[postgis-devel] Patch for PostGis Envelope Bug
Charlie Savage cfis at savagexi.com
Sun Sep 9 00:25:16 PDT 2007
>> However, is this another bug then?
>> select astext(extent(GeomFromText('POINT(-104 40)')))
>> "POLYGON((-104 40,-104 40,-104 40,-104 40,-104 40))"
Martin Davis wrote:
> Looks like the same bug/design issue.  JTS would return the envelope as
> a POINT in this case.
This issue has been causing me problems, so I dug into.  Geos in fact
does return a POINT when you ask for the envelope of a POINT.
It's PostGIS that is wrong.  The method LWGEOM_envelope (line 2493 in
lwgeom_functions_basic.c) *always* returns a polygon.  So I changed it
to return a point if the input geometry is a point.
I've attached a patch that fixes this issue.  The patch checks to see if
the input geometry is a point or a multipoint with just one geometry.
There may be 2 issues with the patch:
1.  The check ins't foolproof, one could subvert it by:
select asText(Envelope(GeomFromText('MULTIPOINT(10 10, 10 10)')));
Maybe checking the bounds (or area) of the envelope would be better?
2.  I'm not sure I handled the SRID correctly for a mutlipoint.  I just
took it from the multipoint itself.  Can the first point in a multipoint
have a different SRID?
Anyway, it would be great if someone could review this patch and apply
it if it seems ok.  I think its important because its easy to create
invalid geometries that don't work with GeomUnion/Contains/Within/etc.
We run into this problem a lot now that we've upgraded to GEOS 3 (GEOS
2.1 seemed to work ok, although maybe that was pure luck.).
Thanks,
Charlie
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070909/39d92b24/attachment.ksh>
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070909/39d92b24/attachment.bin>
