[postgis-devel] RE: PostGIS compilation with Cygwin
Norman Vine nhv at cape.com
Fri Oct 5 09:32:55 PDT 2007
Obe, Regina writes:
> Rimma,
> I'm not sure if building on Cygwin is still being tested with
> postgis so its kind of hard to tell what kind of strange
> errors you would be getting.
> Have you tried compiling with MinGW.  I think that's what
> most Windows developers are using to compile Postgis.  That's
> what I usually use but its been a while since I've done that
> myself.  I haven't tried Ming on my windows vista laptop, so
> I'm not sure if there are any issues with running that on Vista.
I think one needs to either build Postgres locally or have
the postgres-dev distribution as well as the source distribution
installed
HTH
Norman
