[postgis-devel] [Fwd: Build Result: 36836 - postgis on fedora-6-extras]
Devrim GÜNDÜZ devrim at CommandPrompt.com
Wed Oct 31 14:57:04 PDT 2007
On Wed, 2007-10-31 at 21:34 +0000, Mark Cave-Ayland wrote:
> I've spent a few hours over this evening playing with Ant, and have
> come up with the attached Ant file to build the JDBC driver. The main
> caveat is that it doesn't include any JTS JAR support; however I don't
> believe many people are using this, and it should be fairly easy to
> add at a later date if required.
Great news! Thanks.
> Can you check to see if you can build on your system?
I will, this evening.
Regards,
Devrim GÜNDÜZ
PostgreSQL Replication, Consulting, Custom Development, 24x7 support
Managed Services, Shared and Dedicated Hosting
Co-Authors: plPHP, ODBCng - http://www.commandprompt.com/
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20071031/4f08fae1/attachment.sig>
