[Fwd: [Fwd: Re: [postgis-devel] Re: Patch for PostGis Envelope Bug]]
Charlie Savage cfis at savagexi.com
Fri Sep 21 20:19:16 PDT 2007
Hi Martin,
> If the examples you give in the email below are actually what your
> Envelope patch is doing, this is WRONG!
Ah, right.  That's bbox patch is equivalent to your snippet of code and
should be correct.  But the envelope patch isn't as you noticed.
Thanks for the verifying - will fix.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070921/4ad7c792/attachment.bin>
