[postgis-devel] Is it possible to get rid of platform specific lwpostgis.sql files?
Paul Ramsey
pramsey at refractions.net
Thu Sep 6 20:57:49 PDT 2007
As of what PgSQL version?
P
On 6-Sep-07, at 7:33 PM, Tom Lane wrote:
> Charlie Savage <cfis at savagexi.com> writes:
>> The PostGis installation scripts generate different versions of
>> lwpostgis.sql per platform.
>> For example, here is Affine defined on Linux and Windows:
>> CREATE OR REPLACE FUNCTION
>> Affine
>> (geometry,float8,float8,float8,float8,float8,float8,float8,float8,flo
>> at8,float8,float8,float8)
>> RETURNS geometry
>> AS '$libdir/liblwgeom.so.1.3', 'LWGEOM_affine'
>> LANGUAGE 'C' IMMUTABLE STRICT;
>> Affine
>> RETURNS geometry
>> AS '$libdir/liblwgeom.dll', 'LWGEOM_affine'
>> Notice the library names are different. However, if you look at other
>> postgresql contrib modules they don't do this.
> This is definitely deprecated practice --- you should rely on dfmgr to
> supply the appropriate platform-specific extension.
> regards, tom lane
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
