[postgis-devel] Re: [postgis-users] installation problem
vamsee movva vamseejump at gmail.com
Thu May 10 09:24:49 PDT 2007
I was not able to do that , I tried to scroll.
But i could see till 900th line :( .
Can we write all errors into file in some way??
Thanks.
On 5/10/07, Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> On Thu, 2007-05-10 at 12:12 -0400, vamsee movva wrote:
> > Hi mark
> > i executed
> > createlang plpgsql test
> > Then
> > psql -d test -f lwpostgis.sql
> > I don't know why it is happening like this.
> > Thanks for your time.
> OK in that case, as I mentioned in my last email, you need to scroll
> back up your terminal and find the *first* ERROR statement; that will
> tell you the reason for the failure.
> Kind regards,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070510/b6d08364/attachment.html>
