[postgis-devel] [Fwd: Build Error (Job 36671): postgis-1_3_1-1_el5 on fedora-5-epel]
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Oct 22 06:59:35 PDT 2007
On Mon, 2007-10-22 at 15:24 +0200, Per-Olof Norén wrote:
Hi Per-Olof,
Thanks for the interest :D
> We are talking about separating the java build from the postgis build,
> right?
Not necessarily; the aim is more to find a tool/mechanism to build the
JDBC driver on both Windows and Unix platforms.
> Ant is good, a far better choice than make, but there is also maven.
> Given my recent (successful) attempt to use hibernate-spatial with
> postgis using maven, I'd opt for maven.
I've had a quick look at this, and AFAICT Maven is framework that sits
above the build process to manage project building for you (in other
words, it still needs a build tool such as Ant working underneath it).
I've done a reasonable amount of Java coding to know how Ant works, but
not Maven. I would suggest the best thing to do would be to write a
proposal and post it onto the list for comment.
> However, before volonteering, I'd like to nose around the sources
> alittle and I'd also much appriciate any pointers to previous
> discussions, being a list newbie :-)
Markus and Norman are the main Java users; I'd suggest browsing the
source and then posting questions back to the list for someone more
knowledgeable to comment upon.
HTH,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
