[postgis-devel] Re: [postgis-users] installation problem
vamsee movva vamseejump at gmail.com
Thu May 10 08:42:25 PDT 2007
Hi Mark
I commented all things which deals with templateGIS in GNUMake file.
When i executed make i got the following errors
lex.yy.c:4023: warning: `yyunput' defined but not used
lwgeom_chip.c: In function `CHIP_in':
lwgeom_chip.c:128: warning: int format, different type arg (arg 4)
shpopen.c:176: warning: `rcsid' defined but not used
dbfopen.c:206: warning: `rcsid' defined but not used
make: *** No rule to make target `templategis', needed by `all'.  Stop.
Thanks
On 5/10/07, Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> On Thu, 2007-05-10 at 11:25 -0400, vamsee movva wrote:
> > HI mark,
> > I tried what you told,
> > But no luck, Is there any alternative (Note: i don't have root
> > privileges)
> > Thanks
> Can you double-check that? Did you do a "make clean", alter the
> GNUMakefile, and then do "make install" again? Note that it would be
> possible to help you better if you post the output you are getting to
> the list. FWIW the change you need to undo is the templategis changes to
> GNUMalefile from this commit:
> http://postgis.refractions.net/pipermail/postgis-commits/2007-January/000018.html
> Kind regards,
> Mark.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070510/7e19eab6/attachment.html>
