[postgis-devel] Moving towards a 1.2.2 release?
Mark Leslie mark at refractions.net
Fri Jun 1 08:30:09 PDT 2007
Mark Cave-Ayland wrote:
> Hi folks,
> I've just been committing a series of outstanding fixes to PostGIS SVN,
> including going through the PostGIS bugtracker to clear out some of the
> low-hanging fruit before the next release. Is there a reason why bugs
> can only be tagged against versions up to and including 1.1.7 on
> phpBugTracker?
> AFAICT the following issues remain before we can release 1.2.2:
> 1. template_gis - the whole thing needs to be revisited...
> 2. Bug #148 - shp2pgsql/unicode points
> 3. Michael Fuhr's test case:
> http://postgis.refractions.net/pipermail/postgis-users/2007-May/015809.html
I'll look at this today.
> 4. Issue with regression tests for sql-mm on different platforms:
> http://postgis.refractions.net/pipermail/postgis-devel/2007-May/002567.html
I've been rewriting tests to snap results to as 1e-8 grid when I've
found these errors.  It looks like that grid could get considerably
small if needed.
> I'm aiming to complete 1 & 2 - would it be possible for someone else to
> look at 3 & 4? In particular, can Mark please have a look at 3 - the PIP
> shortcut code *still* has a bug in it somewhere... :(
> Kind regards,
> Mark.
