[postgis-devel] Preparation for 1.3.2 release
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Oct 29 10:05:48 PDT 2007
Hi everyone,
I found myself with a spare day and decided to review/apply a number of
outstanding patches to the PostGIS tree. The patches that have been
applied are as follows:
- Charlie's patch to ensure bounding box/envelopes return a valid
geometry in the case of where the input bounding box represents a POINT
or LINESTRING rather than a POLYGON
- Charlie's point deserialisation patch to correctly display the name of
the geometry type trying to be deserialised
- Removed version information from lwpostgis.sql which should remove a
lot of the pain of upgrading from the 1.3.2 release to newer releases
(only functions with changes require the SQL definitions to be reloaded)
- Applied parts of Charlie's MSVC patch in preparation for MSVC builds
>From this point of view, the latest SVN passes all regressions on Linux
32-bit and MingW-compiled Win32, so I'm reasonably confident I haven't
broken anything too badly. However, more testing is always welcome in
case I've missed something subtle :)
The only other patch outstanding I can see is this one here for
shp2pgsql:
http://postgis.refractions.net/pipermail/postgis-users/2007-September/017165.html. I don't really have enough shapefiles lying around to test this, so if someone could check and apply, that would be really helpful.
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
