[postgis-devel] Moving towards a 1.2.2 release?
Paul Ramsey pramsey at refractions.net
Sat Jun 2 07:54:35 PDT 2007
So the client software has to know exactly what distribution it is
working against and create its own lwpostgis on the fly to create a
new spatial database?  There is a valid need for a template, and the
more commonly the template is installed, the better for client
software.  We are hoping to create a situation where someone with
Mapguide can point it at a windows install of PostgreSQL and just
start working, without any special magic administrative steps.
That's where the idea of both having template_postgis and asking that
it be created as part of the installation comes from.
P
On 2-Jun-07, at 7:46 AM, Stephen Frost wrote:
> * Paul Ramsey (pramsey at refractions.net) wrote:
>> We need a "template_postgis" routine in the distribution because we
>> are going to start recommending that one be created by any packaged
>> version of PostGIS. This will allow client software without access to
>> the server to create "spatialized" database with a CREATE DATABASE
>> sql command, instead of needing to know the location of the magic
>> lwpostgis.so on the server side.
> Erm, that doesn't make sense.  Distributions put the lwpostgis.so
> into a
> specific place, and at least on Debian that's the PG lib directory
> which
> means you don't need to know the path to it at all.  In either case
> though, the problem of knowing where the lwpostgis.so exists has
> already
> been solved by the packaging system, it's not like it moves it around,
> nor does it take alot of magic to figure out what that place is.
> Distributions that don't put it into the PG lib directory (and I don't
> know if there are any such) are pretty silly and could stand to have
> that fixed *anyway*, imv.
> If that's the only reason for a 'template_postgis' then it should be
> removed entirely.  My original assumption was that it was there to
> make
> it easier for admins, which can be a worthwhile goal, not to try to
> solve some non-problem.
> Regardless, however, I've got no intention (and, indeed, would be
> strongly against) of creating a database of *any* kind during package
> installation under Debian.  There's alot of broken cases where it
> won't
> work, so you can't assume it'll be there in the end, and in general I
> don't feel it's something which is appropriate for a package like
> PostGIS to *do* anyway.  Make it easy for an admin to create a
> template_gis, fine, but don't recommend distributions automatically do
> it on installation.
>> That said, the current thing in the distribution does seem a terrible
>> mess and very debian-specific.
> Indeed.  My concern is more with the 'terrible mess' than the
> 'debian-specific' piece of it, of course. ;)
> 	Stephen
>> On 1-Jun-07, at 6:58 AM, Stephen Frost wrote:
>>> * Mark Cave-Ayland (mark.cave-ayland at ilande.co.uk) wrote:
>>>> AFAICT the following issues remain before we can release 1.2.2:
>>>> 1. template_gis - the whole thing needs to be revisited...
>>> Agreed, 100%.  I don't really see why anything for template_gis
>>> needs to
>>> be or should be done during build but even beyond that it didn't
>>> appear
>>> to be respecting $DESTDIR properly for some reason.  For those
>>> reasons I
>>> removed it from the build for the Debian PostGIS 1.2.1 packages.
>>> I'm
>>> also not at all convinced it should even be a part of the main
>>> PostGIS
>>> distribution...
>>> Also, the 'extras/debian' directory should be removed, it's horribly
>>> outdated, wrong and obsolete.
>>> 	Thanks!
>>> 		Stephen
