[postgis-devel] Box3D
Vincent Heurteaux vincent.heurteaux at geomatys.fr
Wed Jul 25 23:18:34 PDT 2007
We are trying to use a PostGIS database with a column of "box3d"
type. I realize that most PostGIS functions are designed for working
on geometry objects, but we though that "box3d" was exactly what we
need (namely, store the envelope of a 3 dimensional raster). However
we ran over a number of problems:
* It seems to be impossible to create an index for a
   column of type "box3d". Did we missed something?
* It seems impossible to pass a "box3d" object in a JDBC
PreparedStatement
   using the PostGIS driver. Attempt to pass a org.postgis.PGbox3d
instance
   to PreparedStatement.setObject(...) results in an exception
similar to the
   problem described here:
   http://www.postgis.org/pipermail/postgis-users/2005-June/008536.html
   Attempt to pass a BOX3D as a String did not worked neither
(PostgreSQL
   said that it don't know any && operation taking my argument, or
that my
   argument is an invalid geometry). We add to pass the argument as a
   MULTIPOINT rather than BOX3D.
Are we missing some simple trick, or are we suppose to avoid "box3d"
columns when using PostGIS?
Vincent Heurteaux
http://www.geomatys.fr
