[postgis-devel] [Fwd: Build Error (Job 36671): postgis-1_3_1-1_el5 on fedora-5-epel]
Devrim GÜNDÜZ devrim at CommandPrompt.com
Tue Oct 16 11:41:51 PDT 2007
Are there any Java guys around who can fix this problem?
Regards, Devrim
-------- Forwarded Message --------
> From: buildsys at fedoraproject.org
> To: devrim at commandprompt.com
> Subject: Build Error (Job 36671): postgis-1_3_1-1_el5 on fedora-5-epel
> Date: Tue, 16 Oct 2007 14:36:19 -0400 (EDT)
> Job failed on arch x86_64
>          Build logs may be found at http://buildsys.fedoraproject.org/logs/fedora-5-epel/36671-postgis-1.3.1-1.el5/
> The method addDataType(String, String) from the type PGConnection is deprecated
> 6. WARNING in ./src/examples/TestServer.java (at line 83)
> 	((org.postgresql.PGConnection) conn).addDataType("box3d", "org.postgis.PGbox3d");
> 6 problems (6 warnings)touch compile
> jar -cf postgis.jar -C ./bin org -C ./bin examples -C ./src org/postgresql/driverconfig.properties -C . README COPYING_LGPL -C ../.. COPYING
> cp postgis.jar postgis_debug.jar
> jar -uf postgis_debug.jar -C ./src org -C ./src examples
> cp postgis.jar postgis_1.3.1.jar
> cp postgis_debug.jar postgis_debug_1.3.1.jar
> mkdir -p javadoc-build
> # We use an ugly trick to build on windows and unix -
> # javadoc command line options are not portable wr/t path separators
> javadoc -d javadoc-build -sourcepath "src:jtssrc:;src;jtssrc" \
> 		org.postgis org.postgis.jts org.postgis.binary org.postgis.java2d examples
> java.lang.RuntimeException: The source path ;src;jtssrc does not exist.
>    at gnu.classpath.tools.gjdoc.Main$11.process(gnu-classpath-tools-gjdoc-0.7.7.jar.so)
>    at gnu.classpath.tools.gjdoc.Main.readOptions(gnu-classpath-tools-gjdoc-0.7.7.jar.so)
>    at gnu.classpath.tools.gjdoc.Main.start(gnu-classpath-tools-gjdoc-0.7.7.jar.so)
>    at gnu.classpath.tools.gjdoc.Main.main(gnu-classpath-tools-gjdoc-0.7.7.jar.so)
> make: *** [javadoc-build] Error 1
> make: Leaving directory `/builddir/build/BUILD/postgis-1.3.1/java/jdbc'
> error: Bad exit status from /var/tmp/rpm-tmp.28667 (%build)
> RPM build errors:
Devrim GÜNDÜZ
PostgreSQL Replication, Consulting, Custom Development, 24x7 support
Managed Services, Shared and Dedicated Hosting
Co-Authors: plPHP, ODBCng - http://www.commandprompt.com/
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20071016/bff7481d/attachment.sig>
