -0.903989293123445 3.28125,1.471396736826 -0.881921264348356 3.3125,1.51410274419322 -0.857728610000273 3.34375,1.5555702330196 -0.831469612302547 3.375,1.59569930449243 -0.803207531480647 3.40625,1.63439328416364 -0.773010453362739 3.4375,1.67155895484702 -0.740951125354961 3.46875,1.70710678118655 -0.707106781186549 3.5,1.74095112535496 -0.67155895484702 3.53125,1.77301045336274 -0.634393284163647 3.5625,1.80320753148064 -0.595699304492435 3.59375,1.83146961230254 -0.555570233019604 3.625,1.85772861000027 -0.514102744193224 3.65625,1.88192126434835 -0.471396736826 3.6875,1.90398929312344 -0.427555093430284 3.71875,1.92387953251129 -0.382683432365092 3.75,1.94154406518302 -0.336889853392222 3.78125,1.95694033573221 -0.290284677254464 3.8125,1.97003125319454 -0.242980179903266 3.84375,1.98078528040323 -0.19509032201613 3.875,1.98917650996478 -0.146730474455364 3.90625,1.9951847266722 -0.0980171403295628 3.9375,1.99879545620517 -0.0490676743274202 3.96875,2 0 4,1.99759091241034 0.098135348654836 3.9375,1.99036945334439 0.196034280659121 3.875,1.97835301992956 0.293460948910724 3.8125,1.96157056080646 0.390180644032257 3.75,1.94006250638909 0.485960359806528 3.6875,1.91388067146442 0.580569354508925 3.625,1.88308813036604 0.67377970678444 3.5625,1.84775906502257 0.76536686473018 3.5,1.80797858624689 0.855110186860564 3.4375,1.76384252869671 0.942793473651995 3.375,1.71545722000054 1.02820548838644 3.3125,1.66293922460509 1.1111404660392 3.25,1.60641506296129 1.19139860898487 3.1875,1.54602090672547 1.26878656832729 3.125,1.48190225070992 1.34311790969404 3.0625,1.41421356237309 1.4142135623731 3,1.34311790969404 1.48190225070992 2.9375,1.26878656832729 1.54602090672547 2.875,1.19139860898487 1.60641506296129 2.8125,1.1111404660392 1.66293922460509 2.75,1.02820548838644 1.71545722000054 2.6875,0.942793473651994 1.76384252869671 2.625,0.855110186860563 1.80797858624689 2.5625,0.765366864730178 1.84775906502257 2.5,0.673779706784439 1.88308813036604 2.4375,0.580569354508923 1.91388067146442 2.375,0.485960359806526 1.94006250638909 2.3125,0.390180644032255 1.96157056080646 2.25,0.293460948910722 1.97835301992956 2.1875,0.196034280659119 1.99036945334439 2.125,0.098135348654834 1.99759091241034 2.0625,-2.09798541386808e-15 2 2,-0.0981353486548382 1.99759091241034 1.9375,-0.196034280659124 1.99036945334439 1.875,-0.293460948910726 1.97835301992956 1.8125,-0.390180644032259 1.96157056080646 1.75,-0.48596035980653 1.94006250638909 1.6875,-0.580569354508927 1.91388067146442 1.625,-0.673779706784443 1.88308813036604 1.5625,-0.765366864730182 1.84775906502257 1.5,-0.855110186860567 1.80797858624689 1.4375,-0.942793473651998 1.76384252869671 1.375,-1.02820548838645 1.71545722000054 1.3125,-1.11114046603921 1.66293922460509 1.25,-1.19139860898487 1.60641506296129 1.1875,-1.26878656832729 1.54602090672547 1.125,-1.34311790969404 1.48190225070992 1.0625,-1.4142135623731 1.41421356237309 0.999999999999999,-1.48190225070992 1.34311790969404 0.9375,-1.54602090672547 1.26878656832729 0.875,-1.60641506296129 1.19139860898487 0.8125,-1.66293922460509 1.11114046603921 0.75,-1.71545722000054 1.02820548838644 0.6875,-1.76384252869671 0.942793473651997 0.625000000000001,-1.80797858624689 0.855110186860566 0.562500000000001,-1.84775906502257 0.765366864730181 0.500000000000001,-1.88308813036604 0.673779706784442 0.437500000000001,-1.91388067146442 0.580569354508927 0.375000000000002,-1.94006250638909 0.485960359806531 0.312500000000002,-1.96157056080646 0.39018064403226 0.250000000000002,-1.97835301992956 0.293460948910727 0.187500000000002,-1.99036945334439 0.196034280659125 0.125000000000002,-1.99759091241034 0.0981353486548404 0.0625000000000026,-2 0 0),(-1 0 1,0 0.5 2,1 0 3,0 1 3,-1 0 1)),((7 8 7,10 10 5,6 14 3,4 11 4,7 8 7)))
> ST_CurveToLine04|MULTIPOLYGON(((-2 0 0 0,-1.99879545620517 -0.049067674327418 0.0312499999999999 0.0624999999999998,-1.9951847266722 -0.0980171403295604 0.0624999999999998 0.125,-1.98917650996478 -0.146730474455361 0.0937499999999997 0.187499999999999,-1.98078528040323 -0.195090322016128 0.125 0.249999999999999,-1.97003125319454 -0.242980179903263 0.156249999999999 0.312499999999999,-1.95694033573221 -0.290284677254462 0.187499999999999 0.374999999999999,-1.94154406518302 -0.336889853392219 0.218749999999999 0.437499999999999,-1.92387953251129 -0.382683432365089 0.249999999999999 0.499999999999998,-1.90398929312344 -0.427555093430281 0.281249999999999 0.562499999999998,-1.88192126434836 -0.471396736825996 0.312499999999999 0.624999999999998,-1.85772861000027 -0.51410274419322 0.343749999999999 0.687499999999998,-1.83146961230255 -0.555570233019601 0.374999999999999 0.749999999999997,-1.80320753148065 -0.595699304492432 0.406249999999999 0.812499999999997,-1.77301045336274 -0.634393284163644 0.437499999999999 0.874999999999997,-1.74095112535496 -0.671558954847017 0.468749999999998 0.937499999999997,-1.70710678118655 -0.707106781186546 0.499999999999998 0.999999999999997,-1.67155895484702 -0.740951125354957 0.531249999999998 1.0625,-1.63439328416365 -0.773010453362735 0.562499999999998 1.125,-1.59569930449244 -0.803207531480643 0.593749999999998 1.1875,-1.5555702330196 -0.831469612302543 0.624999999999998 1.25,-1.51410274419322 -0.85772861000027 0.656249999999998 1.3125,-1.471396736826 -0.881921264348353 0.687499999999998 1.375,-1.42755509343029 -0.903989293123442 0.718749999999998 1.4375,-1.38268343236509 -0.923879532511285 0.749999999999998 1.5,-1.33688985339222 -0.94154406518302 0.781249999999998 1.5625,-1.29028467725447 -0.956940335732208 0.812499999999998 1.625,-1.24298017990327 -0.970031253194543 0.843749999999998 1.6875,-1.19509032201613 -0.98078528040323 0.874999999999998 1.75,-1.14673047445537 -0.98917650996478 0.906249999999998 1.8125,-1.09801714032956 -0.995184726672197 0.937499999999998 1.875,-1.04906767432742 -0.998795456205172 0.968749999999998 1.9375,-1 -1 0.999999999999998 2,-0.950932325672585 -0.998795456205173 1.03125 2.0625,-0.901982859670443 -0.995184726672197 1.0625 2.125,-0.853269525544641 -0.989176509964781 1.09375 2.1875,-0.804909677983875 -0.980785280403231 1.125 2.25,-0.757019820096739 -0.970031253194545 1.15625 2.3125,-0.70971532274554 -0.95694033573221 1.1875 2.375,-0.663110146607783 -0.941544065183022 1.21875 2.4375,-0.617316567634913 -0.923879532511288 1.25 2.5,-0.57244490656972 -0.903989293123445 1.28125 2.5625,-0.528603263174005 -0.881921264348356 1.3125 2.625,-0.485897255806781 -0.857728610000273 1.34375 2.6875,-0.4444297669804 -0.831469612302547 1.375 2.75,-0.404300695507569 -0.803207531480647 1.40625 2.8125,-0.365606715836356 -0.773010453362739 1.4375 2.875,-0.328441045152983 -0.740951125354961 1.46875 2.9375,-0.292893218813454 -0.707106781186549 1.5 3,-0.259048874645042 -0.67155895484702 1.53125 3.0625,-0.226989546637264 -0.634393284163647 1.5625 3.125,-0.196792468519356 -0.595699304492435 1.59375 3.1875,-0.168530387697456 -0.555570233019604 1.625 3.25,-0.142271389999729 -0.514102744193224 1.65625 3.3125,-0.118078735651646 -0.471396736826 1.6875 3.375,-0.0960107068765576 -0.427555093430284 1.71875 3.4375,-0.076120467488714 -0.382683432365092 1.75 3.5,-0.05845593481698 -0.336889853392222 1.78125 3.5625,-0.0430596642677917 -0.290284677254464 1.8125 3.625,-0.0299687468054566 -0.242980179903266 1.84375 3.6875,-0.01921471959677 -0.19509032201613 1.875 3.75,-0.0108234900352193 -0.146730474455364 1.90625 3.8125,-0.00481527332780329 -0.0980171403295628 1.9375 3.875,-0.00120454379482771 -0.0490676743274202 1.96875 3.9375,0 0 2 4,0.0012045437948276 -0.049067674327418 2.03125 4.0625,0.00481527332780307 -0.0980171403295604 2.0625 4.125,0.010823490035219 -0.146730474455361 2.09375 4.1875,0.0192147195967695 -0.195090322016128 2.125 4.25,0.0299687468054558 -0.242980179903263 2.15625 4.3125,0.0430596642677908 -0.290284677254462 2.1875 4.375,0.0584559348169789 -0.336889853392219 2.21875 4.4375,0.0761204674887128 -0.382683432365089 2.25 4.5,0.0960107068765561 -0.427555093430281 2.28125 4.5625,0.118078735651644 -0.471396736825996 2.3125 4.625,0.142271389999727 -0.51410274419322 2.34375 4.6875,0.168530387697454 -0.555570233019601 2.375 4.75,0.196792468519354 -0.595699304492432 2.40625 4.8125,0.226989546637262 -0.634393284163644 2.4375 4.875,0.259048874645039 -0.671558954847017 2.46875 4.9375,0.292893218813451 -0.707106781186546 2.5 5,0.32844104515298 -0.740951125354957 2.53125 5.0625,0.365606715836352 -0.773010453362735 2.5625 5.125,0.404300695507564 -0.803207531480643 2.59375 5.1875,0.444429766980395 -0.831469612302543 2.625 5.25,0.485897255806775 -0.85772861000027 2.65625 5.3125,0.528603263173999 -0.881921264348353 2.6875 5.375,0.572444906569715 -0.903989293123442 2.71875 5.4375,0.617316567634907 -0.923879532511285 2.75 5.5,0.663110146607776 -0.94154406518302 2.78125 5.5625,0.709715322745534 -0.956940335732208 2.8125 5.625,0.757019820096733 -0.970031253194543 2.84375 5.6875,0.804909677983868 -0.98078528040323 2.875 5.75,0.853269525544635 -0.98917650996478 2.90625 5.8125,0.901982859670436 -0.995184726672197 2.9375 5.875,0.950932325672579 -0.998795456205172 2.96875 5.9375,0.999999999999997 -1 3 6,1.04906767432741 -0.998795456205173 3.03125 6.0625,1.09801714032956 -0.995184726672197 3.0625 6.125,1.14673047445536 -0.989176509964781 3.09375 6.1875,1.19509032201613 -0.980785280403231 3.125 6.25,1.24298017990326 -0.970031253194545 3.15625 6.3125,1.29028467725446 -0.95694033573221 3.1875 6.375,1.33688985339222 -0.941544065183022 3.21875 6.4375,1.38268343236509 -0.923879532511288 3.25 6.5,1.42755509343028 -0.903989293123445 3.28125 6.5625,1.471396736826 -0.881921264348356 3.3125 6.625,1.51410274419322 -0.857728610000273 3.34375 6.6875,1.5555702330196 -0.831469612302547 3.375 6.75,1.59569930449243 -0.803207531480647 3.40625 6.8125,1.63439328416364 -0.773010453362739 3.4375 6.875,1.67155895484702 -0.740951125354961 3.46875 6.9375,1.70710678118655 -0.707106781186549 3.5 7,1.74095112535496 -0.67155895484702 3.53125 7.0625,1.77301045336274 -0.634393284163647 3.5625 7.125,1.80320753148064 -0.595699304492435 3.59375 7.1875,1.83146961230254 -0.555570233019604 3.625 7.25,1.85772861000027 -0.514102744193224 3.65625 7.3125,1.88192126434835 -0.471396736826 3.6875 7.375,1.90398929312344 -0.427555093430284 3.71875 7.4375,1.92387953251129 -0.382683432365092 3.75 7.5,1.94154406518302 -0.336889853392222 3.78125 7.5625,1.95694033573221 -0.290284677254464 3.8125 7.625,1.97003125319454 -0.242980179903266 3.84375 7.6875,1.98078528040323 -0.19509032201613 3.875 7.75,1.98917650996478 -0.146730474455364 3.90625 7.8125,1.9951847266722 -0.0980171403295628 3.9375 7.875,1.99879545620517 -0.0490676743274202 3.96875 7.9375,2 0 4 8,1.99759091241034 0.098135348654836 3.9375 7.875,1.99036945334439 0.196034280659121 3.875 7.75,1.97835301992956 0.293460948910724 3.8125 7.625,1.96157056080646 0.390180644032257 3.75 7.5,1.94006250638909 0.485960359806528 3.6875 7.375,1.91388067146442 0.580569354508925 3.625 7.25,1.88308813036604 0.67377970678444 3.5625 7.125,1.84775906502257 0.76536686473018 3.5 7,1.80797858624689 0.855110186860564 3.4375 6.875,1.76384252869671 0.942793473651995 3.375 6.75,1.71545722000054 1.02820548838644 3.3125 6.625,1.66293922460509 1.1111404660392 3.25 6.5,1.60641506296129 1.19139860898487 3.1875 6.375,1.54602090672547 1.26878656832729 3.125 6.25,1.48190225070992 1.34311790969404 3.0625 6.125,1.41421356237309 1.4142135623731 3 6,1.34311790969404 1.48190225070992 2.9375 5.875,1.26878656832729 1.54602090672547 2.875 5.75,1.19139860898487 1.60641506296129 2.8125 5.625,1.1111404660392 1.66293922460509 2.75 5.5,1.02820548838644 1.71545722000054 2.6875 5.375,0.942793473651994 1.76384252869671 2.625 5.25,0.855110186860563 1.80797858624689 2.5625 5.125,0.765366864730178 1.84775906502257 2.5 5,0.673779706784439 1.88308813036604 2.4375 4.875,0.580569354508923 1.91388067146442 2.375 4.75,0.485960359806526 1.94006250638909 2.3125 4.625,0.390180644032255 1.96157056080646 2.25 4.5,0.293460948910722 1.97835301992956 2.1875 4.375,0.196034280659119 1.99036945334439 2.125 4.25,0.098135348654834 1.99759091241034 2.0625 4.125,-2.09798541386808e-15 2 2 4,-0.0981353486548382 1.99759091241034 1.9375 3.875,-0.196034280659124 1.99036945334439 1.875 3.75,-0.293460948910726 1.97835301992956 1.8125 3.625,-0.390180644032259 1.96157056080646 1.75 3.5,-0.48596035980653 1.94006250638909 1.6875 3.375,-0.580569354508927 1.91388067146442 1.625 3.25,-0.673779706784443 1.88308813036604 1.5625 3.125,-0.765366864730182 1.84775906502257 1.5 3,-0.855110186860567 1.80797858624689 1.4375 2.875,-0.942793473651998 1.76384252869671 1.375 2.75,-1.02820548838645 1.71545722000054 1.3125 2.625,-1.11114046603921 1.66293922460509 1.25 2.5,-1.19139860898487 1.60641506296129 1.1875 2.375,-1.26878656832729 1.54602090672547 1.125 2.25,-1.34311790969404 1.48190225070992 1.0625 2.125,-1.4142135623731 1.41421356237309 0.999999999999999 2,-1.48190225070992 1.34311790969404 0.9375 1.875,-1.54602090672547 1.26878656832729 0.875 1.75,-1.60641506296129 1.19139860898487 0.8125 1.625,-1.66293922460509 1.11114046603921 0.75 1.5,-1.71545722000054 1.02820548838644 0.6875 1.375,-1.76384252869671 0.942793473651997 0.625000000000001 1.25,-1.80797858624689 0.855110186860566 0.562500000000001 1.125,-1.84775906502257 0.765366864730181 0.500000000000001 1,-1.88308813036604 0.673779706784442 0.437500000000001 0.875000000000003,-1.91388067146442 0.580569354508927 0.375000000000002 0.750000000000003,-1.94006250638909 0.485960359806531 0.312500000000002 0.625000000000004,-1.96157056080646 0.39018064403226 0.250000000000002 0.500000000000004,-1.97835301992956 0.293460948910727 0.187500000000002 0.375000000000004,-1.99036945334439 0.196034280659125 0.125000000000002 0.250000000000005,-1.99759091241034 0.0981353486548404 0.0625000000000026 0.125000000000005,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2)),((7 8 7 8,10 10 5 5,6 14 3 1,4 11 4 6,7 8 7 8)))
