[postgis-devel] Geomtries
Leticia lgomez at itba.edu.ar
Thu Mar 15 05:06:16 PDT 2007
Hi, I need to build a new index. It is similar to R-tree but their entries
nodes contains not only the MBRs but some numeric information.
I am using a "CREATE TYPE" in order to create the data type for the table.
The SQL sentences look like
CREATE TYPE New_Type
   internallength = -1,
   input = New_Type_IN,
   output = New_Type_OUT,
   storage= plain
CREATE TABLE proof (col   New_type);
CREATE INDEX anIndex ON proof USING GiST(  col   New_Type_Ops);
As I am creating an opaque data type, I need to create an equivalent one in
C language. I need something like this:
/* C language */
typedef struct My_New_Type
    ???  geometry;
    float4  number;
} My_New_Type;
Which kind of Postgis data type must I use in the "geometry" field
structure.
As the "My_New_Type" will be stored as the "col" attribute in the table, I
need it not to be a "pointer" so I can't declare as PG_LWGEOM, LWGEOM, etc.
Could you help me?
Thanks in advance,
Leticia
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070315/19cbd490/attachment.html>
