[postgis-devel] Fedora postgis build problems revisited
Devrim GÜNDÜZ devrim at CommandPrompt.com
Tue Jun 26 12:06:46 PDT 2007
Hello,
On Fri, 2007-06-22 at 09:35 +0100, Mark Cave-Ayland wrote:
> Does the Makefile from SVN solve your problem -
> http://svn.refractions.net/postgis/trunk/java/jdbc/Makefile ?
Great! It seems to fix the build problem. Thanks.
However, we have another problem now:
RPM build errors:
    Symlink points to BuildRoot: /usr/bin/createdb.postgis
-> /var/tmp/postgis-1.2.1-1.fc7-root-root/usr/bin/createdb.postgis
    Symlink points to BuildRoot: /usr/bin/mktemplate_gis
-> /var/tmp/postgis-1.2.1-1.fc7-root-root/usr/bin/mktemplate_gis
    Symlink points to BuildRoot: /usr/bin/rmtemplate_gis
-> /var/tmp/postgis-1.2.1-1.fc7-root-root/usr/bin/rmtemplate_gis
This is not a packaging problem, AFAICS.
SCRIPT_DOLINK=rm -f $(SCRIPT_LINK); \
              $(LN_S) $(SCRIPT_TARGET) $(SCRIPT_LINKDIR)
Any suggestions for that?
> BTW, would it cause you any packaging problems if the JDBC driver was
> changed to use Ant instead of make?
Dunno. Give me the diff, I'll test it against Fedora.
Regards,
Devrim GÜNDÜZ
PostgreSQL Replication, Consulting, Custom Development, 24x7 support
Managed Services, Shared and Dedicated Hosting
Co-Authors: plPHP, ODBCng - http://www.commandprompt.com/
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070626/42dd309c/attachment.sig>
