[postgis-devel] lwgeom_gml.c patch
Eric Lemoine Eric.Lemoine at camptocamp.com
Tue Mar 6 22:09:48 PST 2007
Hi
Here is a patch to lwgeom_gml.c. This patch fixes the output
of asgml() for polygons, adding the tags <gml:LinearRing>
and <gml:coordinates> which were missing.
Patch applies to current svn trunk.
PS: patch is appended below for comment, and also attached for a
well-formatted patch to apply.
Thanks,
Eric
Index: lwgeom/lwgeom_gml.c
--- lwgeom/lwgeom_gml.c	(revision 2594)
+++ lwgeom/lwgeom_gml.c	(working copy)
@@ -223,10 +223,16 @@
 	size_t size;
 	int i;
-	size = sizeof("<gml:polygon></gml:polygon>");
-	size += sizeof("<gml:outerboundaryis><gml:linearring>/") * 2;
-	size += sizeof("<gml:innerboundaryis><gml:linearring>/") * 2 *
-		poly->nrings;
+	size = sizeof("<gml:Polygon>");
+	size += sizeof("<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>");
+	size += sizeof("</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>");
+	size += sizeof("<gml:innerBoundaryIs><gml:LinearRing><gml:coordinates>")
* (poly->nrings - 1);
+	size += sizeof("</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs>")
+	size += sizeof("</gml:Polygon>");
 	if ( srs ) size += strlen(srs) + sizeof(" srsName=..");
 	for (i=0; i<poly->nrings; i++)
@@ -246,14 +252,14 @@
 	} else {
  		ptr += sprintf(ptr, "<gml:Polygon>");
- 	ptr += sprintf(ptr, "<gml:OuterBoundaryIs>");
+ 	ptr += sprintf(ptr,
 	ptr += pointArray_toGML(poly->rings[0], ptr);
- 	ptr += sprintf(ptr, "</gml:OuterBoundaryIs>");
 	for (i=1; i<poly->nrings; i++)
- 		ptr += sprintf(ptr, "<gml:InnerBoundaryIs>");
"<gml:innerBoundaryIs><gml:LinearRing><gml:coordinates>");
 		ptr += pointArray_toGML(poly->rings[i], ptr);
- 		ptr += sprintf(ptr, "</gml:InnerBoundaryIs>");
"</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs>");
 	ptr += sprintf(ptr, "</gml:Polygon>");
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070307/b3d5d5f6/attachment.bin>
